Cutting polycarbonate skylight panels? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-24-2012, 06:33 PM   #1 (permalink)
Soundguy's Avatar
Member # 32677
I've ordered a couple 12' sections of U panel polycarbonate skylight panel, I want to cut it into 4' sections and install these pieces on 2 of my walls to bring some light into my shop during the day. What's the proper way to cut this stuff? My roofing guys said it fractures and they typically don't like to cut it unless they have to. I plan to start throwing metal on the walls next weekend so I need to know how to cut this stuff without destroying it. I've cut the metal panel with a circular saw and reversed blade but that seems like it would kill the plastic panels.
Soundguy is offline   Reply With Quote
Old 09-24-2012, 06:50 PM   #2 (permalink)
dkf
Member # 220187
Just got some 3/16" cut for my tow motor roof. They used a table saw and believe me they did not take it easy. Looked like it had a thin kerf carbide tip blade on it.
dkf is offline   Reply With Quote
Old 09-24-2012, 06:53 PM   #3 (permalink)
jamespadgett's Avatar
Member # 99417
I have cut a lot of diff plastics with an abrasive blade, it does melt/leave a wide cut so there is some waste.
jamespadgett is offline   Reply With Quote
Old 09-24-2012, 07:55 PM   #4 (permalink)
Fabrication Nation
roarksupply.com's Avatar
Member # 176241
We cut vinyl siding with a circular saw but we ran the carbide blade backwards so it wouldnt chip, crack, etc.
I have seen a few plastic designated circ blades in our book so I know they r out there.
EDIT: I remember our cabinet installers putting the blue tape over the line they were cutting and would cut on top of it to prevent chipping. I would tape both sides if possible
10% Site Wide Discount Code - GRIT
Phone: 949-939-6889 Email:tom@roarksupply.com
roarksupply.com is offline   Reply With Quote
Old 09-24-2012, 08:19 PM   #5 (permalink)
Jbevs's Avatar
Member # 143241
Maybe power shears?
Jbevs is offline   Reply With Quote
Old 09-25-2012, 05:05 AM   #6 (permalink)
MC
MC's Avatar
Member # 21997
Send a message via Yahoo to MC
We cut new windows for our CNCs every couple of years from bigger lexan stock. A table saw and 2 guys is what it takes. If you go that route make sure you wear some goggles.
Industrial Quality CNC machines at a Hobby Price!
USA Quality is job #1
We build CNC plasma tables, click me
American Motors Engine HERE!!
1-651-257-7917
MC is offline   Reply With Quote
Old 09-25-2012, 05:26 AM   #7 (permalink)
Member # 9994
I'd check with the manufacturer of the panels to see what their recommendations are.
1984 CJ-8
1986 CJ-7
1981/1992 CJYJ
1994 RAM 1500 4x4
Custom Fabrication Parts:
[url]www.troutindustries.com[/url]
jeepnmatt is offline   Reply With Quote
Old 09-25-2012, 05:28 AM   #8 (permalink)
Member # 157046
Seems like the two most recommended rules are:
Keep the plastic protective layer on while cutting, or add your own (tuck tape, packing tape, etc).
and
Use tooling that is both sharp and high teeth count.
First link google shows is this:
Lexan Corrugated Polycarbonate
And they say this:
How to cut Lexan: Lexan Polycarbonate Corrugated sheet can be cut with a variety of common hand-held and table-mounted equipment. In general, sharp tooling with fine cutting teeth should be used to minimize vibration and clatter Sheets should be properly supported along the trim line before cutting. Circular Saws: Use a fine-tooth, hollow ground panel blade with 10-12 teeth per inch. Sabre saws equipped with a fine-tooth blade can also be used, but proper support is recommended.
xmptsunami is offline   Reply With Quote
Old 09-25-2012, 05:34 AM   #9 (permalink)
Member # 228961
Band saws work great if you have one big enough. If not, table saw as mentioned above, then use a blowtorch to finish the edges. Youtube has all of it covered.
s14slide is offline   Reply With Quote
Old 09-25-2012, 06:09 AM   #10 (permalink)
Member # 82603
Metal blade in a jig saw
3 layers of masking tape
Soup Man is offline   Reply With Quote
Old 09-25-2012, 07:41 AM   #11 (permalink)
D60
D60's Avatar
Member # 6398
Shit, a few years ago I cut several panels for a deck covering. I'll be damned if I remember which circular saw I used, but it was probably my 8" Milwaukee metal cutting with the finer tooth blade for thin metal. I didn't think anything of it, just cut it like I would corrugated tin or propanel, and no problems. Maybe I got lucky.
