Making a shear... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-13-2004, 05:48 PM   #1 (permalink)
Member # 14644
Making a shear...
Can I just get the tooling for an ironworker and make my own shear using a bottle jack and such? I would like to shear 1/4" most often---3/8" would be nice, but I don't see that happening. I need to get my books out and see how much pressure I need to shear the 1/4", but I was just wondering if it would work??? I know it would be slow, but a lot nicer than a cut-off saw or band saw.
1986.5 Nissan crawler - dual cases, one tons, 42's...
2003 SV650
1997 F350 DRW PSD
bignissan is offline   Reply With Quote
Old 07-13-2004, 05:49 PM   #2 (permalink)
Member # 14644
also, a punch like that would be nice as well....
2003 SV650
1997 F350 DRW PSD
Old 07-13-2004, 06:15 PM   #3 (permalink)
big97redtj's Avatar
Member # 11356
Send a message via AIM to big97redtj
It all depends on the rake of the upper knife and the seperation distance between the blades. Rule of thumb is 7%-10% of material thickness for the gap.
big97redtj is offline   Reply With Quote
Old 07-13-2004, 07:39 PM   #4 (permalink)
Member # 14644
i need 17.3 tons of pressure to shear 3/8"x3" plate
2003 SV650
1997 F350 DRW PSD
Old 07-14-2004, 04:58 AM   #5 (permalink)
Member # 12499
I'd think you could get the tooling for your hydraulic press and mount the dies in it and go from there.
Wrenchin' to riches!
If you want peace, prepare for war.
PTSchram is offline   Reply With Quote
Old 07-14-2004, 05:29 AM   #6 (permalink)
Member # 16024
I found at one time an article on making a home sheer but can't find it right now. If I find it I will post it for you.
Here is a press brake made in a similar fashion to what you are contemplating.
http://www.frugalmachinist.com/pb.html
Here is a comercial one that might let you figure out some plans.
http://www.medfordtools.com/metalproironworkers.html
Check out UCORA.org
VOTE or SHUT UP!
glfredrick is offline   Reply With Quote
Old 07-14-2004, 10:12 AM   #7 (permalink)
Member # 16351
We made our own sheet metal shear and a small bench top plate break for our shop and they work tits. I will try to get a few picks up as soon as I can. We were considering selling the plate break as a kit that you weld, bolt together for the less serious fabricator, you know the guy that can hang an axle and weld on perches but can't make his own tooling.
I have a design for a hydraulic 40 ton sheer in my head but I am stuck on the blade....do you think a scraper blade off a snow plow blade would work? Its hardened and already drilled for botls etc....anyone?
Check out our webpage coming soon!!
"Fuck you, we all know who the fuck you are. Hit yourself if the face with a rusty shovel you stupid penis sniffer."
MiniMog is offline   Reply With Quote
Old 07-14-2004, 10:31 AM   #8 (permalink)
Member # 15246
It would probably be hard enough, but what about the edge? Will it leave a clean cut, or will the edge of the material be rounded or otherwise deformed?
Andy
Murph is offline   Reply With Quote
Old 07-14-2004, 12:27 PM   #9 (permalink)
Member # 14644
Andy
that would depend on the clearance wouldn't it? As long as the edge was sharp, I don't see why it wouldn't work....great ideas!
Greg
2003 SV650
1997 F350 DRW PSD
Old 07-14-2004, 12:48 PM   #10 (permalink)
Member # 16351
Snow plow blades are never rounded, they scrape cement their entire life leaving a flat (though angled) surface. They are usually available as cast offs when they get to short for plowing snow from being worn down....
Hell a snow plow from a truck has a bunch of good uses, the controller and pump runs my bender ram.
Old 11-11-2004, 10:24 PM   #11 (permalink)
Member # 31838
Could I get some pics of this? I'm planning on making a plate break and can't find many good pics... Something small like a benchtop design might be useful.
Brian
LoveMyToy is offline   Reply With Quote
Old 12-30-2004, 08:03 PM   #12 (permalink)
Member # 31838
bump
Btt
