Tube bending legs in phase, how do you do it? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-21-2004, 09:10 PM   #1 (permalink)
JeepinDoug's Avatar
Member # 13028
I've been bending tube with a JD2 M3 bender for at least 12 years. The first couple years were a pain trying to bend two parallel legs in phase, such as a main hoop. Exagerating, the two down legs always looked like they were walking.
My Model 3 bender dies have always been somewhat loose in the support arms and with a heavy 1.75" x 180* die and 12 foot of stick it like to sag. Even with a roller stand and a good eye it's tough to get the legs in phase.
After a couple years of frustrating with out of phase legs I finally came up with an idea that works so well I could guarantee the legs to be in phase by .1*, (Yes, that's one tenth of a degree).
Around the time I bought my bender I also bought a Smart Level, a digital level originally made for contracting work. A simple digital head unit clips into varying lengths levels. I only bought the head unit thinking I would buy a shorty level base for it later, but they stopped making them this way. I took an old C-clamp and welded some angle to the anvils. Then some fence tabs to fixture the head unit. I ended up with this.
Now when I bend a hoop, I go ahead and bend one leg, while pressure is on the dies I set the level on the tube and tap it to zero, then cinch it up. The C-clamp needs to be in a place where it will not run into the dies or need to be removed to pull the tube from the bender. After the first leg is finished I gently flip the tube for the other bend. Find my start point and twist the tube until I hit zero. It's a good idea to put pressure on the dies while finding zero as a relaxed die set at zero will net as much as a half degree out of phase, big deal but with long legs you can be of your mark by alot.
Next to the bender this digital level has been worth it's weight in gold, setting steering geometery, pinion angles and even leveling picture frames around the house.
What do others do besides eye-balling legs in phase?
I may lack much in way of integrety but I make up for it with pure denial.
[URL=http://www.pirate4x4.com/forum/showthread.php?t=377480][B][COLOR="Red"]Malvado Grande #1[/COLOR][/B][/URL]
JeepinDoug is offline   Reply With Quote
Old 06-21-2004, 09:31 PM   #2 (permalink)
Member # 17015
http://www.no-dog.com/
Paul Elbisser #3233
Rice on the Rocks Pres.
One of Those Guys
Supra powered
TLCA Paul is offline   Reply With Quote
Old 06-21-2004, 11:16 PM   #3 (permalink)
71RCKCRZR RYAN's Avatar
Member # 2569
yeah i guess that way works......
i usually bend one 90.........flip it a round line up the mark..snug it up good...stand back and get the first leg level with the die, well not level acually a butthair under because i have found the tubing twists a tiny bit when ya bend ..no matter what degree the ground is etc.....the second leg will be level will the first....
[SIZE="6"][COLOR="Red"] SALE ON EVERYTHING [/COLOR][/SIZE]
SHOOT ME A PM
SWAY AWAY airs at 220 ea the rest 10% off retail
DUDENBEAR 10% off retail
RUBICON XPRESS buy 4 or more at 28$ ea
AIR MANAGMENT
ETC ETC
[SIZE="7"][COLOR="Lime"][FONT="Impact"]WWW.WICKEDFABRICATION.COM[/FONT][/COLOR][/SIZE]
WickedFabrication.com[/URL] [/SIZE]
[email]SALES@WICKEDFABRICATION.com[/email]
408-898-6210
71RCKCRZR RYAN is offline   Reply With Quote
Old 06-22-2004, 02:49 AM   #4 (permalink)
TB76Bronco's Avatar
Member # 7452
I've been having the same problem. It seems no matter how careful I am the legs are always off. I'll have to try your method. I have a Smart Level head unit too they are great.
Does the bender have to be level to do what you are saying? I'm having a hard time picturing it. I can't really level mine very easily since it is hydraulic and the stand is on casters.
TB76Bronco is offline   Reply With Quote
Old 06-22-2004, 06:32 AM   #5 (permalink)
Member # 14644
you need to use the smart level and match it with the DIE with pressure on it. If your die rotates down a bit(mine does) then you need to set your tube accordingly. Match the angle of the die to the angle of the first bent leg.
