the best way of fastening to cinder block walls? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-21-2004, 04:46 PM   #1 (permalink)
Member # 18131
I am working on getting my new garage/shop set up and am looking to attach some 2x3s to the walls for shelves, pegboard and whatever else I come up with. The walls are made of concrete cinder block and I am not really familiar with fasteners for it. What is the best method of attaching the 2x3s? construction adhesive? concrete screws? toggle bolts? Any other suggestions? I don't think they should have to support that much weight but I don't want them to fall off the wall or pull out either. It looks like someone had used some big nails to fasten 1x2s for hanging tools at one point but they have mostly pulled out of the holes.
dharmabum is offline   Reply With Quote Quick reply to this message
Old 09-21-2004, 05:45 PM   #2 (permalink)
Member # 2967
Tapcons.
Everyone said there would be bad days, I just never figured there would be this many.
Toyota_Jim is offline   Reply With Quote Quick reply to this message
Old 09-21-2004, 06:05 PM   #3 (permalink)
Member # 17517
Send a message via AIM to Bmf24 Send a message via MSN to Bmf24 Send a message via Yahoo to Bmf24
Originally Posted by Toyota_Jim
Tapcons.
exactly. buy the little kit and you will be not be dissapointed
A guy with no rig anymore.
Bmf24 is offline   Reply With Quote Quick reply to this message
Old 09-21-2004, 08:00 PM   #4 (permalink)
78bronco460's Avatar
Member # 9152
I drill all the way through the block and run 1/2" threaded rods through the holes with fender washers and nuts on both sides. They never come out.
A sword never kills anybody; it is a tool in the killer's hand.
Lucius Annaeus Seneca
78bronco460 is offline   Reply With Quote Quick reply to this message
Old 09-21-2004, 08:10 PM   #5 (permalink)
Member # 18131
The Tapcons work, eh? I was looking at them today and wondering if they would do it. I guess I'll give em a try. Thanks
As for a 1/2" rod straight through, while I am sure it would work quite well I don't think it would look too great on the outside of the garage
Old 09-21-2004, 08:32 PM   #6 (permalink)
ZJim's Avatar
Member # 24099
Send a message via AIM to ZJim
JB Weld or duct tape!
Or concrete screws depending on how heavy it needs to hold..
ZJim is offline   Reply With Quote Quick reply to this message
Old 09-21-2004, 08:47 PM   #7 (permalink)
Member # 2967
careful you dont strip the tapcons. it can be done, just snug them up.
best if you can get some longer ones and get into the web of the block.
id get a hammer drill and a percusion bit.
Old 09-21-2004, 09:26 PM   #8 (permalink)
Member # 9152
Originally Posted by dharmabum
...As for a 1/2" rod straight through, while I am sure it would work quite well I don't think it would look too great on the outside of the garage
You could use smaller rods. But if you can't penetrate the opposite side then 1/4" toggle bolts hold very well. The new kind with the nylon zip work pretty good.
Old 09-22-2004, 12:10 AM   #9 (permalink)
F-Trooper's Avatar
Member # 24554
copy that. i always throw on a bead of liquid nails
as well (for good measure). go easy with the drill-
cinder block blows out pretty easily.
Band member Support Group-
Free "Snow Trooper" in 2006.
F-Trooper is offline   Reply With Quote Quick reply to this message
Old 09-22-2004, 04:19 AM   #10 (permalink)
Member # 8203
tapcons work for crap in the older real "cinder" blocks. they work fine in newer Concrete Masonry Units, and they work best when you put them right into a mortar joint or block web.
super cool turbo 4runner
Sundowner is offline   Reply With Quote Quick reply to this message
Old 09-22-2004, 04:25 AM   #11 (permalink)
Member # 22408
If the block is grouted, filled with concrete, then tapcons or even small redheads will work anywhere on the wall. Haven't seen any block built in the last 15 years that wasn't grouted solid. Of course this is California, don't know about Jersey.
Rat70FJ is offline   Reply With Quote Quick reply to this message
Old 09-22-2004, 05:03 AM   #12 (permalink)
Member # 18131
Thanks for all the replies. Well the garage is about 30-35 years old and they are the older real cinder blocks so they do crumble pretty easy. I guess I will aim for the grout lines in between the blocks and use some liquid nails on the backside as well just to be safe. Will the Tapcons self drill or do you need to predrill with a masonry bit?
