4-stroke chainsaw mill - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-06-2013, 01:48 PM   #1 (permalink)
Member # 30288
Im planning on making my own mill as I have 3500 acre of forest. I`ll make a shop,shed etc. out of the materials
I want a chain saw blade as I will have a variety of sizes of threes, and a band saw seems like to much hassle to get right. Chainsaws with 7hp is reccomended by mill producers, but I dont need a new powerful chainsaw.
One alternative is electric, but it is a hazzle to run an extensioncord to where I need it to be, so that is pretty much out of the question
So I figure a cheap chinese 200cc 4stroke rated at 6.75hp should do the job. way cheaper than a chain saw. chain saw runs around 10krpm, the 4stroke peak at 3000rpm. If I set it up with a chainsaw clutch and a 1:4 belt drive, Id get 1/4 of the torque (Torque:8.5ft-lb(11.5N.m)/3000rpm) and the speed I need for the chain.
The chain would be about 16" with a "split chain" with 10 degrees teeth.
Im not sure what torque a 7hp chainsaw is rated at
Any opinions?
This is the basic design I`ll base min off
Name:  03-02-2013 02-26-40.jpg
ShuDuck is offline   Reply With Quote Quick reply to this message
Old 02-06-2013, 02:07 PM   #2 (permalink)
0[III]O
Redfin's Avatar
Member # 132064
BUY MY
Toy/Lexus 3.0 clutch...
Bendix Tuflo compressor
I NEED
Cadillac 425 rear sump pan
Redfin is offline   Reply With Quote Quick reply to this message
Old 02-06-2013, 02:15 PM   #3 (permalink)
Crazy Old Troll
Screwzer2's Avatar
Member # 38193
It'll work, but it'll be slower than a bandsaw mill. You'll be cutting a 1/4" instead of a 1/16" kerf.
I'd look for a Woodmizer Bandsaw mill if I could find it.
I actually agree with Screwzer enough to make me uncomfortable...
Screwzer2 is offline   Reply With Quote Quick reply to this message
Old 02-06-2013, 02:27 PM   #4 (permalink)
Member # 12429
Woodmizer LT15 Portable Sawmill Bandsaw 18HP | eBay
Looks
Todd W is online now   Reply With Quote Quick reply to this message
Old 02-06-2013, 02:30 PM   #5 (permalink)
Member # 30288
Originally Posted by Redfin View Post
Think I got the conversion right. 1 "mål", Is 10 000 square foot. I have 1500 "mål"
I have not been thinking of it as much
I was just looking at some home made band saw mills on youtube and it seems just as easy to build, maybe easier actually. I do like efficiency I`ll need to look more into the band type
cheapest bandsawmill to get around here is $10 000, I`ll build something for 1/10 of that
Old 02-06-2013, 02:33 PM   #6 (permalink)
Member # 30288
Originally Posted by Todd W View Post
That`s very nice, I can build that
Old 02-06-2013, 02:39 PM   #7 (permalink)
Member # 117898
I think that's about 350 acres.
brianZ71 is offline   Reply With Quote Quick reply to this message
Old 02-06-2013, 02:41 PM   #8 (permalink)
Member # 84361
Closer to 350 acres then. Still an awesome amount of land.
Toy, 4.3, 4l60, d300, tons, 38's, Trail Slut
Buggy parts pile in progress.
crazybluerider is offline   Reply With Quote Quick reply to this message
Old 02-06-2013, 02:43 PM   #9 (permalink)
Member # 30288
yeah, you are right
Old 02-06-2013, 04:23 PM   #10 (permalink)
Member # 198851
The chain saw idea will work...But I think you'll need 10 HP....
ADChevy4x4 is offline   Reply With Quote Quick reply to this message
Old 02-06-2013, 06:27 PM   #11 (permalink)
CJ
Member # 71
You could make an electric "breakdown" mill
This one is 15 hp motor with a 8ft bar on it, there is crap stacked where the log would go then the saw travels down the track. it also travels up and down go you can set the place it will cut
it is for cutting logs before going on the 36" Sandborn band mill.
Matt
81 CJ7
CJ is offline   Reply With Quote Quick reply to this message
Old 02-07-2013, 02:04 AM   #12 (permalink)
Member # 30288
Guess I would want that for both types of saw. I need to find a used engine
Very nice, did you build it? how fast is it compared to a band saw? And that is a nice shed, excactly what I want to build
Old 02-07-2013, 05:57 AM   #13 (permalink)
Member # 30288
Anyone know the reccomended blade speed for bandsaw? need to calculate the pulleys.
