Member # 5380
What press are you using in your shop?
I am updating my garage to be more self sufficient. Giving people a six pack and/or delaying a project is no longer reasonable every time I need to press a bearing or anything else.
I am looking for a H-frame floor model. I don't mind a bottle-jack drive with return springs, but I would like at least a 5 ton. Whatevyagot, and was it woth the cost? Thanks
GUNS ONLY HAVE TWO ENEMIES, RUST AND POLITICIANS. |
Member # 12499
I somehow broke my 12-ton press. The upper horizontal bar was square tubing that collapsed and the jack rides on another piece of tubing that bends.
Make sure you get one with sturdy channel for the upper bar and the same for the movable ram. Mine is now much stronger than originally, but what did I expect for <$100?
Wrenchin' to riches! If you want peace, prepare for war. |
Member # 18989
I have this one:
(It kind of, in a way, almost, sort of, somehow, half ass works.) http://www.harborfreight.com/cpi/cta...emnumber=33497 ![]() I'd get this one: (I have seen one, and it appears that it isn't as sloppy) http://www.harborfreight.com/cpi/cta...emnumber=52837
A flash of lightning illuminated the object, wretch, hideous, filthy daemon. A new species would bless me as its creator. Last edited by frankenfab; 07-16-2004 at 06:58 PM. |
I got the 20 ton HF model but I gotta fill and bleed the friggin pump every time I use it! I need to swap that thing out..
I don't know how I ever got by before without a press though! 5 ton? Are you pressing erasers into pencils or what? LOL
This Space for rent! |
#5 (permalink) | |
http://www.blackstar-racing.com/ |
#6 (permalink) | |
Member # 6291
[list][*][url="http://www.pirate4x4.com/forum/showthread.php?t=373488"][COLOR=lime]For sale: Ford D60 parts, D44 steering arms, etc ... [/COLOR] [/url] [/list] |
#7 (permalink) | ||
Member # 5380
Thanks for the imput guys. I really don't know what was in my head when I was typing 5 tons Brandon. :imaretard:
Member # 12499
So far, the only thing I have not been able to separate with my 12 ton was a sliding joint in a driveshaft
go figure, I bend mine up trying to separate something that is supposed to move smoothly.Even for suspension bushings where the mfgr states 20 tons in necessary, the 12 works just fine. Being something of a safety nerd (both from pastprofession and more importantly from hurting myself), I have a whole range of tools for use with the press, instead of using sockets. Keeps parts from flying out of the press as well as not mangling my sockets. I have a hole in the drywall in the shop from a trailing arm that came out of the press. They can be real dangerous (as can many tools).
Member # 23262
I have a 30t H frame that I built myself. I built the frame to handle a 50t ram so that any future upgrades could be added.
Gus
The ultimate result of shielding men from the effects of folly is to fill the world with fools. --Herbert Spencer, English Philosopher (1820-1903) |
Member # 6398
I've been seriously considering the 50T unit from Harbor Freight. Been eyeing it for a long time, and in a recent catalog it came down from $800 to $700. Someone once started a thread about this press, but no one had actually used it..........most replies were either people who had the 20T HF unit, or people just making blanket statements to avoid Harbor Freight altogether.
I've found it's difficult to find places to buy presses aside from Northern and Harbor Freight. I have no local suppliers and an auction is just not possible around here. The 40T Arcan is $600 plus $200 shipping from Northern, or I can get the HF unit for $700 and free shipping. I'm definitely leaning toward the latter, I'd have to think it will work fine in a "shadetree" shop
"Take 300 people and on average 290 of them just generally suck at life" |
Member # 24273
Just purchased a 12 ton from Harbor Freight. Came in 3 boxes.
While the associate was taking the boxes from the warehouse, I noticed one box said 20 Ton. The associate explained that some of the pieces were the same from the 12 ton to the 20 ton. I asked her to check again. She looked at her little sheet of paper, and assured me that it was correct. When I got home (3 hour drive later), I found that the pieces were definately not interchangable.
gunracer1- You must have the reading comprehension of a first graded |
#12 (permalink) |
Member # 11745
Does anyone use a press that has a guage as to how much pressure is being applied?
I have seen them around but you don't see them on the presses that use the "bottle jack" style jack.
