comp tank leaks thru valve when closed - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-23-2004, 12:58 PM   #1 (permalink)
a2b
a2b's Avatar
Member # 22547
so i have a 35 gallon husky compressor i got from the depot.
a few weeks ago, it started not closing when i screwed the valved to close position. it still leaks anyways. what the heck is going on?
-Hobie
GOTPROPANE.COM
HI-DESERT DRIVELINE IS THE BEST DRIVELINE EVER!
a2b is offline   Reply With Quote
Old 06-23-2004, 01:11 PM   #2 (permalink)
Banned
Member # 24950
Are you talking about the air release valve? I have had those go out after just a few uses. Take it off and replace it with a good ball valve.
Butler is offline   Reply With Quote
Old 06-23-2004, 01:59 PM   #3 (permalink)
a2b
a2b's Avatar
Member # 22547
yes, the air release valve. thanks
-Hobie
GOTPROPANE.COM
Old 06-24-2004, 07:20 AM   #4 (permalink)
Banned
Member # 24950
Freaking
Noho wheelers. After fighting with all different varieties of those cheap ass brass ones, I put a galvanized 90 on mine and then a small ball valve. Never sticks, always seals and does what it's told.
Old 06-24-2004, 08:52 AM   #5 (permalink)
cranky bastard
plunkinberry's Avatar
Member # 20868
Alright, at first I thought he was talking about the butterfly valve at the bottom of the tank used to release water/air after use - mine leaks there too. But after Butler's question and the response, I'm no longer sure...
Help with my leaking valve on the bottom of the tank???
plunkinberry is offline   Reply With Quote
Old 06-24-2004, 10:12 AM   #6 (permalink)
Member # 9287
a good lever ball valve is the ticket to your problems.
88 XJ 8"/36s/locked
when I grow up - I don't want to be like you
xj4rocks is offline   Reply With Quote
Old 06-24-2004, 10:34 AM   #7 (permalink)
Banned
Member # 24950
I was talking about the butterfly valve,too. Hobie are you talking about the blow-off? The valve that opens if the pressure gets too high?
Old 06-25-2004, 08:44 PM   #8 (permalink)
AprilzWarrior's Avatar
Member # 21033
Stainless Steel Ball Valves... Go big 1" for quick drain of the tank. Gets the crap out and wont leak like the POS Petcocks.
AprilzWarrior is offline   Reply With Quote
Old 06-25-2004, 11:01 PM   #9 (permalink)
Member # 2463
You said Pet Cocks.
pmurf1 is offline   Reply With Quote
Old 06-26-2004, 02:58 AM   #10 (permalink)
a2b
a2b's Avatar
Member # 22547
nope, i am talking about the valve at the bottom of the tank
-Hobie
GOTPROPANE.COM
