Member # 33779
Punching Holes into Pipe
I'm attempting to make an exhaust baffle. I need to punch many square pencil-sized holes into one inch pipe. The holes cannot be drilled as the punched inner notches act to retrict exhaust flow. Anyone have any ideas as to what I can use to make the punches?
Thanks! |
IH/Rover Moderator
Why not drill and just clean up with a die grinder?
I like beer. On occasion, I will even drink beer to celebrate a major event such as the fall of communism or the fact that the refrigerator is still working." BUY MY BOAT http://www.pirate4x4.com/forum/misc-...e-history.html |
#3 (permalink) | |
Member # 33779
Oldscout
The punch creates a notch in the inner part of the pipe. These notches act to further baffle the exhaust & create the sound I am looking for. Thanks Jim Quote:
Member # 9576
Hammer driven nailer! (Type that is loaded with the 22 explosives).
On a more serious note... all I can think of is a "four sided" punch. Top of it looks like a praymid. What a pain, punch... hammer... wiggle punch out... punch... hammer... I'd go nuts (and spend $60 for a decent muffler). What about taking a FLAT SHEET OF METAL? Punch over a piece of wood. Once done, roll the sheet and weld the seam. It would go quicker, thinner sheet metal could be used for the punch operation (easier to do). Why are you making your own muffler? (Oh, I did have a sports car that could only use mufflers 9" long (it fit between the "X" in a frame... pain in the rear to find a muffler that size with any flow). Discovered the easiest way to quiet the exhaust down was to bolt on a turbo with a 18" straight pipe (noise wasn't bad at all!) Tom
#5 (permalink) | |
Member # 33779
fj40juy
Thanks, some good ideas - even the one about the nailer - maybe using it as an impact punch. The reason I'm using this instead of a muffler is that it will save about 60lbs (2 mufflers) plus the exhaust will sound better hopfully. Anyone know of a cheap punch press that might do the job? Thanks Quote:
#6 (permalink) | |
Member # 19763
The site for the fabricator: [URL="http://www.offroadfabnet.com/index.php"]www.offroadfabnet.com[/URL] [COLOR="Orange"]Bend-Tech [URL="http://www.2020softwaresolutions.com/bt_pro.htm"]PRO[/URL] is now available!!![/COLOR] Design full tube [URL="http://www.2020softwaresolutions.com/web_images/Racer-X_5[1].jpg"][U]chassis[/U] [/URL]in less than a couple of hours with the PRO [COLOR=Cyan]We are the developers of the Bend-Tech products. [COLOR="Yellow"]651-257-8715[/COLOR] for sales and support[/COLOR] [URL=http://www.2020ssi.com]www.bend-tech.com[/URL] [COLOR="Cyan"]10,000+[/COLOR] now using Bend-Tech |
