Just a reminder about wedding rings and welding... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-27-2004, 06:53 PM   #1 (permalink)
DRM
Super Moderator
DRM's Avatar
Member # 8
Not only does the wife get pissed you are ruining it by adding on weld boogers, that gold conducts heat WAY fast...
>David
> 4x4Spot.com
>It only hurts the first time you agree with me...
>"A little nonsense now and then is cherished by the wisest men."
DRM is online now   Reply With Quote
Old 06-27-2004, 06:54 PM   #2 (permalink)
DRM
Super Moderator
DRM's Avatar
Member # 8
A better close-up pic...
>David
> 4x4Spot.com
Old 06-27-2004, 07:00 PM   #3 (permalink)
Member # 23566
Send a message via AIM to SirMrManGuy
Awww a boo boo, want me to kiss it and make it better. Pussy.
Last time I went to the hospital the nurse asked me if I used heroin because all the burns on my arms look like track marks.
95 Nissan Pathfinder, D44 front/H233 rear, dual ARBs, 4.56s, 36 Iroks
SirMrManGuy is offline   Reply With Quote
Old 06-27-2004, 07:19 PM   #4 (permalink)
Member # 18671
What he said.
Next time put on a pair of gloves.
no sig
Gen. Nonsense is offline   Reply With Quote
Old 06-27-2004, 08:01 PM   #5 (permalink)
Member # 6957
i used to work near heavt machinery so i don't wear my ring saw a guy lose a finger
ironpig70 is offline   Reply With Quote
Old 06-27-2004, 08:01 PM   #6 (permalink)
DRM
Super Moderator
DRM's Avatar
Member # 8
Anyone else want to chime in? Morons
>David
> 4x4Spot.com
Old 06-27-2004, 08:05 PM   #7 (permalink)
Member # 12780
Send a message via Yahoo to SCOTTS_4X
I do it all day. try not welding bare handed or in those "cool" mechanix gloves like all the jackoffs on tv. the weld spatter doesn't stick to my ring very well, I just chip it off and re-polish the titanium and it's good as new.
-Scott
"A fear of weapons is a sign of retarded sexual and emotional maturity." -Sigmund Frued
SCOTTS_4X is offline   Reply With Quote
Old 06-27-2004, 08:09 PM   #8 (permalink)
DRM
Super Moderator
DRM's Avatar
Member # 8
It was the typical story - I was *just* gonna tack some tube in place, then grab all the gear for the full on welding... Isn't that how it always happens?
And yeah - Mechanix gloves are useless for welding.
I just wanted to post these to show what *can* happen when you think you can just tack a few beads before grabbing the gear... You get burned
>David
> 4x4Spot.com
Old 06-27-2004, 08:27 PM   #9 (permalink)
Member # 18671
Morons
Maybe, but we dont have a nasty wittle burn on our fingers.
no sig
Old 06-27-2004, 11:46 PM   #10 (permalink)
FYRMAN's Avatar
Member # 4358
Send a message via Yahoo to FYRMAN
Just pop the fawker and get back to work.
My two cents: Take the fawker off whenever you are in a shop environment. I've seen way too many screwed up fingers in my short time. Burning flesh is a distinct smell. A smell you never forget. It only takes a second to weld a hot wire, or the positive post of the battery , to any ground using your ring.
[COLOR="Red"]Central Washington Muff Dive and Rescue Team[/COLOR]
FYRMAN is offline   Reply With Quote
Old 06-28-2004, 12:15 AM   #11 (permalink)
braxton357's Avatar
Member # 14685
Send a message via AIM to braxton357
Pussy.
:blackflipoff2bandwagonjoining:
In vino veritas
70 turbocharged 351w fastback mustang
73 linked 5.8efi Bronco
99 QCLB 4x4 twin'd cummins on meth.
braxton357 is offline   Reply With Quote
Old 06-28-2004, 12:18 AM   #12 (permalink)
braxton357's Avatar
Member # 14685
-Scott
Mechanix gloves have their place. They work great under a pair of leather gloves, I'm able to weld quite a bit longer with both pairs of gloves than I am with only the leathers (they've caught on fire a few times now). And they have also saved my hands from the angle grinder more times than I can count and picking up hot tube or working on a hot engine. Wear a pair for a while then don't, you'll see. Don't be all pissy cause theyre on tv and you aren't either.
In vino veritas
Old 06-28-2004, 04:30 AM   #13 (permalink)
DRM
Super Moderator
DRM's Avatar
Member # 8
It isn't that nasty, and it is little... But like FYRMAN pointed out, it could have been MUCH worse, so I got lucky. Been married 5 years now, and this spring was the first time I have really had a problem with it... now the ring has some ugly scars on it (and the wife is NOT happy about that ) and been burned twice now.
To give you an idea - the booger that landed on the ring was about the size of the ball on the end of aball point pen. That small piece heated the gold up so fast, it made a burn the size of the end of 2 pencil erasers. I could only imagine if something bigger landed on there - I would have a blister around the entire finger before I could even realize it was burning.
Again - the point of the post is to go ahead and take it off before you head out to the shop. Next time, I/you may not be so lucky to just walk out with a teeny little burn...
>David
> 4x4Spot.com
Old 06-28-2004, 11:21 AM   #14 (permalink)
Member # 24273
I stopped wearing mine. Pisses the wife off... but I'm tired of taking it on and off while I'm working.
