Member # 14644
Air Compressor question
what determines the size of pump/motor needed for a certain sized tank? I have a good oiled pump and motor that are belt driven, but need a tank. It's mounted on a 10-11 gallon tank now, but I was wondering if I could go up in size to replace the tank? If not...I'll just buy a CH from Lowe's for $400 for a belt drive 60 gal. Thanks,
Greg
1986.5 Nissan crawler - dual cases, one tons, 42's... 2003 SV650 1997 F350 DRW PSD |
Member # 30615
There's probably a happy medium there. I think a lot of it will depend on the power your motor puts out, as to wether it can keep up with the demand of keeping that tank filled. You need to be able to deliver a certain amount of cfm and psi depending on the tools you use. As for specifics, I'm too sure.
1989 toyota pickup, 4x4, 22re 2001 chevy 2500hd 4x4, 8.1/allison Many BIG plans but me and my wallet disagree a little! |
Member # 14644
hmm, If I get a 30+ gallon, once the tank is filled, it should be able to keep up decently I would think. I'll check into more.
Greg
Member # 18989
The CFM that the compressor is capable of providing is the most important factor. The tank only provides for momentary surges. If you are using "surge" devices, such as impact guns or air ratchets, a large tank will help. You will get more bursts out of your tool before the compressor kicks on and you have to wait for the pressure to build back up. For continuous demand tools, like sand blasters or paint guns, you need a large compressor. Get the biggest you can afford.
Excellent info here: http://www.practicalmachinist.com/ub...ML/000039.html I just finished rebuilding my compressor. 17.6 CFM at 120 psi. It's a 3 cylinder, 2 stage. The first 2 cylinders feed the 3rd, which compresses the air a second time.
A flash of lightning illuminated the object, wretch, hideous, filthy daemon. A new species would bless me as its creator. |
