Member # 587
I-beam Size
Need to add an I-beam inside of my workshop to
1)hold up rafters 2)lift stuff Need it to be 18' long. What size i-beam will I need????????????? Thanks,
eighty three on thirty eights and a nice tow rig too. |
Member # 22408
Well, there aren't too many variables here!! WTF are you talking about? I assume this is an existing shop? Do you have saggy rafters, ie. it's underbuilt in the first place? What kind of stuff are you lifting? I live five miles from EDH, PM me if your serious. I'm a general contractor and my specialty is framing (structure), i give free advice to good folk.
Kent |
#3 (permalink) | |
Member # 587
#6 (permalink) | |
Member # 587
![]() my new workshop/garage are 2X8X24' and wouldn't trust them for shiat!!!
Member # 10854
What about useing a inverted "C" shape I-beam bolted to the floor for lifting heavy stuff?
A prisoner of war is a man who tries to kill you and fails, and then asks you not to kill him." - Sir Winston S. Churchill, 1952 |
Member # 8203
how about you tell us what the beam is supporting deadload wise in the form of a roof or second floor area, walls, what you intend to lift from the beam, etc.
I could just tell you to go out and buy a W36x230, but you wouldn't want to pay for it!
super cool turbo 4runner |
Member # 16737
I talked with a super on one of my jobs once about I beam for a garage header/hoist mounting. And he said for a span of 20-25 feet that 6" would do fine. I would go bigger though. Im in the same situation your in with a addition to my shop of 12X42 making my "new" shop 24WX42L and will use some steel channel to support the roof(just corrugated metal), but for lifting im going to build a mobile hoist like the ones in wrecking yards that will fit inside the shop. Or I would have to put in a 12" I-beam for my junk because everything I tend to need to lift is extremely heavy(500+lbs). I would go as big as possible and play it safe. Put in some steel posts on either side as well to help support the I beam and load and you should be good to go. Do you have room for some angled supports? This would help support and decrease the span a bit and you could minimize the size if you needed to.
72 Rockwelled yeah whatever... All my shits heavy. |
Member # 16737
Yep, thats the ticket. But im building my own. I wanted to do the I beam trick in the shop like you, but I need something that can go outside as well as most of the heavy junk is stored out of the shop.
#13 (permalink) | |
Member # 84
Anybody know how to make a woman happy?Didn't think so!There are no happy women just confused immature teenager wannabees in an old cougar outfit |
#14 (permalink) |
Member # 19500
Here is the one I made. I call it the swingset. Its made from stuff I had laying around. The pipe is old oil transport pipe. If I slap some grease on the top of the horizontal pipe the chain will slide back and forth fairly well with a load of around 600 lbs.
#15 (permalink) |
Member # 587
Any Engineers out there????
Went to S&K Steel yesterday and think I might have found my I-BEAM. It is 10" tall, 4 5/8" wide and 17' Long. The thickness of the I-BEAM in the center section is 5/16. Each foot weights 25.4 pounds. I am going to set it on 4" X 4" X 1/4" square tubing on each side. Does anybody have access to any software where they can plug in these numbers and tell me how much weight I could lift using this I-BEAM? Thanks,
#16 (permalink) |
Member # 27710
Any Engineers Out There
I beleive the best you can get as far a formula goes, is for deflection of the beam. Deciding how much deflection is allowed determines how much load can be placed upon it. If the I-beam is modeled as a simple beam supported at each end, with the load centered at the middle, the formula is;
Deflection= ((Load)*(Lenght)^3) / (48*(E)*(I)) Lenght should be in inches 48 is a constant E is the modulus of elasticity for the material, 28000-30000 ksi for steel I is the moment of inertia of the beam From my Mechanics of Materials book by Gere, your I-beam sounds like a S10X25.4 designation. It list I as 124 inches^4 Suppose a 1/16 inch deflection is allowed at the center, then the load works out to be about 1200 pounds. Choose how much you think is safe and work from there. |
#17 (permalink) | |
Member # 5670
Then he needs to consider any dynamic load from moving the load on the hoist, and any factors of safety required.
Nothing to see here, move along |
#18 (permalink) | |
Member # 587
So the beam is going to weight 431.8 pound!!! This is going to be fun to get it into place!!! Will probably have to weld the 4" X 4" square tubing posts with it in the air, since my garage is nearly complete. Based on those calculations should I feel comfortable lifting a 1000 pound item with a Ball Bearing Trolley like this? http://www.fastenal.com/web/products...ex?sku=0578632
#21 (permalink) |
Member # 587
The 4 X 4 posts will be welded to the I-BEAM
--------- | | | | -- -- The 4 X 4 posts will be welded to a 16" X 4" plate which will be bolted directly to the 24" concrete footing.
#22 (permalink) | |
Member # 5395
Or do it yourself, that way you're the only one at fault if it fails. http://efunda.com/formulae/solid_mec..._bc_simple.cfm http://efunda.com/math/areas/IbeamIndex.cfm I am an ME, but I wouldn't touch the problem w/o more information.
1977 Dodge Ramcharger, 440/727/203, Dana 60's, 5.38 Gears, Yukon 35 Spline Rear Shafts, 38.5" SX's 1975 Dodge Club Cab, W200, 440/727/203, Dana 60's 1998 Dodge 2500 Club Cab, 12V Cummins/47RE/241, Dana 60/70 1969 Plymouth Roadrunner, 383/727 Last edited by tv_larsen; 07-16-2004 at 12:48 PM. |
#23 (permalink) | |
Banned
Member # 13026
Brian |
#25 (permalink) |
Member # 587
Do you guys think this is enough triangulation???
The one side should be fine. The posts are 4" X 4" X 1/4". The supports are 2" X 2" X 1/4" and the plates are 6" X 12" for the supports and 12" X 12" for the posts. All 1/4" The man door prevents me from having a support on one side. Thanks,
