Worth it to rent a plasma cutter? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-01-2004, 04:00 PM   #1 (permalink)
Lucy's Driver's Avatar
Member # 5124
I'm in the process of cutting the cast frame end front track bar mount off my TJ. Its a big cast piece factory welded to the frame on two sides: bottom of the frame and the inner framerail. I've gotten through the welds under the frame with an angle grinder. It took many unpleasant hours to do this.
Now I have to get most of the inner section of the ear off. Because I need to have the frame underneath it mostly intact to weld on the mount I'm fabbing up and due to the tight confines the only tool I can get in there is the angle grinder and in such a way that I can't cut the welds: I can only grind the entire section down. This is about 1/2 to 3/4 of cast.
I've never used a plas before but I can get the mig welder in there easy enough, so I figure the head of the plas would fit.
Basically my question is this: would a pretty decent welder whose never used a plas before screw it all up and hack the frame?
Basically I'd need to cut the welds in such a way as to not cut the frame. I have plenty of scrap around the garage to practice on.
Sorry no pics, but if someone has a pic of the stock cast ear on a TJ, especially from the inner framerail view, please post.
"Your Jeep smells like a sweaty horse." 8/24/01, "Get me out please, I'm upside down, I smell gas." 9/29/01
Lucy's Driver is offline   Reply With Quote
Old 08-01-2004, 04:43 PM   #2 (permalink)
Member # 26833
Plasma is the way to go.Make sure you specify thickness you are cutting when you rent. My little 250 will only cut up to 5/16..Makes for a clean job.
82cj7 350 sm465 atlas soa D44s 101"wb 36's,
bla.bla.bla
NVCJ is offline   Reply With Quote
Old 08-02-2004, 06:24 AM   #3 (permalink)
Scramblah's Avatar
Member # 19566
Have you thought about using a plain old Acetylene torch to cut the weld? I used my torches to blast off a bunch of my welds on my CJ. Just as long as you keep the heat concetrated on the weld you should be able to do it without messing up the frame.
Scramblah is offline   Reply With Quote
Old 08-02-2004, 07:03 AM   #4 (permalink)
302YJ's Avatar
Member # 24652
Send a message via AIM to 302YJ
I agree, acetylene is probably just as good
Here, watch this...
302YJ is offline   Reply With Quote
Old 08-02-2004, 01:39 PM   #5 (permalink)
Member # 5124
Originally Posted by ryankopecki
Plasma is overrated. And yes I do have one, for cutting sheets into strips quickly. For most other things I still use a torch. A torch is a very valuable tool if you can use it good, other than cutting, it can also heat things and blow out welds. And then there's the air gouger, it hooks to an arc welder and air compressor and blows out welds faster than you could make them, that would probably be the best tool for the job you're doing. It actually does use plasma and it heats the work piece very little.
A buddy of mine is a breacher on a SWAT team. One of their cool breaching tools looks like an arc welder using very large sitcks. This device is hooked to a compressed gas tank (not sure what gas they use). This is used to burn quickly through metallic doors and also to get into safes. Is this an air gouger?
Second, does anyone know some place that would rent a torch or air gouger (or plas) in the northern NJ or eastern PA area? I've tried some searches and come up empty.
Old 08-02-2004, 02:19 PM   #6 (permalink)
D60
D60's Avatar
Member # 6398
What sort of "cast" are we talking about here?
I've tried to hack up a wheel bearing hub flange with my plasma (5/8" cast .... iron? I'm guessing?) and it took forever & made the ugliest cut you've ever seen. But I've cut 1/2" mild steel with it no problem. It's rated to cut 7/8" and sever 1.25"...............but cast is clearly different.
Bottom line, be sure the plasma will do what you want.
"Take 300 people and on average 290 of them just generally suck at life"
D60 is offline   Reply With Quote
Old 08-02-2004, 05:53 PM   #7 (permalink)
Member # 347
Nah, that's a Broco burning setup (Google). I got to burn a half-rod of this at a vendor show a while back... I cut up a scrap engine block like butter. Picture an exothermic cutting rod hooked to a pressurized 02 canister. Light it, fire it, and you can cut underwater, underground, you name it. No way they'd let you use it in a junkyard, but man would it make pulling parts a breeze.
Randii
Pack it *ALL* out... you pick up after your dog, so clean up after YOU, too.
- VIRTUAL RALLY for the HAMMER TRAILS in JOHNSON VALLEY Post 1349
- VIRTUAL RALLY for TELLICO Post 716 and Post 924
- KOH Pledge Drive: for 4405 KOH Pledge #4
randii is offline   Reply With Quote
Old 08-02-2004, 06:01 PM   #8 (permalink)
couchracing's Avatar
Member # 14020
Plaz is the way to go when gouging welds out. If you can turn the head to the side it's like a little Jedi lightsaber. You can typically rent the Force for about 40 bones a day. Remember, clean dry air, it's your friend.
To all the peeps out there in internet land, electrodes and tips last a long time. Just because it's called a consumable, doesn't mean you change it out every 1' of cut. Good luck with you quest, Grinding sucks. Scott.
89 Toy
couchracing is offline   Reply With Quote
Old 08-03-2004, 06:34 AM   #9 (permalink)
Member # 13069
I'd opt for the cutting torch myself. Mainly because I think its easier to control . I have cut off mounts with my plasma cutter and it seemed the consumables got eaten up quicker. If you even 'blink or sneeze' while using the plasma cutter it is going to cut whatever gets in its way in half a heartbeat. For me, in these situations, the light plasma torch can get me into trouble. By the time I let go of the little button I have a hole or 1" cut where I didn't need one.
Just-fabricate-it is offline   Reply With Quote
Old 08-03-2004, 07:40 AM   #10 (permalink)
Member # 2058
Send a message via ICQ to Foxfab Send a message via AIM to Foxfab Send a message via Yahoo to Foxfab
I have both and I'm in Central CT if ya wanna drive
Undoing years of Toyota engineering one SAS at a time!!
2007 Yaris--1959 FJ25--www.yankeetoys.org
Foxfab is offline   Reply With Quote
Old 08-03-2004, 05:35 PM   #11 (permalink)
Member # 24273
I am totally confused by this comment. I feel I have a lot more control with the plasma cutter than a torch. With an plasma cutter, it's just "point and shoot". With the torch, is it constantly lit, so you have an open flame to worry about while crawling under and around a vehicle. Plus, with a plasma cutter, the heat affected zone is far smaller than a torch.
If you are having trouble with the torch slicing through things too quickly, can't you just turn it down? I thought all of the larger plasma cutters were adjustable.
gunracer1- You must have the reading comprehension of a first graded
jerseyzuks is offline   Reply With Quote
Old 08-04-2004, 09:14 AM   #12 (permalink)
Member # 13069
The reason I like the torch for cutting some things off is that (at least for me) is that once I get the plasma cutter cutting and moving around I tend to forget to let go of the switch some times and it just keeps on its merry way cutting away Yeah, I know, dumb operator. The cutting torch make me think a little more and yes its harder to get into those tight spots.
My experience with the plasma is I have a hard time controlling cutting something big/bulky off of a thinner piece without accidently slicing the thinner piece. With the torch I can sort of watch it happen at a slower pace.
I probably need more experience with the plasma but I have more experience torching things off so thats what I go with in certain cases. I tend to use up the plasma consumables fast when I'm 'butchering' things off.
Old 08-04-2004, 09:18 AM   #13 (permalink)
Member # 17324
there is absolutly no HAZ w/ a torch built in pre,during & post heat.
your just a brokeback slider wantin to join Al Kaider
whthilux is offline   Reply With Quote
