Member # 15689
jd2 model 4 bender...how thick can i bend?
i wanted to bend some 1.5 x .240 wall dom. would it be ok to bend this thick of material with my bender? it's the jd2 model 4. thanks!
not bad for home grown it's a little more than that sonny |
generally its the die thats the weak point on the model 3s and they use the same dies, correct? if so then I would say its doable but at its limit...stuff that thick its usually better to use a HF poo bender
-Caleb Call |
Member # 13028
I've had no problems with dies in my JD2M3. A couple weeks ago I bent some 1.75"X.250" wall DOM and bent the sh1t out of the follower bar pin. I'd rather bend that than the follower bar itself. BTW, it took myself and a buddy to bend four 90* bends with a 6' cheater.
From what I remember about the JD2M4 bender, the basic structure and dynamics are the same but the arms and supports are taller to accept larger diameter materials. If it uses the same size pins as a JD2M3 your gonna need more replacement pins. Oil or grease the material, make it as easy as you can on the bender
I may lack much in way of integrety but I make up for it with pure denial. [URL=http://www.pirate4x4.com/forum/showthread.php?t=377480][B][COLOR="Red"]Malvado Grande #1[/COLOR][/B][/URL] |
Member # 15689
so in other words. if i try to bend some 1.5 x .240 wall dom it is gonna break some shit?
i am only needing to do like 2, 45 degree bends.
Member # 9576
The dies are different for the JD2-model3 & JD2-model4. They are "priced about the same", but there is not a weldeded on tab on the model 4 dies, like the model 3 ones.
Manual bend or full hydro? I'd just go for it! Only time I had a problem... didn't space the base plate off the stand. Opps. Added some washers for the center pin to drop down correctly, viola no more problem. Stand is built from "what ever scrap was there, and hit with what ever paint was left over" I-beam and gray would have been my preference, but I'm cheap. Oh, hydro bender... so the stand just holds it up, but keeps out of the way for a upside down "U" bend. Tom
Member # 13655
I have bent 1.5" .250 wall DOM in a Model 4 with no problem.
I think Scott at Rockstomper has bent 2" .250 wall on his hydro'd model 3, so I'd ask him to be certain.
89 XJ, 8" lift, 38's, locked F&R 98 LR Discovery - street poser 99 F350 PSD 4x4 Jeep Tow Truck 2003 Mini Cooper S - street go-kart 2004 Subaru WRX STi - Vette eater 2005 Mini Cooper S - street go-kart on LSD Pile of tube, 383 SBC, and some buggy plans |
