Any Tips or Cool Mods for a Harbor Freight Shop Press.... - Pirate4x4.Com : 4x4 and Off-Road Forum
Register Blogs FAQ Community Calendar Premium Memberships
Old 12-24-2013, 06:50 AM   #1 (permalink)
Member # 211134
Well I made it back to the "Big City" yesterday and swung by Harbor Freight and picked up a few things. The main thing I was after was the grey 20 ton shop press and they had one in stock. Along with some 3in casters.
I'm quickly running out of room in my shop and I was thinking of putting the casters on the press to move it around. Either bolting or welding them on. Would that be a bad idea?
I also grabbed a set of those car dollies to set axles on so I could move them around the shop. Any other creative uses for them or modifications?
Fordf150 is offline   Reply With Quote Quick reply to this message
Old 12-24-2013, 07:03 AM   #2 (permalink)
Newbie
TheTurtleLab's Avatar
Member # 387794
Swag Off Road has an awesome brake for that press. I got the heavy duty finger brake. and it works great!
Also, you can replace the hydraulic jack with an air/hydraulic jack from harbor freight. It saves a bunch of time, and you don't have to sit and pump the stupid thing all day.
If you are adding wheels, I would ditch the angle feet with square tube, because with wheels attached to the angle, they will want to twist a lot when you move the press around.
Cool fabricated junk and plasma art for sale >>
82 1-ton CJ7 - 350/SM465/NP205/14rr/60fr - In Progress
98 Jeep XJ - Stock drivetrain, to be expedition rig
88 CRX with VX motor 45MPG+
93 BMW 325i
93 International Thomas School Bus RV Conversion
TheTurtleLab is offline   Reply With Quote Quick reply to this message
Old 12-24-2013, 12:35 PM   #3 (permalink)
Member # 211134
I hadn't even thought about that. When I get it to gather I'll see how flimsy it is. Might have to add an angle brace or 2.
Old 12-24-2013, 01:53 PM   #4 (permalink)
It's bent. #ttb
vetteboy79's Avatar
Member # 31621
Send a message via AIM to vetteboy79
I put my HF 20-ton on 3" casters, works fine. Although my garage floor is pretty nice...if you have to take it over a bumpy surface you might want to reinforce the bottom as mentioned.
I also have the SWAG 20-ton press brake kit, definitely a nice thing to have. I've used it way more than I thought I would.
The Alternative Rocker - Taurus SHO V6-powered, Explorer-framed, TTB-front, RCV'd, YJ-bodied east coast racer
Flying Pig Racing #512
vetteboy79 is online now   Reply With Quote Quick reply to this message
Old 12-24-2013, 02:34 PM   #5 (permalink)
Swag Off Road's Avatar
Member # 120418
Thanks for the kind words.
Let us know if you have any questions.
Troy
Innovative fabrication tools, & Drop down tailgate kits for YJ's, TJ's and JK's.
Visit us on
Swag Off Road is offline   Reply With Quote Quick reply to this message
Old 12-24-2013, 05:04 PM   #6 (permalink)
Brian1's Avatar
Member # 2205
Here is how I modded my orange 20 ton press; Harbor Freight 20 Ton Press Rehab - OFN Forums
I have heard the grey one is better built but a few things I did to mine would still apply. I use castors with a larger base and no problems so far. It makes it nice to move around.
Brian
NMOffroad.com
Brian1 is offline   Reply With Quote Quick reply to this message
Old 12-24-2013, 05:41 PM   #7 (permalink)
Shift to the Best
R.DesJardin's Avatar
Member # 68266
Yep this is it. Added an air over hyd. cylinder of course.
Manual auto trans shift controllers and shifters, GM, Jeep, Toyota, Nissan & more,
Toyota Triple Stick shifters, Dealer of Winters Shifters & Transgo Kits.
My stuff:
John 3:16- He is the answer.
R.DesJardin is offline   Reply With Quote Quick reply to this message
Old 12-24-2013, 06:36 PM   #8 (permalink)
Member # 211134
That turned out nice! I really like the basket on the bottom.
I grabbed a few end pieces of bar stock from the scrap pile at work and trued the ends up on the lathe to use for pushers and spacers. Some kind of basket that is attached would keep everything right there when you need it.
Old 12-24-2013, 06:37 PM   #9 (permalink)
Member # 211134
I looked at them while I was there, just about picked one up. Now I'm wishing I would have.
Old 12-25-2013, 12:16 AM   #10 (permalink)
Member # 141570
That is definitely a nice piece. Too pricey for me at the moment though. As a makeshift, I made a full width punch and die out of 20' of 2x2x1/4 angle and a scrap of DOM I had laying around. A little tedious to use, but gets the job done if dimensions are not real critical. I've used it on up to 1/4" a36 plate.