I have apperently changed my mind on the chain saw mill, and want a band saw mill instead. Should be easier to construct and faster in use
a 15hp is cheap enough new, hard to find anything like this used
Old 02-07-2013, 07:38 AM   #14 (permalink)
85f150dsel's Avatar
Member # 43079
There is a milling forum on arboristsite, glad to see you changed your mind, as aband saw is the way to go if you are doing much at all. You waste too much wood and time with a chain.
smileysarmory.com
85f150dsel is offline   Reply With Quote Quick reply to this message
Old 02-07-2013, 08:07 AM   #15 (permalink)
Member # 30288
Thanks, I`ll check it out. that is what I realized looking at vidoes etc. got no experience with milling at all
Old 02-07-2013, 05:42 PM   #16 (permalink)
billybob_81067's Avatar
Member # 52387
Send a message via AIM to billybob_81067 Send a message via MSN to billybob_81067 Send a message via Yahoo to billybob_81067
Whatever you do end up doing post it up on here because I've been kicking around the idea of building a lumber mill for a while now. I think it'd be badass to cut my own planks and timbers out of the cottonwoods we have around here (I know cottonwood sucks but it's all we really have!)
billybob_81067 is offline   Reply With Quote Quick reply to this message
Old 02-08-2013, 04:36 AM   #17 (permalink)
Member # 30288
I`ll post up a build thread for everything here
So far I have decided on the the design:
15hp
22"trailerwheels with hubs
I want to drive the blade directly on the tire
Angle irons as tracks
two post design
not decided on electric winch for height adjustment or manual
this is a design I really like
Band saw blade speed: 3000-5000 feet/min
with a more understandable terms that is 914 -1524 m/min
If I drive the wheel directly and the motor runs at 3000rpm, I would need a 3.5:1 gear. I would get a blade speed of 1510 m/min. A 6" drive should do it
But then again I would need to read up on preferred blade speed related to blade life, cutting speed etc.
Old 02-08-2013, 05:01 AM   #18 (permalink)
Member # 198851
That's very interesting machine.
I have worked with portable band saws mounted on a 25' trailer . The engine was two cylinder gasoline, I would guess about 20 HP. This is a machine designed for constant use with an automatic log feed and hydraulic log lifting ramp.It's been some time but I believe the band saw was also powered by a hydraulic motor.
Old 02-08-2013, 02:56 PM   #19 (permalink)
Member # 78096
Pocket Bike Mill
moulin a scie de poche (pocket sawmill)partie 1 - YouTube
Jeep07 is offline   Reply With Quote Quick reply to this message
Old 02-08-2013, 03:25 PM   #20 (permalink)
Member # 30288
well.. that thing is fawesome !
I did play with the hydraulic thought today as I have a bale packer (the white tractor eggs) with several hydraulic motors etc. that I could strip. But instead I posted it for sale, and have a lot of interests. I have tried before, but cheaper this time
Anywho, I should get this project moving pretty good soon with over double the budget that I need
Old 02-09-2013, 03:25 AM   #21 (permalink)
m715's Avatar
Member # 2235
I like your idea, I've got a friend with some land that wants his own small sawmill to build a workshop, very interested on watching the build...subscribed.
Originally Posted by Jeep07 View Post
would never have thought of that
1977 CJ7 Chevy 327 and some other stuff...
1968 M715...Under Construction
m715 is offline   Reply With Quote Quick reply to this message
Old 07-15-2013, 04:12 AM   #22 (permalink)
Member # 335610
Hello ShuDuck,
Where did you find this Blue Bandsaw design? I like it too.
It looks quite a simple build
Regards Colin
15hp
two post design
Attachment 743306
Whitworthsocket is offline   Reply With Quote Quick reply to this message
Old 07-16-2013, 10:55 PM   #23 (permalink)
Member # 203479
That IS badass!
I like Toyota's
"Never half-ass two things, whole ass one thing"
UndefinedTaco is offline   Reply With Quote Quick reply to this message
Old 11-09-2013, 09:47 AM   #24 (permalink)
Member # 210335
Well, I have decided to build a chainsaw mill myself, I had one before. It turns out excellent smooth lumber with a ripping chain.
I decided not to go with a chainsaw head and to go with a 2 stroke. I am looking at 190cc and using a gocart clutch. True, the heads only get to 3100-3600 rpms, but, the chain does not spin at 8k-13k rpms on a chainsaw because of the gearing/small sprocket on the chainsaw clutch.
Usually a (small) 8 or 9 tooth on the chainsaw because it does not have the torque and the lawnmower engines do have the torque and you end up using a (big) 12-14 sprocket.
I am just not sure how I figure actually saw chain speed using the motor RPMs with the tooh count at each sprocket AND add in the size of each on the chainsaw and bar end. I know there has to be a Unix app somewhere ! :-D
4x4prepper is offline   Reply With Quote Quick reply to this message
Old 11-09-2013, 12:40 PM   #25 (permalink)
Member # 52387
Ah was looking for this thread earlier and lost it! Subscribing so that I don't lose it again! I have the bed for a bandsaw mill made. It's 4' wide and 20' long. Now I need to get to work on the actual saw part of it...
