Bendomatic Buildup - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-11-2004, 03:34 PM   #1 (permalink)
Member # 21267
Bendomatic Buildup
Hi, here is another tube bender buildup. I made the bender parts and laminated dies with a CNC laser. The results are very good, but I still want to coat the inside of the dies with something to smooth them out. The first thing that comes to mind is body filler but I dont know if it will crack. Have a look at the dies and see if you can suggest another material to squeegee onto the dies.
Thanks
Bendomatic Buildup
Flat50 is offline   Reply With Quote
Old 07-11-2004, 03:45 PM   #2 (permalink)
www.12voltguy.com
SeaBass44's Avatar
Member # 40
bondo will not work, you can scratch it very easily, not intended for that purpose, as a body filler it's great. you might use JB weld or it's varents, maybe some others have an idea.
12voltguy
info@12voltguy.com--davezoffroadperformance.com
# 530.532.4529
TTC 2010 1989 BRONCO
-Awesome web development for your business. www.mudnworks.com mud@mudnworks.com
Pat's W I D E TOYOTA Front Axle
--07 KTM 450XC----with "stuff"
SeaBass44 is offline   Reply With Quote
Old 07-11-2004, 03:46 PM   #3 (permalink)
H M F
Im4yotas's Avatar
Member # 8758
Fawking SWEET!
I think the best thing to do is just use a sanding drum the same diameter of what the die is for and sand it down smooth. Might change the radius of the die by 1/16'th, but that's not big deal.Just make sure you take off the same amount all the way around
Drive it like Tim!
Im4yotas is offline   Reply With Quote
Old 07-11-2004, 03:51 PM   #4 (permalink)
Member # 22345
How 'bout JB weld (or some other epoxy putty)? I think it'll be stronger than body filler. I have to get me one of those laser thingamajigs. Those are some sick cuts!
edit: I see I type real slow and JB weld was mentioned!!! sorry for the repeat!
Balsax is offline   Reply With Quote
Old 07-11-2004, 04:17 PM   #5 (permalink)
Member # 4878
Send a message via ICQ to Travis Waldher Send a message via MSN to Travis Waldher Send a message via Yahoo to Travis Waldher
ok.. so umm.. when ya selling all the lazer cut pieces so we can build these at home. :redneck:
btw - what did that piece of debri in teh die do to your die? Did it gall it all to hell? Based on the reading here, I get the impression dies are kinda, well, shall I say sensitive to galling?
Travis Waldher is online now   Reply With Quote
Old 07-11-2004, 04:29 PM   #6 (permalink)
Member # 21267
No it didnt gall the die at all. It was a piece of millscale left from bending the rusty pipe. Still not smart enough to clean the thing before every use. Die is as good as new though.
Old 07-11-2004, 05:20 PM   #7 (permalink)
waverider's Avatar
Member # 11971
That is totally badass!
Could you use brass or lead or some other soft metal to fill the die? I don't think any epoxy would last very long.
[URL=http://www.lucky13offroad.com]LUCKY 13 OFF ROAD[/URL]
waverider is offline   Reply With Quote
Old 07-11-2004, 05:35 PM   #8 (permalink)
Member # 16024
I'm not sure that any material softer than the base metal would suffice, as it would likely extrude under the pressure from the bending process. Instead, you might try a hardsurfacing welding rod, and a sanding drum/polishing as suggested otherwise. That might take a bit of time, but you would end up with almost indestructable dies.
As the surfaces and arcs are consistent, you ought to be able to automate the grinding process somewhat. Perhaps a really slow pass on a lathe with a drill motor and grinder chucked into the tool rest for the curved part, and a simple surface grinder table (with the same drill motor/sander drum) for the flat parts.
I like the idea of a laminated die - really cost effective over billet stock! Great thinking and an advance of the craft.
Let me know when you are ready to start selling build-at-home kits... I will live with the dies...
Check out UCORA.org
VOTE or SHUT UP!
glfredrick is offline   Reply With Quote
Old 07-11-2004, 05:46 PM   #9 (permalink)
mj
Member # 1919
well that is just too cool
mj is offline   Reply With Quote
Old 07-11-2004, 06:39 PM   #10 (permalink)
snatch cannon
unimogken's Avatar
Member # 11745
Wow, I really don't know what to say.
That is amazing!
You should post that laser cutter in the "your favorite tool" thread because its now one of my favorites!!
Later, Ken
1 Mercedes Benz Unimog 404s
unimogken is offline   Reply With Quote
Old 07-11-2004, 07:38 PM   #11 (permalink)
MossMan's Avatar
Member # 11995
Send a message via MSN to MossMan Send a message via Yahoo to MossMan
That is sweet.
MossMan is offline   Reply With Quote
Old 07-11-2004, 08:45 PM   #12 (permalink)
Member # 29609
Send a message via MSN to doctor_cad
Wow. Only thing you're missing is a "Built in Canada" decal!!
doctor_cad is offline   Reply With Quote
Old 07-11-2004, 10:17 PM   #13 (permalink)
Member # 11154
Very Nice! How about welding the inside of the dies with a "Hard-Facing" type welding rod and then using the idea above (lathe and grinder)
OCNORB is offline   Reply With Quote
Old 07-12-2004, 12:21 AM   #14 (permalink)
Member # 19379
Send a message via AIM to gtidrivr
So when can we all expect a copy of those files to take to a local laser cutting shop and have them made???? Get with it!!! Please...
gtidrivr is offline   Reply With Quote
Old 07-12-2004, 05:14 AM   #15 (permalink)
Member # 16024
Just so you all know, that grinder trick is one I learned a long time ago... With a lack of things like milling machines, and lathes in my home shop, I often have to get creative with a drill press or grinder.
