Looking for a decent band saw - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-27-2004, 07:57 PM   #1 (permalink)
Member # 14644
I cut alot of tubing, and thinner plate-3/16-1/2"...but for most of the thicker junk, I'll just pull out the torch and clean up with a grinder. I have found a JET bandsaw at my local welder shop and it's about $298. It's the smaller version, non-coolant. Is it worth it? I don't think I need the coolant systems as I don't do much thicker material. What about a grizzly? http://www.grizzly.com/products/item...emNumber=G1010
What do you think?
Greg
1986.5 Nissan crawler - dual cases, one tons, 42's...
2003 SV650
1997 F350 DRW PSD
bignissan is offline   Reply With Quote
Old 07-27-2004, 08:04 PM   #2 (permalink)
Member # 14644
http://www.grizzly.com/products/item...emNumber=G9742
2003 SV650
1997 F350 DRW PSD
Old 07-27-2004, 08:37 PM   #3 (permalink)
Member # 29644
Send a message via AIM to 71Dauntless
I picked up the HF 4x6 saw about 2 months ago for $149. It usually goes on sale for 169 so I decided to get it when it dropped down. It is damn near the same saw as the first Grizzly you posted. The JET 4x6 is the same as well.
I think that JET and Grizzly use cast blade guides, while some say the HF are stamped sheet. My HF has CAST guides, so I guess it varies. With a new blade and a little adjustment it has been a great saw thus far.
1971 CJ5
2006 Toyota Tundra
71Dauntless is offline   Reply With Quote
Old 07-27-2004, 10:42 PM   #4 (permalink)
Member # 19652
Send a message via AIM to socalchef
the same model (in yoru first post) is on sale at HF right now for $150. i got mine at that price, and i like it. it has cast blade guides as well. same color as the one in the pic. northern tool has a red/black one for like $250 or 300, and then there's a white jet one.check northern tool. they have a wide selection and the EZpay option too...splits the cost into 6 monthly charges to your card of choice.
socalchef is offline   Reply With Quote
Old 07-28-2004, 12:34 AM   #5 (permalink)
Member # 14644
I've seen the ones in Northern tool. So the HF ones are decent with a new blade and cast guides? I might just drop the $150 on one of those and call it good. I don't need anything incredibly accurate, just cleaner than the dang abrasive saw...
Grg
2003 SV650
1997 F350 DRW PSD
Old 07-28-2004, 04:37 AM   #6 (permalink)
Banned
Member # 6323
Send a message via ICQ to rsitzejr Send a message via AIM to rsitzejr
I've got this one, http://www.grizzly.com/products/item...emNumber=G9742
I love it, great being able to control the speed with Hydraulics
rsitzejr is offline   Reply With Quote
Old 08-12-2004, 07:23 AM   #7 (permalink)
Member # 8228
Send a message via AIM to broncorob
I know this thread is old, but oh well.
I don't really see the point in the horizontal band saws. I guess if you're making straight cuts all day long then its fine, but I used my buddies vertical band saw for awhile and fell in love. You're able to do straight cuts if you want, but you can also do cut curves and stuff to make cool parts.
Rob Ellis
broncorob is offline   Reply With Quote
Old 08-12-2004, 07:52 AM   #8 (permalink)
chumly2071's Avatar
Member # 8293
Send a message via AIM to chumly2071 Send a message via Yahoo to chumly2071
My HF is one of my most used fab tools. I use it constantly for cutting tube to length for fab work. now, like you said, I use my vertical for curves etc....
I'm an Engineer. Why leave it alone, when I can REALLY screw it up?
There is no mechanical problem so difficult that it can't be solved by brute strength and ignorance.
chumly2071 is offline   Reply With Quote
Old 08-12-2004, 08:42 AM   #9 (permalink)
fj40guy's Avatar
Member # 9576
Also on the HF band saw, I can lock it in the "upright" position and there is a small table attachment. 6" x 6" or so. No, not a real tool, but when I needed to cut some curves in a 1/4" aluminum plate did the trick fairly well. Occasion use, it works.
Side note on the HF unit... OPEN UP THAT GEAR BOX! I noticed mine was running hot. Opened it up and found DRY gears witha bunch of metal swarf in there. Cleaned it up, filled 1/2 with 90 gear oil. RTV on the "lid". Seals held, no oil leaks. It will last lots longer.
Tom
fj40guy is offline   Reply With Quote
