Member # 10736
switch rotation of electric motor
i found this old motor in our barn and i would like to use it. the only problem is that it spins the wrong way. how do i switch the rotation from counter clockwise to clockwise ( looking down the shaft from the front). it is an old GE 1/2 hp electric motor with a 2 prong plug.
[IMG]http://img.villagephotos.com/p/2005-...25/Pic0000.jpg [/IMG] |
Member # 7588
If it were a Baldor motor I would tell you to exchange wires #5 and #8...
have you taken off the terminal cover yet? sometimes there is a diagram showing the correct wires to change (either wire numbers or colors...)
1948 Willys 1952 M37CDN Powag Last edited by CRO; 07-30-2005 at 12:45 AM. |
Member # 12491
Yikes! The amount of mis-information here. It's an AC motor ... it doesn't have brushes.
First take off the cover plates and look for any wiring diagrams. Take pictures of whatever you find (diagram or just the terminals inside.) Post those here. It has a capacitor which means it's probably a capacitor-start motor (or it could be a capacitor-run motor also called a 2-phase motor.) Anywho it will come down to swapping 2 or 4 wires (if they are available at the cover plate.) Take a look and tell us what you find. CP |
Banned
Member # 24704
It may have a shading coil or start windings too. A single phase electric motor will continue in whatever direction it is started in, you just need to figure out how to start it in the opposite direction.
#9 (permalink) | |
Registurd Abuser
Member # 34995
'71 800b, 305 Vortec, 4L60e/241d/241c 60, 14, 37's. Hours away from driving again
#10 (permalink) | |
Member # 334
Open housing. Flip stator over so the armature is now reversed in relation to the stator. Put housing back together. Reinstall bolts. |
#11 (permalink) | |
Banned
Member # 24704
#12 (permalink) | |
Member # 14620
Priest "The time has come to liberate the potential of the coming porkappocalypse." |
#13 (permalink) |
Member # 43867
If its anything like all the air cond motors. You should have two wires to swap and splice back together. Quite a few ac motors have brushes they are known as a universal motor as they will run on ac or dc. Hell for the trouble and time you have spent go to any harbour freight and by what you need.