1986.5 Nissan crawler - dual cases, one tons, 42's...
2003 SV650
1997 F350 DRW PSD
bignissan is offline   Reply With Quote
Old 06-22-2004, 10:51 AM   #6 (permalink)
DRM
Super Moderator
DRM's Avatar
Member # 8
I have to admit - my manual JD2 gives me fits sometimes too. I have leveled the bender by way of leveling the stand, but the "sloppyness" of the bender and die can still cause headaches with the process. I keep hoping more practice will show me the way to mastering it
>David
> 4x4Spot.com
>It only hurts the first time you agree with me...
>"A little nonsense now and then is cherished by the wisest men."
DRM is online now   Reply With Quote
Old 06-22-2004, 01:41 PM   #7 (permalink)
fabcam's Avatar
Member # 19763
You need to make sure the die is level. Checking the stand is nice, however, it is best to go straight to the source.
The best way to do this is to place a tube in the bender and apply a little pressure, now place a level on the tube. Should be level. Now bend the tube 90 degrees and before releasing from the bender check to see if the end of tube that rotates is level. Now when you use a level on the next bend it means something.
The site for the fabricator: [URL="http://www.offroadfabnet.com/index.php"]www.offroadfabnet.com[/URL]
[COLOR="Orange"]Bend-Tech [URL="http://www.2020softwaresolutions.com/bt_pro.htm"]PRO[/URL] is now available!!![/COLOR]
Design full tube [URL="http://www.2020softwaresolutions.com/web_images/Racer-X_5[1].jpg"][U]chassis[/U] [/URL]in less than a couple of hours with the PRO
[COLOR=Cyan]We are the developers of the Bend-Tech products.
[COLOR="Yellow"]651-257-8715[/COLOR] for sales and support[/COLOR]
[URL=http://www.2020ssi.com]www.bend-tech.com[/URL]
[COLOR="Cyan"]10,000+[/COLOR] now using Bend-Tech
fabcam is offline   Reply With Quote
Old 06-22-2004, 02:33 PM   #8 (permalink)
Member # 19652
Send a message via AIM to socalchef
someone once told me to bend with the seam inside....so i made a small mark on the center of the radius on the die and always line up the seam on the tube with the mark on the die. works well for off camber floors.
socalchef is offline   Reply With Quote
Old 06-22-2004, 06:24 PM   #9 (permalink)
TB76Bronco's Avatar
Member # 7452
I'm pretty sure the Smart level thing only works with the bender level so I guess that won't work for me.
I'll try the seam trick. I tried making a mark down the entire length of the tube and it still came out off. Maybe my line wasn't quite straight.
Old 06-22-2004, 08:13 PM   #10 (permalink)
Member # 14644
No it doesn't. If you measure your die with pressure on it at say.... (0.1*) then match your tube up to (0.1*) and they are now in the same plane....make sense?
2003 SV650
1997 F350 DRW PSD
Old 06-22-2004, 11:30 PM   #11 (permalink)
H M F
Im4yotas's Avatar
Member # 8758
I do mine the same way that Ryan explained. I use a mobile hydraulic homemade bender, and have used it in a level shop, out on crooked cobblestone, and even in the sand at a friends house. Always comes out right. I have used the cheapo Harbor Freight magnetic angle finder, but I've grown tired of waiting for the pendulum to stop on the mark, so I ordered the Smart Tool and magnet attatchment yesterday. Got it from this place http://www.speedpartz.com/smarttoolmagneticbracket.htm
Drive it like Tim!
Im4yotas is offline   Reply With Quote
Old 06-22-2004, 11:33 PM   #12 (permalink)
Member # 8211
I use a cheap weighted magnetic protractor for the same thing. Never woried about getting the die level, just fine it's angle and make the tube match. Works fine for me...
Russ
85 K30 truggy, 350 TBI, TH350, 203/205, D60/C14, 4.56 Locked, 42" TSLs, 4" lift, 112" wheel base, front leafs, rear double triangulated 4 link with coils.
BadDog is offline   Reply With Quote
