Member # 15697
Miter Saw capable of wood AND metal?
I'm looking for a good miter saw for around the house stuff.. and I want to use it for all the stuff w/ my rig too. The DW Multicutter seemed cool, but it looks like its perfect for metal and metal only. Whats the best saw for wood and metal? I don't mind spending a bit more for a good one cause its replacing two tools.
Thanks guys! Dave
Wait, what? |
#3 (permalink) | |
Member # 15697
Wait, what? |
Member # 11978
lol you would be better off buying the Dewalt multi cutter and then put a wood blade on and be patient. Hell you would not even really need to change the blade.
"Fear The Wrench" |
#5 (permalink) | |
Member # 15697
Wait, what? |
Member # 28084
I've got a Craftsman compound miter saw that I got when I remodeled my mom's kitchen for her 1 year on x-mas break. It rarely got used for wood and was just collecting dust while I went through cutoff wheels for my 4.5" grinder. Finally I just said screw it and bought a cutoff blade for a chopsaw and put it on the miter saw. It works, just make sure to remove the dust collection bag first. A polyester bag full of sawdust flames up real good when you start hitting it with sparks.
#7 (permalink) | |
Member # 15697
Bravo! That woulda been a darwin award for sure man ![]() So I guess either one is capable of the other, but is one designed to do both? Guess I'm asking for too much?
Wait, what? |
#8 (permalink) | |
Member # 347
* The metal can do the wood work, when fitted with the right blade, but the RPMs are wrong. * The wood can do the metal work, when fitted with an abrasive blade, but the RPMs are wrong, and I'd expect to dramatically shorten the life of the wood saw. I've used different-sized metal abrasive wheels and wood blades to dink with the cutting speed at the kerf, and have a Harbor Freight Chicago Electric miter saw that is pulling dual duty. It had kinda spotty alignment out of the box, when cutting hard cross-grain in wood... no surprise that cutting angles in metal hs resulted in even worse angle-holding capability. All the plastic on the saw is at least pock-marked from spraying hot-metal, and in some case has melted and burned. This sort of use beats the hell out of the tool, luckily it was a harbor freight cheapy. It is minimally acceptable for rough cuts, but expect to get metal in your wood (that's rust, folks) and wood in your metal (sawdust flares up when you weld). If you have space for only one tool, are willing to shorten that tool's life, AND don't need precision, this can be made to work -- but you need realistic expectations, going in. Randii |
#9 (permalink) | |
Member # 15697
So if anything, a metal one with a wood blade would be the best? I'd hate to buy two, just seems so silly since they're almost the same thing!
Wait, what? |
#13 (permalink) |
Member # 15697
totally! I think I am going to go with the DW multi cutter cause its an awesome metal cutter and it should do OK at metal if I change blades and go nice and slow (about a third the speed, seeing as the RPM is 1/3)If anyone has a better idea I'm open, let me know ![]() Dave
Wait, what? |
#14 (permalink) |
Member # 15697
Well, went to Home Depot today and we were there for over 2 hours
I was good and got a drill We saw a nice table saw for 50$, so we're considering getting a table saw and the DW multicutter... Table saw probably first, I can do a lot with just it, truck is sorta on indefinet hold right now anyway
Wait, what? |
#15 (permalink) |
fishingwithdynamite
Member # 30721
Anything new? I've seen DeWalt's multi-cutter, and Evolution's Rage 3. I'm building a small (10ft) enclosed trailer that's going to serve as sort of a mobile workshop, so space is VERY limited. I'm looking for something that's more adjustable than a standard chop-saw, and I need to be able to cut metal and wood with it.
#17 (permalink) |
Member # 6398
Uh huh. The first one's cordless and claims non-ferrous only.
The second one looks more like a cold saw, but also claims non-ferrous only.........but says it can accept abrasive blades..............albeit 12" which is kind of a bummer Were you able to get a price on the second one? And I'm really confused 'cause isn't C.R. Lawrence the place that makes aftermarket windows/sliders/sunroofs for the automotive industry? This place claims to be C.R. Laurance.
"Take 300 people and on average 290 of them just generally suck at life" |
#18 (permalink) |
fishingwithdynamite
Member # 30721
Jeez, I didn't even notice that the first one was cordless. Just saw that it uses a Bosch motor. I did see that both of them are only approved for non-ferrous metals, but I figured maybe that's a little better than wood-only compound miter-saws? At least they had some type of metal in mind when they designed those. Why ISN'T there a saw like this on the market? I don't get it.
#19 (permalink) |
What about a band saw? loses the versatility on the wood, still cuts great, cuts the hell out of steel. The cost can be close to a grand but if you are going to cut lots of steel and some wood, it might be worth it.
[QUOTE=Action Fab;13102972]Thats Rohypnol your thinking of... :flipoff2:[/QUOTE] |
#20 (permalink) | |
Member # 6398
I had also thought about the bandsaw thing. Have you considered if there's any possible way to make a small miter bandsaw like these fit? http://www.pirate4x4.com/forum/showp...9&postcount=15 I wonder if you could have it store up against the wall and then swing out 90 degrees when you want to use it such that the stock feeds thru the saw and toward the front of the trailer?? It would take some engineering but it could be trick..........maybe.
#21 (permalink) |
fishingwithdynamite
Member # 30721
Yeah, the Evo Rage 3 might fit the bill. Just want to find out what my options are so I can make an informed decision. I've already got a porta-band (like this one, but's the older V28 model). No room for anything bigger, but I'm going to try to come up with some kind of way to mount that in a vise so I can use it standing upright like a vertical bandsaw. No room for anything bigger, unfortunately.
#22 (permalink) | |
Member # 87941
I won't say it's ideal (I really want a cold saw) but it works. Last edited by DILYSI Dave; 07-21-2010 at 09:22 PM. |
#23 (permalink) |
Everyday Wheeler
Member # 83086
You can make things out of materials other than steel.
What a concept But really get a good metal cutting saw and a CL special for wood. Wood saws are cheap on CL. Why fight trying to make a tool do a job it wasn't made for. Wheel And I'm still not impressed enough with the metal cutting saws to justify the expense. I prefer a bandsaw.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself? |
#24 (permalink) |
Paris Hilton Fan
Member # 11249
http://www.bii1.com/saws/manual-coldsaw-225m.php
This is shown as $695 on the Baileigh site and it is exactly what I'm buying once I get the extra cash. It has all the features I need to cut metal and what It will not cut, I can cut with my Bandsaw. See, I have a roller table under my tube rack. I need a miter type saw so that I can simply grab the tube from the rack, drop it on the table and cut my angle while it rests on the roller table. My Bandsaw will not do this for me since it is a cheapo 4x6 type. The CS-225M will do what I need to cut 1-3/4" and 1-5/8" tube up to 45° angle, quickly. If the tube needs more angle, I can throw it in the bandsaw that Im going to modify with a rotary table and get angles up to 60°. But, hopefully the piece will be much more manageable at this point and not 20' long! At 50 rpm, it will prolly not cut wood though, so Im a dork for not looking at that prior to posting.
Read what I've learned about the Baileigh Industrial TN-250 I won here on Pirate4x4! http://www.pirate4x4.com/forum/showt...=tn+250+review Last edited by MudzerK5; 07-22-2010 at 07:49 AM. |
#25 (permalink) |
Member # 17313
Ive been using a delta miter saw with an abrasive wheel in it all summer.. thickest ive done so far is 3/8's, but even cutting that, it ripped right through with no issues..
way faster/more power than the milwaukee chop saw our club has..
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion. |
