Wood to Metal Bandsaw Conversion? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-22-2004, 07:40 AM   #1 (permalink)
Member # 5960
Send a message via Yahoo to LAME
Neighbor got pissed off at his bandsaw last night and asked if I wanted to "get the goddamn fucking thing outta here".
It's a Grizzly, 3/4hp, 14" with a 93" blade.
Besides finding a metal blade that fits, how much am I gonna have to slow it down? Is there anything else that I have to change?
crawl4cure.org
Rock Rash Racing #613, Trail Tampon Spotter
LAME is offline   Reply With Quote
Old 07-22-2004, 08:58 AM   #2 (permalink)
Member # 6291
A friend of mine just did this to an upright bandsaw he was given. He put in a jackshaft and another set of pulleys to slow it down since all his had was a single belt. Does yours have just one belt ?
[list][*][url="http://www.pirate4x4.com/forum/showthread.php?t=373488"][COLOR=lime]For sale: Ford D60 parts, D44 steering arms, etc ... [/COLOR] [/url] [/list]
morpheus is offline   Reply With Quote
Old 07-22-2004, 09:46 AM   #3 (permalink)
Member # 5960
Yep, single belt. Motor pulley is about 2" dia, and the saw pulley is about 6" dai.
crawl4cure.org
Old 07-22-2004, 10:10 AM   #4 (permalink)
redrangie's Avatar
Member # 11072
check grainger.com for a different pulley?
forgings design dot com
metal furniture | fabrication | decor
new | rustic | recycled
redrangie is offline   Reply With Quote
Old 07-22-2004, 11:29 AM   #5 (permalink)
fj40guy's Avatar
Member # 9576
Lame,
Grab that sucker!
You'll need a jackshaft to bring the speed down. Typically wood blades are running around 800 fps (feet per second), and you want to bring that down to around 100 fps (50 is good for 1" thick plates!).
If you need to cut something like 1/4" Aluminum... uh, you can do with with a 6 tooth wood blade and some patience. Damn noisy, but gets the job done.
Tom
EDIT: My numbers are WRONG! 3300 fps (55 FPM) for wood. 120 fps (2 FPM) for metal. Darn, hate doing that.
fj40guy is offline   Reply With Quote
Old 07-22-2004, 11:46 AM   #6 (permalink)
Member # 22721
Send a message via MSN to TheRipper Send a message via Yahoo to TheRipper
Was looking in my Grizzly catalog and they have the same blade size for metal also.One question what is a jack shaft?Maybe I know it by something else..lol
[SIZE="5"][COLOR="Blue"]www.rockjunkie.net[/COLOR][/SIZE]
[URL="http://www.crackslinger.com/login.php"]http://www.crackslinger.com/login.php[/URL]
[URL=http://www.pirate4x4.com/forum/showthread.php?t=313836]Link's to rockwell question's and info...[/URL]
[URL="http://www.ouversonengineering.com/"][SIZE="5"]http://www.ouversonengineering.com/[/SIZE][/URL]
TheRipper is offline   Reply With Quote
Old 07-22-2004, 11:50 AM   #7 (permalink)
Member # 5960
Originally Posted by fj40guy
Lame,
Grab that sucker!
Tom
Its in my garage, next to the box, already
ENCO lists a Bi-Metal blade with 10/14tpi, that is 3/4" wide.
The fps is exactly what I was looking for. I'll have to stop by grainger one of these days after work
crawl4cure.org
Old 07-22-2004, 12:34 PM   #8 (permalink)
Member # 6291
simply changing pulleys won't likely get it down slow enough. you'll have to add a jackshaft with another pulley on it.
if this is the model that you have:
http://www.grizzly.com/products/item...emnumber=G1019
then if you look at the pdf manual you see a pic of how to align the pulleys.
you'll need to add shaft and another set of pulleys under their somewhere to get it down slow enough.
Old 07-22-2004, 01:06 PM   #9 (permalink)
fj40guy's Avatar
Member # 9576
Lame -- looked at the speed numbers again. DOH!
That wood band saw is rated at 3300 FPM... about 55 fps.
The metal saws are running around 120 FPM. About 2 fps.
Come to think of my saw hitting the splice it runs about that
(I hear the splice go past the guides every few seconds).
Sorry about that. Still aim for a ratio of roughly 20:1 speed
reduction. Should get you in the ball park..... A friend converted
an old big iron wood saw for metal cutting, and I'm thinking we used
around a 10:1 speed reduction.... but might have been a slow turning
wood saw to start with!
I lucked out one day with "scrap machinery" in a metal scrap yard.
They had a 40:1 gear reduction unit inside an old "ticket booth arm".
Used it for a "tire tumbler" (toss metal part in with tumbling media inside
the tire, it sits on a couple of rollers and just keeps rotating to deburr
& polish the metal parts.).
Tom
Old 07-22-2004, 01:14 PM   #10 (permalink)
Member # 5960
Tom
I was just thinking "WTF" what's the right number
I'm gonna measure up the up the pulleys tonight, and see where I can jam a jackshaft in the rig.
crawl4cure.org
Old 07-28-2004, 11:57 AM   #11 (permalink)
Member # 9386
Send a message via Yahoo to zukikid
see if you cant find a lower rpm motor...they can somtimes be found cheap.
zukikid
"life is not convenient"
[QUOTE][i]Originally posted by littlejackass [/i]
[B]aaaahh come awn care bears rock! :D [/B][/QUOTE]
zukikid is offline   Reply With Quote
Old 07-28-2004, 10:17 PM   #12 (permalink)
Member # 10736
what jobs would a converted vertical bandsaw be able to handle.
masonmachines is offline   Reply With Quote