Old 09-22-2004, 05:10 AM   #13 (permalink)
Member # 8203
and there's the rub.
they only grout every 4th void or so (As far as I've see naround here), and I live in a 50 yr old house, so I'm basically using stuff that hangs ffrom the ceilings
Old 09-22-2004, 09:43 PM   #14 (permalink)
Member # 14228
Send a message via AIM to KevinM
A concrete screw is probably the best bet, shooting into it will is kinda sketchy. A sleeve anchor would also work well. You should be able to get a 1/4" sleeve type anchor at Home Depot. Hollow block typically isn't strong enough to set a red head type wedge anchor.
http://www.us.hilti.com/holus/module...jsp?OID=-12341
ZJ on 35"s
KevinM is offline   Reply With Quote Quick reply to this message
Old 09-23-2004, 03:27 AM   #15 (permalink)
Member # 30266
There are lots of choices out there, you could do the tapcon, sleeve anchors, or even the screen tubes with epoxy and a threaded rod...
as far as grouting CMU walls, around here, most of the CMU basement walls up to 10' are ungrouted...but I kinda like it - it is job security with me owning my own structural engineering company
bk
bkfj55 is offline   Reply With Quote Quick reply to this message
Old 09-23-2004, 04:12 AM   #16 (permalink)
Member # 8203
bk
structural engineers are the losers of the engineering world.
Old 05-18-2011, 07:45 PM   #17 (permalink)
Member # 190816
tapcons don't work on cinder block
Best bet is toggle bolts. Tapcons, concrete nails, anchors ,etc will NOT work on cinder block. Especially if it's aged. It hardens over years and will crumble like a cookie. YOu gotta use toggle bolts. Trust me, I've tried tap cons, with and without hammer drill, pre-drilled (and not). Tapcons won't work on the cinderblock.
probuilder32 is offline   Reply With Quote Quick reply to this message
Old 05-18-2011, 08:04 PM   #18 (permalink)
PAToyota's Avatar
Member # 37600
Send a message via AIM to PAToyota Send a message via Skype™ to PAToyota
Way to bump a six and a half year old thread as your first post...
94 GMC 6.5TD K1500 Yukon SLE / 93 Chevy 6.5TD K2500
85 Toyota 22R RN60 4x4
PAToyota is offline   Reply With Quote Quick reply to this message
Old 05-19-2011, 09:24 AM   #19 (permalink)
Member # 100827
Send a message via AIM to smewhtguy
Double X panders, Tapcons bring the suck in cinderblock.
I do math and stuff, on a professional level.
smewhtguy is offline   Reply With Quote Quick reply to this message
Old 05-23-2011, 11:48 AM   #20 (permalink)
370
Member # 153116
your not supposed to put the tapcon into the block anyway. the tapcon is supposed to go into the joint. and as for california solid grouting all cells that for eatrhquake issues most likely.. florida does almost the same thing for hurricane winds. in indiana we grout every 2-4ft depending on spec and wall height. and also if it's low lift grouting or high lift grouting. a tapcon every couple of feet inot the joint will more than suffice as long as your not going overkill on the weight. also ALWAYS predrill tapcons. believe it or not hilti nails work very well too. i'm nto sure where you can rent the powder cap hilti gun some places require liscensing to use one. i'm unsure about NJ but IL is i rememeber correctly requires either training or lisceneing to use powder cap propelled nail guns.
370 is offline   Reply With Quote Quick reply to this message
Old 05-23-2011, 12:44 PM   #21 (permalink)
Member # 143241
Let's see what other dumbasses post.
Jbevs is offline   Reply With Quote Quick reply to this message
Old 05-23-2011, 05:09 PM   #22 (permalink)
Member # 22408
Somehow, I bet the issue has been solved by now.
Dharmabum, what did you end up doing?
KI6ZGH
Old 05-23-2011, 05:14 PM   #23 (permalink)
Member # 126388
Didn't you read his name? He's a professional.
lukethedork is offline   Reply With Quote Quick reply to this message