IME only the flat sheets will have protective coating.
On a different note, it took an act of congress to find this material in the same pattern as standard roofing "propanel" so I could shove it up under my existing roof. Finally found it thru Tallant, and then had to convince Lowe's they COULD order it, including providing Lowe's with the right number to call LOL
"Take 300 people and on average 290 of them just generally suck at life"
D60 is offline   Reply With Quote
Old 09-25-2012, 09:22 AM   #12 (permalink)
Biohazard
Gozuki's Avatar
Member # 3088
We use a waterjet, but a router or table saw work fine too...
Originally Posted by fatdan460 View Post
it leads to real abuse, like guys who will smack a broad in the head
For Sale!! F150 5x135mm wheels!!
Wanted, Ak parts, kits or whole rifles!
Gozuki is offline   Reply With Quote
Old 09-25-2012, 12:21 PM   #13 (permalink)
cbrogers's Avatar
Member # 27362
If you want to use the Circular Saw method, go out and get one of those really cheap plywood blades made of HSS only. No need for carbide, and the blade should be like $7.
Another method if you have air is to use a Body saw. Those fine steel cutting blades should work great. You could use a Saws-all with a really fine metal cutting blade.
But the biggest issue is going to be cutting down on vibrations. If you can clamp it to a sheet of plywood near the cut that will help. Something like the body saw with a nice short stroke will probably work best.
I have cut poly carbonate on a Table saw and it works well, just big, loud and difficult to maneuver a large sheet.
Carl
cbrogers is offline   Reply With Quote
Old 09-25-2012, 04:16 PM   #14 (permalink)
Soundguy's Avatar
Member # 32677
Their recommendations are to order them the length you need straight from them and pay double the cost of a 12' sheet just for them to cut it into 4' pieces.
Old 09-25-2012, 04:19 PM   #15 (permalink)
Soundguy's Avatar
Member # 32677
I've got the Meuller Metal Buildings regional manufacturing plant right down the road from my house and they keep R and U panel polycarbonate sheets in stock but only in 12' lengths, anything else is custom ordered and the price doubles if you do that.
Old 09-25-2012, 05:46 PM   #16 (permalink)
plasma dust huffer
carslut's Avatar
Member # 25823
Send a message via ICQ to carslut
i cut it with a air powered body saw. as long as i use a new blade and don't rush it produces clean cuts. i have also used a high speed router with some luck when removing inserts while making some decorative parts with colored polycarbonate. ive heard guys have luck with circular saws running a new blade and putting wood directly under the cut but i have yet to try that style of cutting.
one of these style body saws.
for long cuts i use a piece of wood as a guide.
so far my newest one is from these guys and holding up well.
Duramax and LS based motor tuning
Offering in House Custom CNC Plasma cutting services, we can take your idea from design to your doorstep.
have a sketch you want to become parts for your project? pm me, i can help. parts are shipping out daily
"it makes the mach5 look like a vagina" - ARCHER
carslut is offline   Reply With Quote
Old 09-25-2012, 05:58 PM   #17 (permalink)
mikegyver1's Avatar
Member # 107241
I use a plexiglass blade on the tablesaw and or the skill saw with a kerf blade. helps if you cut it over a sheet of plywood to support it.
WTF
Build thread
/forum/jeep-hardcore-tech/1050315-project-ang-er.html
mikegyver1 is offline   Reply With Quote
Old 09-26-2012, 05:03 PM   #18 (permalink)
Member # 185509
Best way is to lay it on foam board and cut into the foam.Sabre saw with afine wood cutting blade or circle saw with a thin kerf carbide blade works good ,dont turn a carbide tipped blade backwards because you will knock the tips off the blade.
Mjddddd is offline   Reply With Quote
Old 09-27-2012, 06:51 AM   #19 (permalink)
Pedal Junkie
Mutt's Avatar
Member # 8649
Depending on the poly carb it could cut easy, it could melt into a fucking nasty horrible mess that slings stringy goo...
I have had the best luck cutting thick polycarb and lexan with these sawzall blades, or any style pruning blade. Best bet is to try to get a sample piece, if not, you will know within the first few inches.
Have a broom ready, makes as much mess as wood.
-Steve
43" SX, h1's, ori's, ord magnum/np205, D60/D70, lq4, th400, bentfab chassis ....some assembly required.
Mutt is offline   Reply With Quote
