Member # 6494
Home brew water circulator for tig?
I need to dump this air cooled torch and get a water cooled one, but I'm too cheap to pay $600+ for a circulator. I've got a coolant pump out of my southbend 400 lathe that I'm contemplating using. Can you send too much water through the torch? And any guess as to what kind of flow requirements I should be shooting for? How big is your reservoir(5, 10, 15gal)?
We got the Rose Memorial Merit spot for KOH 2013! ECORS team #914, racing the Pampered Chef buggy |
#3 (permalink) | |
Member # 9576
I found a 5 gallon bucket to work fine. At 60% 250 Amp duty cycle (heavy duty machine) I need a break long before the machine does. The original miller water tank is a good 18" x 18" x 36" long. Old school stuff. Tank was too big, so just placed the pump (1/4 hp???) over a 5 gallon bucket... all it needs. Ya, had planned on a automatic transmission cooler. Fan, pump, fancy housing... All I'm going to change is make my tank from an aluminum cylinder about 9" diameter, 36" tall, so it will sit on the back of the welder. Found the 9" alumium tube in the scrap yard, part of an industial light fixture. Tom
Knee Grow
Member # 12575
Location: It puts the lotion on its skin OR it gets the hose
why not just hook up to your tap water put a good filter on it and dump the waist down the drain or in the yard?
just put a valve on the tap to regulate the flow
She said her name was Bambi, I said thats a coincidence darlin cause I was just thinkin about skining you like a deer then wearing your face like a mask as I do my little kooky dance |
Member # 6494
The unit is a Hobart CyberTig-200, and it's old. I believe the duty cycle to be 60%. The machine works great, I never knew the joys of DC stick welding until I got this thing. Next I need to find a torch with finger controls.
Can't/ wouldn't do the tap water because a: no running water in the shop, b: I wouldn't want everything to corrode from the well water that would be pumped in.
#6 (permalink) | |
Member # 30038
Member # 15945
I have built several. You can over pressure but it does require a few lbs. to cool properly. Use an Ogerdorf (sp?) pump it will cosst about 70 bucks. The company is in NY and these same pumps are used in several purpose built coolers. 5 gallons should cool just fine. Get the pump with the built in regulator turn the pressure up untill it just starts to leak at the torch head and then back off a little,
Pens and Paper for peace, help our troops win hearts and minds! - [url]http://www.freemanproject.org/about-the-project/our-mission[/url] |
Member # 5969
I made my own and used the same pump used on the ones you buy. I got it from Grainger, pumphttp://www.grainger.com/Grainger/pro...629241&ccitem= and motor http://www.grainger.com/Grainger/pro...634300&ccitem= about $165 for both, and just use a tank to hold a few gallons. Make sure you use the coolant made for welding coolers, if you just use water it will get nasty and grow stuff that will clog the pump and lines.
Member # 18521
Grainger sells the Italian brand.
Miller, Lincoln, ESAB all us the American made pump, Procon. You can purchase factory direct Proconpump.com for contact info. The same pump is used in fountain drink machines and are often on ebay used for around 10 bucks. You want a 100 gallon per hour model. |
Member # 7036
Hey Stud...when we weld out in the field on tanks, tube bundles etc. we run H20 from a utility station thru 1/4" plastic air line and let the flow go to the sewer. We use a Hoke valve to shut off the supply on older machines that don't have a foot pedal that fires up the high freq. and auto turn-on of the water. Hell....don't throw your $$ away...Later.
#12 (permalink) |
Member # 89255
Water cooled torches here
I've got water cooled torches for your Chinese tig or tig/combo machines over here.... /forum/tools-supplies/643662-water-cooled-tig-torches-chinese-machines.html
#14 (permalink) |
Member # 1926
I have one of those Tig coolers too.. Brand new Bernard 3500SS if anyone needs one.
'69 FJ40 with very few stock parts. 2000 Cummins with some goodies to make it smoke..... Trail Gear's Bad Ethics=Bad Business. |
#15 (permalink) | |
Member # 76684
[QUOTE=nahmus;9175355]asking chit chat to stop before they are done is kinda like asking piranhas to stop after one bite.[/QUOTE] |
#18 (permalink) |
Member # 22119
I used 2 different types at work. I made these because our 30 gallons of standing water was getting too hot from running the TIG's all day.
First was a simple pond pump with an oil cooler hooked up next to a bathroom vent fan. Second was an air circulator from a house in a 4" tube that had copper tubing run in a coil along the inside with a pond pump. They both worked fine to keep the 30 gallons of standing water cool for both machines. Since then I've moved them over to the Spot welders instead of running tap water through them and draining outside. My boss doesn't like to spend any money on equipment unless he gets a bug up his butt about something. He dropped 4k on a Lincoln welding fume extractor when I'm running 1960's? TIGs that blows fuses when trying to weld 1/4" alum (various reasons for this). I complain for years and nothing, he says to deal with it, but a new hire welder that I had to train how to weld complains and gets a new Miller 250DX and a Miller 210 dropped off. WTF??!!
2000 TJ 4.0L 5 spd. D44HP Front, D60 Rear, Detroits, 5.13's, 36" TSL, winch etc.. Custom: Radius arms front, leaves SOA rear, Belly up skid, tank in bed, 5" ext. wheelbase, OBA, H1 Beadlocks, etc.. Currently rebuilding for family wheeling anywhere. |
#19 (permalink) |
Member # 54522
the grainger pump and motor is discontinued.
my lincoln square wave 175 machine came with a small 120A air cooled torch thats only about 10ft long. the torch is also sort of bent due to alot of aluminum welding and taping the tungston out. i was thinking of getting a longer higher amp water cooled torch. i also dont want to spend over $100 on a water system. what hp pump or flow do i want for a setup like this?
86 4runner 7MGE bobed, exo, SAS on 38s, 5.29, fully locked with duals/4.7 and 30spl longs |
