Too cheap for HF
Well, I could not see paying $130 for a 6 ton press from HF. (I am a super cheap bastard)
I happened to have a bunch of 2x6, 2x3" square tube and some 4" and 6" U channel steel. Plus a spare 6 ton hydraulic jack sitting around. So I figured that I could easily just make a press. ![]() The thing actually turned out fairly well. (I am having a hard time getting the pics off of my camera at work I'll do it at home later) The one place that I am kinda stumped is how I should make stops for the adjustable lower table. I was thinking that it would be easy enough to just weld some tabs to the press itself or would it be better to have more adjustability by drilling 3/4" holes in the uprights for a bar to pass through?? The center section is removable so the tabs would be pretty easy over all. Ideas/suggestions??
DEAR MADAM: THANK YOU FOR YOUR RECENT ORDER FROM OUR SEX TOYS WEBSITE. YOU'VE REQUESTED THE LARGE RED VIBRATOR AS FEATURED ON OUR WALL DISPLAY. PLEASE SELECT ANOTHER ITEM. THAT'S OUR FIRE EXTINGUISHER |
And the bender (almost finished.)
The uprights are made out of 2x6" .120 wall tubing. The top member is 7" U channel steel (so is the base of the jack) The adjustable portion is made out of .250 wall 2x3" tubing. The bottom support/tie in is 4" U channel steel. Super beefy... And the obligitory first squish made. D60 5.13 pinion..
#4 (permalink) | |
Member # 3511
Chuck P The clowns'? Oh, yeah, the clowns. We fight them too — entire armies, spilling out of Volkswagons. We do our best to fight them off, but they keep sending 'em in! www.oldjeep.com |
#6 (permalink) | |
I'm still money ahead
#7 (permalink) | |
Member # 12499
Wrenchin' to riches! If you want peace, prepare for war. |
Member # 11425
close-ups!
i been wanting to do this sorta thing for a while now, it would be extremely helpful if you could get me some close-up shots of the jack, slides/springs, work shelf (where you place that pinion you pressed a bearing onto), etc.
[I][SIZE="1"][COLOR="Silver"]"do what thou wilt shall be the whole of the law"[/COLOR][/SIZE][/I] |
Member # 5776
Home-built presses all have one thing in common.
They either eventually look like this (bent): ![]() Or like this (braced):
[size=1]ASE Certified Master Automotive Technician Toyota Certified Expert Technician Volvo Certified Expert Technician Suzuki Certified Master Technician IDPA Certified Master Cardboard Killer[/size] Last edited by TNToy; 03-30-2005 at 08:44 AM. |
