will it blow? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-05-2004, 10:18 PM   #1 (permalink)
BLINGN's Avatar
Member # 26761
will it blow?
I use my aircompressor once a week or a little on big projects and do not drain it often. Has anyone ever really seen one of these blow up, from rusting or what not? If so what should I do to get the rust crap out? thanks
make your rig do its job
BLINGN is offline   Reply With Quote
Old 08-05-2004, 10:30 PM   #2 (permalink)
Member # 31347
Send a message via MSN to Junk Driver
RUN LIKE THE DEVIL!!
no its ok. I drain mine, 80 Gallon tank every 6 months or so. There should be a drain on the bottom, take that piece to Home Depot or whatever, figure out how to get it to do a 90 degree bend to a valve you can turn on/off. Make sure you point this out the door if you can. With some compressed air still in the tank, not max or even 20% I can shoot the accumilated water 25 feet clear across my shop.
Junk Driver is offline   Reply With Quote
Old 08-05-2004, 10:31 PM   #3 (permalink)
Member # 6957
dont think they will explode in a catstrophic way from rust would think the rusted area would "break" and be like a nail in a tire
ironpig70 is offline   Reply With Quote
Old 08-06-2004, 08:32 AM   #4 (permalink)
Member # 14644
yeah, my tank just rusted through on a compressor I got from my grandfather...worked fine one day, then after that, just had a leak in it.
1986.5 Nissan crawler - dual cases, one tons, 42's...
2003 SV650
1997 F350 DRW PSD
bignissan is offline   Reply With Quote
Old 08-06-2004, 09:12 AM   #5 (permalink)
fj40guy's Avatar
Member # 9576
[QUOTE=I drain mine, 80 Gallon tank every 6 months or so. [/QUOTE]
Every SIX MONTHS? I need to drain mine a few times a day when it is humid. Large puddle of water when I drain. Usually just open the valve at night and let it air down (small compressor, doesn't take long to air up).
Tom
fj40guy is offline   Reply With Quote
Old 08-06-2004, 11:11 AM   #6 (permalink)
Member # 31347
Calgary Alberta...... Definitely not known for humidity, actually pretty dry. I admit I probably should do it more often.
Old 08-06-2004, 05:55 PM   #7 (permalink)
sothpaw's Avatar
Member # 9279
Send a message via AIM to sothpaw
http://www.irgaragesolutions.com/drain_valves.asp[/URL]
Retails for like 200.00. Got mine on ebay for 40.00. Never have to think about it any more.
______
SI VIS PACEM PARABELLUM
FJ40john: WTF are you talking about man?? You need a disclaimer at the top of this that says "If you are a pale friendless virgin (male or female), who likes (insert whatever the hell you were rambling about here), please read on...everyone else, please disregard."
sothpaw is offline   Reply With Quote
Old 08-07-2004, 07:55 AM   #8 (permalink)
Member # 24273
Hey, that auto drain is pretty sweet. When I install a big shop compressor, I think I'll get one of those. Thanks for the link.
gunracer1- You must have the reading comprehension of a first graded
jerseyzuks is offline   Reply With Quote
Old 08-07-2004, 08:30 AM   #9 (permalink)
KLF
Member # 3910
I've seen a couple rust out, they don't blow up, just start leaking out a rust hole in the bottom.
I try to drain mine after every use (Porter-Cable 60 gal vert tank). But I've always wondered if I should let it drain all the way down to 0, or just pop the bleeder open for a minute to blow out the water that's sitting in the bottom of the tank? The instructions that came with the compressor don't say.
'87 Toyota xcab SR5 - SAS'd, stuff
'05 Lexus ES330 - babe magnet
KLF is offline   Reply With Quote
Old 08-08-2004, 08:05 AM   #10 (permalink)
Member # 13069
I recently cut apart a 80 gallon vertical air tank that had been in daily use in a car dealership for about 14 years. I don't know what their maintenance schedule was but when I got it I drained about a gallon of oil/water chocolate mixture. When I cut it open it had all kinds of sludge and rust particles in it. About a good shoebox sized amount in the bottom and another like amount clinging to the top and sides. There was no way that would have gone out the drain. That stuff was nasty. Scraped it out with a putty knife. Reminded me of a rusted mass of thin sheetmetal mixed with oil sludge. Even with all that the tank was in good shape. The two domes were slightly pitted but the walls of the tank were still very smooth. The tank was about 3/16"-1/4" thick material.
I have a 35 year old 20 gallon sears tank that is still going strong. Drain it whenever I think about it (probably once a year). Don't use it much though.
Just-fabricate-it is offline   Reply With Quote
