Question Regarding Pigs Dimple Dies - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-22-2004, 03:44 PM   #1 (permalink)
Member # 2107
I've Been Checking Out The Threads In Search, And Was Curious, With The Dies Pig Offers Do You Have To Use A Hole Saw To Pre Drill The Material?
Because I Have Seen And Used Some On Sheet Metal That All You Needed Was A Small Pilot, And It Cut And Dimpled The Material All In One Shot.
Is There Any Specific Benifit To One Style Over The Other?
It Seems Eaiser And More Precise To Me To Use The Second One Mentioned, All Less Consumables, Burning Up Hole Saws?
Thanks
Wheeling Addict!!! Must finish truck before I start having convulsions! <A HREF="http://members3.clubphoto.com/jeff265526/
" TARGET=_blank>http://members3.clubphoto.com/jeff265526/
</A>
90 toy fully caged, fiberglassed, long travel suspension, 33/12.50s, 5:29, detroit locker, widened front suspension 6", 350, th350 tranny, rad. in bed, dual spares
toyotabajaracer is offline   Reply With Quote
Old 07-22-2004, 03:51 PM   #2 (permalink)
Member # 2413
you have to cut a hole first with pigs
TINBENDERS.ORG
Aaronn is offline   Reply With Quote
Old 07-29-2004, 08:06 AM   #3 (permalink)
Azrckcrawler's Avatar
Member # 3550
Anybody tried to dimple 3/16 steel with these? If so what did you use for teh press?
[URL="http://www.azrockcrawler.com/_images/btgdvd/btgvol4dvd/btgvol4dvd.html"]Built to Grind 4 DVD - 2 Hours of Arizona and NM Rockcrawling
[/URL]
Chassis Plans for the Do-It-Yourselfer
[URL="http://www.azrockcrawler.com"]www.azrockcrawler.com[/URL]
BTG Rockcrawlers
Azrckcrawler is offline   Reply With Quote
Old 07-30-2004, 03:53 PM   #4 (permalink)
GOAT1's Avatar
Member # 5969
most of the dimple dies that punch are only made for thinner gage material, probably thinner than most people use around here.
I dont dimple die any thing over 1/8, it is hard to do and just doesnt work well, it really distorts the entire plate.
GOAT1 is offline   Reply With Quote
Old 07-30-2004, 09:27 PM   #5 (permalink)
Member # 15646
Thanks
What's With The Caps?
They do make dies that cut the hole in heavier sheet/ light plate for use with iron workers and such. I've never used them-just seen them advertised. I remember seeing that pirhana made them specifically for their machines. Surely sombody would make some for use in a press. You will probably still have to drill a pilot hole.
Peter
ROCKSFORBRAINS is offline   Reply With Quote
Old 07-30-2004, 10:07 PM   #6 (permalink)
Member # 32492
Does anyone on this site make thier own dimple dies? I am very interested in buying some but I am limited on cash.
Cannon Motorsports is offline   Reply With Quote
Old 07-31-2004, 12:21 AM   #7 (permalink)
braxton357's Avatar
Member # 14685
Send a message via AIM to braxton357
d.d. machine ...does some cool stuff, check teh vendors section.
In vino veritas
70 turbocharged 351w fastback mustang
73 linked 5.8efi Bronco
99 QCLB 4x4 twin'd cummins on meth.
braxton357 is offline   Reply With Quote
Old 08-02-2004, 10:39 PM   #8 (permalink)
Member # 14762
I made my own. Takes a little bit of math to figure out what the void needs to be between the male and female dies but for the most part, anyone with a lathe could make a set. If you had the correct tooling you could probably make a set on a mill too.
The dimple part of the die is basically a 45* chamfer (but you could make yours custom if you'd like) and the rest falls under simple lathe operations.
I'd bet someone could come up with a way to build some poor-man dies with common hardware store parts...finding the 45* part would be the challenge but with a welder you could almost use simple tubing for the rest.
lilscorpion is offline   Reply With Quote