To the OP, for your jack stands/axle stands, make an angle iron frame you can set the base of the stand in, mount some casters on it, and you'll have a roll around axle cart. But you can always just pull the stands out if you need them for their intended purpose. If you plan on using the stands for not just storing, but actually working on the axles, you may want to devise a pinion support to keep the housings rotated to the position you need. You can use a third jack stand for this, but a support will free up a stand and probably be less trouble in the long term.
dirtydawgZ71 is offline   Reply With Quote Quick reply to this message
Old 12-25-2013, 12:43 AM   #11 (permalink)
fume sniffer
rocklobster87's Avatar
Member # 122979
I went to the local steel yard and had a few various size blocks with different dimensions cut in pairs from scaps out of a bin. They are perfect for building up the base and will not bend.
cost ~$20.
edit: btw that press is the best thing I ever bought from HF.
I also use the ram all over the shop, particularly as a floor jack for anything tall enough to straddle it.
rocklobster87 is offline   Reply With Quote Quick reply to this message
Old 12-25-2013, 04:13 AM   #12 (permalink)
not2hye's Avatar
Member # 186552
Isn't there also some risk of the harbor frieght plates shattering?
Too much junk...
not2hye is offline   Reply With Quote Quick reply to this message
Old 12-25-2013, 04:19 AM   #13 (permalink)
Member # 152591
Yes. Get some quality arbor plates.
Sent from that shitty app that is exactly like tapatalk but now has advertisments
Losing House...Still got the Jeep
CO80jeep is offline   Reply With Quote Quick reply to this message
Old 12-25-2013, 04:33 AM   #14 (permalink)
Member # 256522
Yup haha
Cplourde10 is offline   Reply With Quote Quick reply to this message
Old 12-25-2013, 05:16 AM   #15 (permalink)
Member # 211134
Originally Posted by Cplourde10 View Post
I was under the impression the new ones are steel instead of cast.
Old 12-25-2013, 05:18 AM   #16 (permalink)
Member # 152591
Not when i was in our store a week ago. Was the new style gray press with the same old shitty plated.
Old 12-25-2013, 07:53 AM   #17 (permalink)
Member # 100827
Send a message via AIM to smewhtguy
cost ~$20.
Great advise, same thing I did. I got 8"x8" cut in pairs from 1/2"-3/4" and 1" and also 2"-3"-4"x8" in pairs out 3/4" plate. Best $30 ever spent after one of the hf plates exploded and almost killed me.
I do math and stuff, on a professional level.
smewhtguy is offline   Reply With Quote Quick reply to this message
Old 12-25-2013, 08:34 AM   #18 (permalink)
Member # 130003
First purchase should be the SWAG press plates! I am sure he would combine shipping if you order along with a brake or any of his other cool accessories!
Just looking at the press plates in pictures, they may seem pricey, but when you get them in your hot little hands, they are worth the money!
Harold Phipps is offline   Reply With Quote Quick reply to this message
Old 12-25-2013, 09:49 AM   #19 (permalink)
Member # 3935
You would think HF would be concerned about liability and swap the plates out for decent ones.
[QUOTE=camo;17280058]All of you are fawking idiots :shaking:[/QUOTE]
southernfriedcj8 is online now   Reply With Quote Quick reply to this message
Old 12-25-2013, 06:58 PM   #20 (permalink)
Member # 29644
Send a message via AIM to 71Dauntless
This thread on Garage Journal says that the new plates are plate and not cast like the old style
Harbor Freight 20 ton press is changing - Major Changes - Info inside - The Garage Journal Board
1971 CJ5
2006 Toyota Tundra
71Dauntless is offline   Reply With Quote Quick reply to this message
Old 12-25-2013, 08:05 PM   #21 (permalink)
D45
Member # 102974
They are still cast plates at my local HF store
2012 Ford F150 FX4; Long Bed; 3.5L V6 ECO; Max Tow; 3.73; Leveled; 275/65R20 Goodyear Duratracs
D45 is offline   Reply With Quote Quick reply to this message
Old 12-25-2013, 08:24 PM   #22 (permalink)
Member # 211134
That's were I read that the new ones are steel and not cast.
Old 12-25-2013, 08:27 PM   #23 (permalink)
Member # 211134
Could it be the ones at your local store are just left over plates from the other presses and just in use for display purposes?
I will get mine opened tomorrow and we will get to the bottom of this.
Old 12-25-2013, 08:27 PM   #24 (permalink)
fume sniffer
Member # 122979
i got steel plate arbor plates with my 20 ton (~5/8" x 2" x 6"), not the above pictured. they bent easily under the power of the ram unless on end and were useless.
edit: that was 2+ years ago.
Old 12-26-2013, 05:16 PM   #25 (permalink)
Member # 187391
I dont think they are, its the cheapest that they can get them with the hi-est profit, all from china. got to love/hate nafta. i have one of these too and just scraped the plates and jack and bought decent ones.
locost7 is offline   Reply With Quote Quick reply to this message
