ultra newbie
Member # 12487
I found it on the side of the road with a free sign on it
![]() I fired it up last week and it was working but the chuck was rusted shut. The chuck isn't shown in the pic. I took it off right before I took the pics. Last edited by Lmpymilk; 09-22-2005 at 07:55 PM. |
Member # 13439
super find!!
Awsome find.
Those style of radial arm drills, have a 100 uses. Bolt it to a solid bench and you can swing the arm around for drilling on larger items clamped next to the drill. Not as portable as a magnetic base drill set up, but with a little creativity applied for mounting just as usefull. Find a flat surface on the drill head, use an angle finder for keeping the drill head at 0*. Those clamp style mounts tend to creep.
Free Beer Tomorrow |
Member # 12499
Looks like one I put out in the trash last spring! Mine had the most awful bearings in the head.
Wrenchin' to riches! If you want peace, prepare for war. |
Member # 19763
Is there a reason to why you need to know the make and model?
The site for the fabricator: [URL="http://www.offroadfabnet.com/index.php"]www.offroadfabnet.com[/URL] [COLOR="Orange"]Bend-Tech [URL="http://www.2020softwaresolutions.com/bt_pro.htm"]PRO[/URL] is now available!!![/COLOR] Design full tube [URL="http://www.2020softwaresolutions.com/web_images/Racer-X_5[1].jpg"][U]chassis[/U] [/URL]in less than a couple of hours with the PRO [COLOR=Cyan]We are the developers of the Bend-Tech products. [COLOR="Yellow"]651-257-8715[/COLOR] for sales and support[/COLOR] [URL=http://www.2020ssi.com]www.bend-tech.com[/URL] [COLOR="Cyan"]10,000+[/COLOR] now using Bend-Tech |
#8 (permalink) | |
ultra newbie
Member # 12487
Chris |
Member # 14887
Looks like an old Rockwell / Delta.
In fact the front part (Quill????) is just like my Rockwell / Delta, but mine does not have the pivot at the main tube.
Carey |
Member # 27362
With the rusted chuck you might try electolysis (sp?) to get a lot of the rust out. I have seen some amazing stuff get grought back to life with this process.
Do a search for electric rust removal on the web. Also think there is a thread on here too. From what I have seen arround here it looks like a Delta. Looks pretty good and heavy too. Great find. Carl |
#12 (permalink) |
Member # 144
My bet is on it being a Delta from right after their walker-turner purchase. If it is.. parts are still available.. too bad you just tossed it Paul
That's because you're a pinko fascist. - Haole I know what antidisestablishmentarianist means |
#13 (permalink) |
ultra newbie
Member # 12487
OK - I found it. It's a 1974 Rockwell 11-280 32" radial drill press.
here is the manual. it has a date of 06/01/1974. ***Edit*** Here is where I found the manual. Looks like a very good site for finding old machine manuals. Thanks for the input. Chris Last edited by Lmpymilk; 09-24-2005 at 08:48 AM. |
#17 (permalink) |
www.12voltguy.com
Member # 40
COOL find!
I have an old Rockwell, guessing 50s got for $100 at a yard sale been using it for work last 2 years, speed is a bit high, but I drill mostly thin aluminum, I also use it as a light duty mill with a vise that moves in-out/left-right yours looks most versatile!
12voltguy info@12voltguy.com--davezoffroadperformance.com # 530.532.4529![]() TTC 2010 1989 BRONCO -Awesome web development for your business. www.mudnworks.com mud@mudnworks.comPat's W I D E TOYOTA Front Axle --07 KTM 450XC----with "stuff" |
