Harbor Freight Tube Benders - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-02-2005, 05:05 PM   #1 (permalink)
JJS
Member # 28835
i'm looking at the pittsburgh 40" compact bender on the Harbor Freight web site. anyone have any experience with this or similar benders? will it work ok for long length tubing pieces? i would like to use it for doing bumpers, sliders, and the like. forgive my ignorance, i've never bent tube before.
here's the link to it:
http://www.harborfreight.com/cpi/cta...emnumber=38470
2012 JK. Stock as hell for now.
JJS is offline   Reply With Quote Quick reply to this message
Old 01-02-2005, 05:38 PM   #2 (permalink)
CJeep77's Avatar
Member # 25458
That is NOT a tube or pipe bender, that is basically an ornamental iron bender..Note that the die sizes listed are the radiuses, not the material size capacity. It states 5/8" round or solid capacity only.
CJeep77 is offline   Reply With Quote Quick reply to this message
Old 01-02-2005, 05:49 PM   #3 (permalink)
JJS
Member # 28835
Thank you for the info man, like I said I'm ignorant with this subject.
Old 01-02-2005, 05:53 PM   #4 (permalink)
fabcam's Avatar
Member # 19763
You need a rotary draw bender like the pro-tools or jd2. Check the vendor section, you will find several Pirate sponsers pushing them.
The site for the fabricator:
Bend-Tech
is now available!!!
Design full tube in less than a couple of hours with the PRO
We are the developers of the Bend-Tech products.
651-257-8715 for sales and support
10,000+ now using Bend-Tech
fabcam is offline   Reply With Quote Quick reply to this message
Old 01-02-2005, 06:06 PM   #5 (permalink)
JJS
Member # 28835
thank you very much dude. i checked out the section and it looks as though i won't be buying a bender any time soon. the jd2 looks very reasonably priced but money is tight right now. just out of curiosity, what can you do with this style pipe bender?
http://www.harborfreight.com/cpi/cta...emnumber=38024
Old 01-02-2005, 06:25 PM   #6 (permalink)
CJeep77's Avatar
Member # 25458
Try this thread for some input on that bender.
Old 01-02-2005, 06:36 PM   #7 (permalink)
Member # 20423
I have built 2 cages and a couple roll bars with mine.
http://www.harborfreight.com/cpi/cta...emnumber=32888
I picked it up at Northern on sale for about $69.
Best investment I made.
I use 1.5 ID and 1.9 OD pipe.
I cap 1 end with a spray can cap and duct tape. then fill it with pea gravel. shake till it's packed and cap that end.
Then bend.
I use a 14"cutoff wheel for cuts. With the rocks in it if needed.
You can google for a program called winmiter that will print out wraparound guides for your notches.
I grind them with my angle grinder.
It can all be done without a $500 bender.
HTH
Bill USN-1
EFI Moderator at http://www.binderplanet.com
Bill usn-1 is offline   Reply With Quote Quick reply to this message
Old 01-02-2005, 06:56 PM   #8 (permalink)
JJS
Member # 28835
hmmmmmm now i'm interested. thanks for all the info, i think i may be able to make that hydraulic bender work.
Old 01-03-2005, 01:21 AM   #9 (permalink)
Member # 20423
Here's another little device I came up with that really helps with the second bend!!!
I bolted it to my engine stand so it will rotate with the bend of the pipe!!
Here's the end product.
Bill USN-1
Old 01-03-2005, 04:01 AM   #10 (permalink)
Member # 11998
Send a message via AIM to BrettM
the orange HF bender ( http://www.harborfreight.com/cpi/cta...emnumber=32888 ) like pictured above does a great job for things you mentioned like sliders and bumpers. I did my tube-bed (pipe-bed I guess) with one.
now when it comes to making roll-cages using that bender and pipe rather than tube you will find some debate. the cages above look good because the bends are nice and 1.5" schd. 40 is beefy stuff, heavy too though. It is my opinion that if you get good bends, and use GOOD pipe (very important) 1.25 schd 40 for light rigs or 1.5 schd 40 for heavy rigs will make a perfectly safe cage. cage design and welds of course play an influence.
here is an excellent pipe vs. tube debate: /forum/jeep-hardcore-tech/216563-pipe-size-exo.html
you will notice by the end many people change their opinions about pipe, including me.
awshifting.com
BrettM is offline   Reply With Quote Quick reply to this message
Old 01-03-2005, 07:58 AM   #11 (permalink)
Member # 16024
I like that idea of hooking the bender to the motor stand...
