Member # 2967
Tool Control foam.
Anyone know where you can get the foam that you put in toolbox drawers, the kind you cut out for tools? I need a shitload and the stuff snappy has is a fucking rip off. sears aint cheap either. Im thinking of finding just 1/2" thick foam.
Everyone said there would be bad days, I just never figured there would be this many. |
Member # 2967
I want the shit you cut out for the tools, not just a liner, i got that already.
Member # 34936
Never tried this before, but have you thought of spraying 'great stuff' expanding foam in, letting it start to cure a little, then dipping the tool in to create a depression? Have it wrapped in glad wrap to keep the GS from sticking. Great Stuff makes at least three different levels of expanding foam, look for the kind that is the least expanding
#6 (permalink) | |
Member # 25152
[QUOTE=killr-b]Here is my input--- You sir are a piece of safety equipment worn on the head of an inline skater !!!!!! [/QUOTE] |
#7 (permalink) | |
Member # 21102
"got a what are you looking at asshole smirk" |
Member # 34936
well I thought grease at first but I'm not sure how that would interact with the foam. I think there might be a thicker type of wrap that you can stretch tight against the tool to keep it from wrinkling as bad. I know there has to be something capable of doing this but its not coming to mind right now. I think the key to forming would be letting the surface cure, while the inside is still somewhat soft and malleable. Whatever happens, we want pics.
I'm sure there are a lot of other things that this stuff is useable for. I remember now a stiffer type of foam I've seen used for shaping molds. I can't remember the name of the stuff. Also while on the same topic, a friend once used a 'caulk' that had a soft, rubbery texture. It expands when exposed to air, making a sort of porous compound like soft work boot soles. This might work too, since it cures more of a soft rubber texture than the hard foam of Great Stuff. I think he bought it at 84 lumber. Not sure if they have those in your neck of the woods...
Member # 8203
check A&P mechanic tool sources.
most of them are required to use the foam by the FAA. the practice is called "tool shadowing" and it's more to keep absent minded mechanics from leaving a ratchet in a turbine than for tidy tool boxes.
super cool turbo 4runner |
#12 (permalink) |
Member # 34936
what's A&P?
I Googled tool shadowing and foun this: http://www.leaninnovations.ca/drawer_liners.html |
#13 (permalink) | |
Member # 8203
#14 (permalink) |
Member # 11745
My buddy used big foam squares that he got at Schucks. It the ones with a diamond plate pattern on them so it kinda looks cool. He just traced the tools and cut it with an x-acto blade.
They are used for mats to reduce strain of standing for long periods.
Later, Ken 1 Mercedes Benz Unimog 404s |
