Member # 14644
parts needed to make a lathe a notcher
Picking up a lathe, what do i need to use it like an end mill for notching tube? I can't wait to get it!!!
1986.5 Nissan crawler - dual cases, one tons, 42's... 2003 SV650 1997 F350 DRW PSD |
#3 (permalink) | |
Member # 12499
With the lathe, you could make most of the parts needed to fab what you want, but I doubt a bolt-on assy could be had inexpensively.
Wrenchin' to riches! If you want peace, prepare for war. |
Member # 14644
Thanks, i want to use the "end cutter" not the hole saw, i'm tired of hole saws and would rather pay for the "good stuff". Then I can just feed it into the "side" of the cutter rather than the end of the hole saw. Do I need any special chucks or anything to hold the cutter in the 3 jaw chuck on the lathe head?
Greg
Member # 12499
You'll be better off if you can hold the cutter in a collet as among other things, it will almost certainly run truer.Depending upon the headstock bore/taper, you may be able to get a mill bit holder that will match the bore/taper.
As for the tubing holder/vise, I think it should be fairly easy to mount a piece of heavy angle on the cross slide/compound and mount a vise to the angle. Keep in mind how you will want to change the angle of the vise versus the plane of the cutter. I'm very excited (for lack of a better term) to see what you build up, keep us in the loop. Peace, PT
Super Moderator
Thinking this through, feeding the work into the tool may not be the best idea, depending on what the work piece (tube, etc.) is.
Say you are working with a large, bent, and/or awkward piece of tube, and you are running a stationary cutter and trying to feed the work into it. That seems like it could be problematic, and may cause some problems. Not sure, just thinking this through in my head a bit...
>David > 4x4Spot.com >It only hurts the first time you agree with me... >"A little nonsense now and then is cherished by the wisest men." |
Member # 14644
http://www.vansantent.com/tube_copin...ng_notcher.htm
That is how that one works I believe, it has the vice for $300, but I think I'll just see about making my own. I'm not sure when I'm getting it, it was left to my Mother and I need to go to her friends shop to pick it up. It's a decent size, but not huge. I have the manual for it. I'll post up some more info in a bit. Greg
Member # 18989
Here it is, mounted to the compund cross-slide. You can use an end mill or a hole saw chucked in the lathe.
A flash of lightning illuminated the object, wretch, hideous, filthy daemon. A new species would bless me as its creator. |
#10 (permalink) | |
Member # 12499
I think there are better ways to do it, but other projects in the way. Peace, PT
Member # 14644
not $300 for the one frankenfab posted...I don't know where/how much that one is. The $300 deal is pretty nice from vansant, but I like frankenfabs, I can make that myself.
Thanks!Greg
#12 (permalink) |
anyone else seem to think that lathe was spinning a tad over calculated cutting RPM in that pic......maybe its just the pic i dunno
CS = Recomended RPM*4/D (shorthand) did i do that right? Lord
If it aint broke fix it till it is To the pessimist, the glass is half empty, to the optimist, half full, to the engineer, the glass is twice as big as it needs to be. 00 TJ. 318, NV4500HD, 231, 44 locked on 35's. Work in progress |
#13 (permalink) | |
Member # 12499
#14 (permalink) |
ahh true about the hole saw, i still like to calculate everything out because its a good habit to have when writing code for CNC, HSS is that formula x 1, for a carbide you can multiply the rpms by 3 just because carbide is the best thing ever.
God I love metal more than slutty bitchesLord
#15 (permalink) | |
Member # 12499
I finally got the correct tool holders to use carbide in my lathes. Man, what a difference it makes.
#17 (permalink) |
Member # 14644
looked at the lathe i'm getting, it's a small bench top jobber...so i'm thinking it is probably too small to notch tubing. how much HP do you need to run an end mill notcher? I'm getting it for free, it's old and in the family, so I'm going to use it for small jobs at least, it's an "Atlas" brand. Still in great condition.
1986.5 Nissan crawler - dual cases, one tons, 42's... 2003 SV650 1997 F350 DRW PSD Last edited by bignissan; 07-18-2004 at 10:33 PM. |
#19 (permalink) | |
Member # 12499
Peace, PT
#20 (permalink) |
BIGELOW MOTORSPORTS
bumping this to the top. How many people have used the end mill and did it with their lathe? Also, what size lathe? I priced out a couple of new mill notchers and for the 3500-4k new it seems way easier to pick up an older lathe and a bit. I'm looking solely to do this as a hobbiest and not looking to turn out parts or anything. If you did it what do you think the minimal amount of lathe you could get away with running the bit as a notcher?
TEAM YUKON GEAR and AXLE #4413 Bulldog Winch, Raceline, Maxxis, FOA, Tom Woods, Everlast Welders, Ruffstuff Specialities, Cool Shirt, Stage 8, Baja Designs, PSC Steering, AJIK Overland Exchange, Reid Racing, Artec, Powertank, DynoMax, Hinchman Racewear, DJ Safety |
#21 (permalink) |
Holy old ass thread batman?!
![]() sorry nothing constructive to contribute, always wanted to say that though
When Liberals started making burgers out of beans that was the start of the anti OHV movement. 1995 Dodge Ram V10....infinitely broken Several Trail 90's....Word to the Honda horizontals! |
#23 (permalink) |
Member # 12499
Absofawkinglutely nothing. How much stress do you think taking a big cut induces to the ways?
#24 (permalink) | ||
BIGELOW MOTORSPORTS
![]() ![]() Quote:
#25 (permalink) |
Member # 6398
I'm a little unsure why we're trying to reinvent the wheel. Seems to me a $200 notcher works just fine, is more portable and probably requires less setup time.
I guess if you want to dedicate a machine to this, fine. I personally wouldn't be willing to remove my tool post each time I wanna notch, when I could just as easily walk over to my hole saw notcher. Also if you're using end mills, aren't you needing to stock some pretty damn large end mills? 1.5", 1.75, 2" ? Not that these are impossible to source, but they're not exactly cheap.
"Take 300 people and on average 290 of them just generally suck at life" |