Later, Ken 1 Mercedes Benz Unimog 404s |
#13 (permalink) |
Member # 30115
i got a 50 ton i got from a shop going out of business, 50 bucks, better than any hf, i'm makeing a press brake for it, going to try to make a tubing bender with it, the only problem is if it can't move it it will explode it, so i got a peice of 12inch round peice of steel pipe to put around things when i'm pressing, mainly bearings, saved my ass many times
#14 (permalink) | |
Member # 23262
Gus
#15 (permalink) |
Super Moderator
it's the 12 ton HF one like a ton of other people have, but with the 20 ton jack in it. Yes, it is sloppy, and I still need to square everything up and weld it together and try to shim some of the slop out of it for good.
>David > 4x4Spot.com >It only hurts the first time you agree with me... >"A little nonsense now and then is cherished by the wisest men." |
#16 (permalink) | |
Member # 15689
i've used the one in the first pic and it was sloppy as hell and the bar bends real easily. i ended up buying the same one in the second pic for like 100 bucks when it went on sale once. it is way better than the first one and tight. i would recomend it for the money.
not bad for home grown it's a little more than that sonny |
#17 (permalink) |
Member # 6726
12 ton HF. Does what I need. Rebuilt my W56 using it and it will press wheel bearings off the shaft if you get creative.
Fram is sloppy and I am going to sleve the top where it bolts together and put a cross brace on ti with some scrap to keep it square.
[COLOR="Black"]Did you expect to find something deep and meaningful here?[/COLOR] "He has all the virtues I dislike and none of the vices I admire." -- Winston Churchill |
#20 (permalink) | |
Super Moderator
#21 (permalink) |
I have a 20T unit from Homier, the traveling tool Gypsies.
$100. No freight. Unlike the HF unit, it's black. ![]() Can't say I've done much with it.. finally put it together last week.. made shock bushings a breeze.. LOL. update: pics ![]() ![]() .
-Tom KE7VUX Last edited by tsm1mt; 07-26-2004 at 01:36 PM. |
#22 (permalink) |
Member # 28084
How much could it cost to build something similair to the HF models posted?
Buy a big bottle jack, abunch of C-channel and square tubing, a few garage sprins for return springs. Build your own and paint it whatever color you want. Unless you're a hack it should turn out better than the HF stuff that others have said needs some "tweaking" anyway. So has anybody built ther own, other than the one that requires a lathe posted above? |
#23 (permalink) |
Member # 3574
I'm using this one :
Amrox 20 ton, bought it at the local J&L picked it up for $50.00 because the table was 1/4" out of square.
><((((º>`·.¸¸.·´¯`·.¸.·´¯`·...¸><((((º> `·.¸.·´¯`·...¸><((((º>`·.¸¸.·´¯`·.¸.·´¯`·...¸><((((º> ><((((º>¸.·´¯`·.¸.·´¯`·...¸><((((º> `·.¸¸.·´><((((º>`·.¸¸.·´¯`·.¸.·´¯`·...¸><((((º> |
#24 (permalink) | |
Member # 6398
But yes, several on the board have built their own. There were a couple private individuals as well as Scott@Rockstomper and Steve G?erstner? with ? custom? diffs? or something. My memory fails me. There have been a couple of threads in Gen4x4, search 'em out (I'm too lazy right now) and maybe Camo will move them over here. But basically I've just seen pics of a couple of custom ones, dimensions and instructions would be nice (even tho it seems simple), also would help to calc ultimate cost if we had dimensions. If you're talking bigger, like 40T+, you might be able to build your own for less. But I'd nearly bet there's no way you could build an equivalent of the Harbor Freight 20T unit for the $170 that it regularly goes on sale for.
#25 (permalink) | |
Member # 28828
The hardest part would be getting the holes in the side of the C channel the same on both sides. I have several different ideas of ways around this but nothing down on paper yet. Also if I were to build my own I would probably get a ram from surpluscenter.com and either use a hand pump or rig up a 120v pump.
One of the biggest drawbacks of the HF press that I used to own was the opening on the press table. I always had something that was a little bigger than the opening, forcing me to stack blocks of whatever was handy to hold up my workpeices. I can see where if you built your own you could work around their design. However that being said I think that scoring one or two of their 12 ton presses and engineering them into one might be a way to go. At least their steel is inexpensive and the holes in the channel are already punched. dc Quote:
