best way to remove old shock mounts ? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-16-2004, 01:03 PM   #1 (permalink)
Member # 33095
I am a newby trying to teach myself how to fabricate. I have 2 old axles that I am trying to prepare for a cj8. what tool is used to remove the old shock and spring mounts to prepare the axles for narrowing? I have a 4 1/2 inch grinder but that seems awful slow. Is that the best tool for the job short of a plasma cutter? Thanks for any help in advance
redd7 is offline   Reply With Quote
Old 07-16-2004, 01:10 PM   #2 (permalink)
GJC
Member # 26181
Just throw on a cutting blade and have at it
Jon
GJC is offline   Reply With Quote
Old 07-16-2004, 01:25 PM   #3 (permalink)
Member # 13395
I've always used a grinder, big Dewalt and even bigger Makita, but a 4.5 grinder will do it. Just get some ear plugs, it makes the job a lot easier on the senses.
TDI FZJ80 and Misc LR junk
HandBuilt is offline   Reply With Quote
Old 07-16-2004, 02:03 PM   #4 (permalink)
No comment
camo's Avatar
Member # 4
Send a message via Yahoo to camo
my prefrence would be a plasma or oxy torch and clean up with a grinder. polish the final area with a flapper disc
camo is offline   Reply With Quote
Old 07-17-2004, 08:19 AM   #5 (permalink)
MattyL13's Avatar
Member # 32766
Send a message via AIM to MattyL13
I second the Oxy-Accetalene torch. if you havent used one before get some junk and pratice, you can "gouge" the welds right off and if youre real good you wont even need to clean up with a grinder. its all about how you angle the torch tip. it takes some practice. i could cut OK before this summer when i got a demolition job. sitting 20-30 feet up on 6" Ibeam dropping the damn beams your sitting on (yes i did say that right) will make you real good at cutting.
PS: I hate my fawking job Ill be glad when i go back to college, hopefully in one damn piece
Lord
If it aint broke fix it till it is
To the pessimist, the glass is half empty, to the optimist, half full, to the engineer, the glass is twice as big as it needs to be.
00 TJ. 318, NV4500HD, 231, 44 locked on 35's. Work in progress
MattyL13 is offline   Reply With Quote
Old 07-17-2004, 10:03 AM   #6 (permalink)
64Trvlr's Avatar
Member # 6582
Torch, sawzall or grinder will all do the job. Remember eye and hearing protection are your best friends.
Originally Posted by Muddin
You must be able to blow harder than me
Originally Posted by Bubba Ray Boudreaux
Shooting is gay.
D.A.V. Life Member
N.R.A. Life Member
64Trvlr is offline   Reply With Quote
Old 07-17-2004, 02:49 PM   #7 (permalink)
Member # 16024
There are two different kinds of wheels for the 4 1/2" grinder - a grinder disk and a cutter disk. The difference is the thickness. Get some thin ones, and you can litterally cut the weld right off the tube. The thick ones just grind into the corner and never really cut the weld.
When you get them, get a bunch - they don't last as long as the grinder type. Also, don't use them for cleaning up the welds that are left, switch back to the regular disks.
In the absence of a torch this is probably the best way.
Check out UCORA.org
VOTE or SHUT UP!
glfredrick is offline   Reply With Quote
Old 07-19-2004, 08:57 AM   #8 (permalink)
Member # 24273
Where are you located?
Somebody may have a plasma cutter or torch you could borrow.
gunracer1- You must have the reading comprehension of a first graded
jerseyzuks is offline   Reply With Quote