The only time I wear it now is if we are going out (dinner, wedding, etc)
gunracer1- You must have the reading comprehension of a first graded
jerseyzuks is offline   Reply With Quote
Old 06-28-2004, 11:57 AM   #15 (permalink)
FYRMAN's Avatar
Member # 4358
Gold is an excellent metal. It's pretty, it's expensive, it's conducts heat and electricty very well, and has a relativly low melting point. I used to work with a guy that had to have his ring surgically removed after it melted into his finger. To remove it, they cut his dead finger off, slid the ring away from the bone, after they peeled the cooked flesh away from it.
There are too many stories like this one to ignore.
Old 06-28-2004, 12:36 PM   #16 (permalink)
Member # 11998
Send a message via AIM to BrettM
i want to get a Ti ring when i get married, would it be much better? of course it's much harder, but the melting point is much higher too, right? and does it conduct heat/electricity well?
awshifting.com
awshifting@gmail.com
BrettM is offline   Reply With Quote
Old 06-28-2004, 06:33 PM   #17 (permalink)
DuCaTi MoNsTeR
Booger Weldz's Avatar
Member # 2931
some jackass at work just went to hospital to get his 'mechanix' gloves removed. seems you can get them hot enough and melt them to your flesh....when i weld mig at work i just use a pair of work gloves, but when stick welding or dualshield, its always a pair of real 'welding' gloves...
Amongst the best of the toyota vendors:
Www.4wheelunderground.com
Www.addictedoffroad.com
Www.hellfire-fabworks.com
Booger Weldz is offline   Reply With Quote
Old 06-28-2004, 07:55 PM   #18 (permalink)
Member # 12780
first off, keep your hands away from the arc and your leather gloves won't catch on fire, seems to work for me, and I find myself welding 6-8 hours a day, 6 days a week. are you using leather work gloves or insulated welding gloves? if you've welded enough, or worn those mechanix gloves enough you will come to find out they melt. I'm not one for liking melting plastic to be wrapped around my hands. if you are working in a shop environment you should check shit before you pick it up or before you touch it, that's what's going to save you from getting burnt, not a thin pair of gloves with plastic cladding. you are right, they do have their place, but that place is not protection from heat/sparks/fire.
-Scott
Old 06-29-2004, 08:21 AM   #19 (permalink)
Member # 943
So you've done it twice Moron!
The Joker is offline   Reply With Quote
Old 06-29-2004, 09:25 AM   #20 (permalink)
Evil Twin
yager's Avatar
Member # 10695
Send a message via AIM to yager
drm - i understand you post your trying to help spare someone some pain and everyone is a big tough guy... Seeing all the pbb injuries has definilty helped me. I now wear eye glass consitantly and even hearing protection.
and...
Titanium rings are the WORST ring you can wear for the stuff we all do...They are difficult to cut off in an emergency situation. A gold ring is comparibley easier to cut of with minimal effort. Plus gold can be reworked a lot easier if it does get messed up...
just somthing else to think about....
yager is offline   Reply With Quote
Old 06-29-2004, 02:21 PM   #21 (permalink)
BigWoodyWag's Avatar
Member # 26468
Send a message via AIM to BigWoodyWag
Weld splatter can also cruise through a quartz face on a watch real fast like.
Same deal, tack and quick weld latch on gate. I broke it on the way out to go to work. Decided not to wire it closed, and could get it done quick. So there I am in a Suit, Tie, Helmet, mig cart & stinger in hand at 7am or so. Took one little booger due to hitting a chunk of paint. Landed right on my watch face. Killed the watch! And lets just say it's not the kind you pick up at WallyWorld.
Hindsite 20/20 stupid, stupid, stupid. Hell I could have ruined a suit. Thats what I get for not liking to leave things broke, after I've broke them.
DRM sorry you got hurt, suck it up, before someone mails you some tampons!
Triple Nickel Racing, Lead Foot Syndicate & TGTW Lemons Racing
555race on TWITTER
BigWoodyWag is offline   Reply With Quote
Old 06-29-2004, 02:24 PM   #22 (permalink)
Brandon's Avatar
Member # 6
Send a message via ICQ to Brandon
My ring is coverd in boogers, I have to keep turning it since it cuts against my fingers. Too scared to grind em out and too cheap to pay to have it done
This Space for rent!
Brandon is offline   Reply With Quote
Old 06-29-2004, 03:06 PM   #23 (permalink)
Member # 16812
So all I'm getting out of this is: Don't get married.
-t
LandCroozer is offline   Reply With Quote
Old 06-29-2004, 03:34 PM   #24 (permalink)
rockmup's Avatar
Member # 16699
Burned my ring finger to the bone 3/4 of the way around on the two top post of my Blue top Optima.
This will only take a second and ..................why is my ring so hot ? I have two spots on my ring, power in and power out.
07/C2 SOT
/Making guns and fun toys, one hammer swing at a time
Need quality ammo ?
AMERICAN LEAD DISTRIBUTORS
Need a POV system ? REPLAY XD
rockmup is offline   Reply With Quote
Old 06-30-2004, 02:06 AM   #25 (permalink)
Member # 9386
Send a message via Yahoo to zukikid
see i tried to tell people my divorce was due to a safety issue ... zukikid
"life is not convenient"
[QUOTE][i]Originally posted by littlejackass [/i]
[B]aaaahh come awn care bears rock! :D [/B][/QUOTE]
zukikid is offline   Reply With Quote