I was just trying to figure out a nice stand for my one and hadn't though of doing it that way.
Way cool...
Thanks!
Check out UCORA.org
VOTE or SHUT UP!
glfredrick is offline   Reply With Quote Quick reply to this message
Old 01-03-2005, 05:36 PM   #12 (permalink)
Member # 20423
Thanks,
Setting it on the tailgate or holding it in the air and pumping got old.
This way you can use your level to insure the bends are parallel to each other.
Bill USN-1
Old 01-05-2005, 08:32 AM   #13 (permalink)
BUZZISCRAZY2's Avatar
Member # 17399
Send a message via AIM to BUZZISCRAZY2 Send a message via Yahoo to BUZZISCRAZY2
" Pipe " can save your ass and your shit........... IF built right.
My pipemobile was tied to the frame........Handled 50 + Mph roll 3-5 times. I'm still walking and the cage and frame are still straight and no bends.
I'd rather see someone use Good pipe than scrape them off the road with a shovel. Don't think that you have to have the bling for Chromo or you won't be safe.
http://img.photobucket.com/albums/v2...2/IM000098.jpg
http://img.photobucket.com/albums/v2...2/IM000101.jpg
Yeah, it's repost, but maybe it'll save a life !
[FONT="Comic Sans MS"]Catch your Dreams, before they slip away........[/FONT]
[FONT="Arial Black"]Current vehicles[/FONT]
67 Bronco
69 Bronco
81 Bronco
81 Bronco
75 F-250 (highboy)
77 F150
78 F150
70 F100 (2wd)
93 F350
95 F350 (Blown Crazy")
95 F350 ("Crazy Too")
87 Ranger (2wd)
00 Excursion
04 Navigator
BUZZISCRAZY2 is offline   Reply With Quote Quick reply to this message
Old 01-05-2005, 09:52 AM   #14 (permalink)
Member # 20423
I agree.
It is better for a guy to be able to afford to build a pipe cage then not be able to afford a tubing cage and run with just a show bar or hard top!
I paid $69 for the bender and $1/ft for the pipe.
I bought 60ft of pipe for my first cage.
I go to Lowes and buy the 1/4" X 4" plate and cut to length for the feet pads.
For less than $150 I had a 6point cage in my scout.
I felt much more secure than just running a hard top.
Not everyone can afford a full tube vehicle.
So how about something they can afford so they can be a little safer out on the trail and still enjoy our passion.
Off the soap box
Bill USN-1
Old 02-22-2005, 08:58 PM   #15 (permalink)
Member # 42292
bill sent you a PM, I am not having the same success as you with my bender... I am geting ugly 90 degree bends, i used pea gravel just like you said, pumped about once every 5 seconds or so, and I am getting the outside surface reall flat and the inner surface kinks... I just PM'd you, if you can offer some instructions I would appreciate it... Like where do you put the rollers
jeepn4life is offline   Reply With Quote Quick reply to this message
Old 02-22-2005, 09:19 PM   #16 (permalink)
Member # 16024
On mine, I figured out that you have to place the rollers about as far out as you can, even for the small bends. Mine also bends very nicely without packing the pipe with sand or pea gravel, but I do use a couple pieces of larger tube, split in half to guide the pipe on the outer rollers. That takes away the dimples.
It almost sounds like you are trying to bend thin-wall tubing instead of pipe by your descriptions of the bending process. Mine flattens out tubing pretty well, but bends pipe perfectly round.
Speed wise, I just get the piece of pipe lined up the way I want it and pump away... I don't slow down to wait for anything. The stuff just bends.
Check out UCORA.org
VOTE or SHUT UP!
Old 02-22-2005, 09:24 PM   #17 (permalink)
JeepinDoug's Avatar
Member # 13028
Originally Posted by Bill usn-1
The passenger rear corner is creased with multiple ripples. This is why drawn rotories are prefferred for cage work.
My personal opinion, I wouldn't wheel with this cage.
I'm not saying you didn't take care and thought in this cage, I'm not trying to flame your work. I just wouldn't trust those ripples to save my mellon.
The corner should be the strongest area but now the ripples make it the weakest.
I may lack much in way of integrety but I make up for it with pure denial.
JeepinDoug is offline   Reply With Quote Quick reply to this message
Old 02-23-2005, 07:30 AM   #18 (permalink)
Member # 42292
what size pipe... I am using 1.5" sched 40.... And for sure it just kinks like crazy if i just put it in and bend away... Now up to a 45 degree angle it is fine, but after that it is all over....