I sometimes chuck a piece into a drill press, (to spin it) and then apply pressure with a grinder (air, electric - with various sorts of wheels) to sort of "lathe turn" by grinding a part. It works pretty well depending on your patience and ability to correctly chuck up the part and clamp the grinder so it can be guided. I have also done something similar with a flywheel that had to be surface ground to take a new clutch while off in the middle of nowhere.
Check out UCORA.org
VOTE or SHUT UP!
Old 07-12-2004, 07:31 AM   #16 (permalink)
Member # 9994
its already in the works...stay tuned. working on low-cost dies right now.
1984 CJ-8
1986 CJ-7
1981/1992 CJYJ
1994 RAM 1500 4x4
Custom Fabrication Parts:
[url]www.troutindustries.com[/url]
jeepnmatt is offline   Reply With Quote
Old 07-12-2004, 08:58 AM   #17 (permalink)
IH/Rover Moderator
Old Scout's Avatar
Member # 17
Send a message via ICQ to Old Scout
West Systems Epoxy with some of there graphite powder additive may work for you.
http://www.westsystem.com/
423 Graphite Powder
423 Graphite Powder is a fine black powder that can be mixed with WEST SYSTEM epoxy to produce a low-friction exterior coating with increased scuff resistance and durability
I like beer. On occasion, I will even drink beer to celebrate a major event such as the fall of communism or the fact that the refrigerator is still working."
BUY MY BOAT
http://www.pirate4x4.com/forum/misc-...e-history.html
Old Scout is offline   Reply With Quote
Old 07-12-2004, 10:02 AM   #18 (permalink)
Member # 11798
Send a message via AIM to scoutkid
i gotta say thats a brilliant idea with the laminated dies, i too would just live with the grooves. How about tinner material, and more laminates? i mean, its just like a calc problem, make the sections thinner and thinner and eventually you will have a 'smooth' line. ::nerd::
2003 E350 7.3L Diesel UJOR 4x4
scoutkid is offline   Reply With Quote
Old 07-12-2004, 10:37 AM   #19 (permalink)
DRM
Super Moderator
DRM's Avatar
Member # 8
I could care less about the dies, I would be interested in the long arms to make mounting up my ram (same as his) on my existing JD2 a bit easier.
besides - dies are $130-$200 a set, I consider that reasonably priced. Buying the laminate die metal can't be cheap (estimated $50 for die and follower), then my time and effort to put the die together - if it takes more than a couple of hours, I start seeing a point og diminishing returns.
Don't get me wrong - if I had a "frickin' laser" at my disposal, I am sure I would delve into all sorts of time wasting projects
>David
> 4x4Spot.com
>It only hurts the first time you agree with me...
>"A little nonsense now and then is cherished by the wisest men."
DRM is offline   Reply With Quote
Old 07-12-2004, 11:12 AM   #20 (permalink)
www.12voltguy.com
SeaBass44's Avatar
Member # 40
so you don't care that the cage is weak??????????? I don't understand that thinking
12voltguy
# 530.532.4529
Old 07-12-2004, 11:19 AM   #21 (permalink)
DRM
Super Moderator
DRM's Avatar
Member # 8
From reading the linked page, he said the light grooving was barely noticeable, and removed with LIGHT sanding... How are you calling that "weak"?
>David
> 4x4Spot.com
Old 07-12-2004, 11:31 AM   #22 (permalink)
Member # 9994
i'm mainly working on a low-cost bender that the average home fabricator can afford to buy. i want one for myself, and have a bunch of friends that would like one as well...but just can't justify the $600 for a bender and die-set just to get started. right now i have just the basic bender prototyped. soon i'm going to start on the brackets to do the hydro-conversion. i may even offer a Kit if the price difference is significant enough that people will want to buy their own bolts and pins. for the prototype i have now, i was able to find heat-treated 1" and 7/8" hitch pins from the local Tractor Supply Co for a really reasonable price...much less than i could make them and have them heated for. honestly, i don't plan on doing anything differently than what is already out there...just cheaper.
Matt
1984 CJ-8
1986 CJ-7
1981/1992 CJYJ
1994 RAM 1500 4x4
Old 07-12-2004, 11:34 AM   #23 (permalink)
Member # 21267
He meant thinner laminations, not tube.
Thanks for the responses. Yes the law of diminishing returns does come into effect here if you cant get free laser cutting like I can. This method is not for everyone. However, you all could find out who has laser shops in your area and email drawings (of the arms, or other parts like high steer arms, disk brake brakets, etc) for quotes. I am sure you would be surprised at how resonable some shops can be. May be cheaper than buying commercially and paying for shipping of a lot of steel. I will post drawings of the bender arms and base soon. I should make a collection of the CAD drawings I already have and put them somewhere thats more accessible. What do I do? Start a CAD thread? Or what?
As for my dies, I'll probably just live with the results for now. The sharp edges may round over the more I use it. If I have to I will just buy real dies, but I'd rather spend the $200 on a driveshaft or something. You guys know how hard this hobby is on the wallet.
Old 07-12-2004, 11:36 AM   #24 (permalink)
Member # 30027
thats awesome, although i think your boss maybe upset when your making more money than he is selling these things
Organized_Chaos is offline   Reply With Quote
Old 07-12-2004, 11:55 AM   #25 (permalink)
www.12voltguy.com
SeaBass44's Avatar
Member # 40
in that case I'm wrong, usually from other threads, (WELDPROs) the groves get deeper, thus getting unsafe.
don't get me wrong, I think what he has done is great! not many doing that, not sure how cheap it can be done, I can get a bender with degree ring for $237, & as ya said dies in the $200 range, I'm going to purchase a bender within the next 12 months or so, maybe sooner, steel prices should be dropping in the next 1-6 months from what I have read, so it's going to be exo time?
12voltguy
# 530.532.4529
