HF MIG Cart Review - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-02-2005, 11:11 AM   #1 (permalink)
Member # 18989
HF MIG Cart Review
I was going to build a new design of welder cart. My design was going to be based on a hand truck, so I went to HF to buy one. I found this item there....
http://www.harborfreight.com/cpi/cta...emnumber=90305
I got it for $39.99, which was too good a price to pass up.
I liked the color of blue. The finish was good, except where the axle tube was welded to the bottom. The paint was a little thin there, and there was rust in the joint. The hardware, although definately not American made, was some of the better Asian hardware I have seen. There were even grade markings on the bolts. It fit together well, and was reasonably sturdy.
I didn't much like the wheels or casters, so I used the ones from my old cart. Here, the original wheels and casters are shown on the ground.
I think it was a good buy, and would recommend it.
A flash of lightning illuminated the object, wretch, hideous, filthy daemon. A new species would bless me as its creator.
frankenfab is offline   Reply With Quote
Old 10-02-2005, 11:56 AM   #2 (permalink)
Christian hater arg!
CrustyJeep's Avatar
Member # 29527
Nice... I think that may be my next $40 expendature
Originally Posted by JK3078 View Post
To fucking ignorant
CrustyJeep is offline   Reply With Quote
Old 10-02-2005, 02:21 PM   #3 (permalink)
Member # 11363
Send a message via AIM to 1985CJ7Laredo
That's a big improvement from the cart they used to carry in the same price range.
1985CJ7Laredo is offline   Reply With Quote
Old 10-02-2005, 04:44 PM   #4 (permalink)
Member # 39602
The cart looks OK, but whats that horrible, ugly thing behind it?
mountain4x4 is offline   Reply With Quote
Old 10-02-2005, 07:54 PM   #5 (permalink)
Member # 41306
That's funny. I went to HF about two years ago and bought a hand truck to convert to a welding cart. The tank and cooler went on the bottom plate of the truck, and the welder got mounted on the rear. It turned out ok, but now I want to build a regular cart. The HF cart has no place for a cooler, so I may have to make my own.
Scott F is offline   Reply With Quote
Old 10-03-2005, 07:56 AM   #6 (permalink)
Dirt Engineer
Clodhopper's Avatar
Member # 23542
I picked up the same cart at HF. I was needing to build one when the HF ad arrived with that cart on sale. That is the sale price by the way, they are usually more expensive. At the sale price, it just wasn't worth the time and materials to build one. Besides, one I got it home, my wife and 3yr old son put it together. I didn't even have to do that!
The paint on mine was maybe not quite as good. It appears it was dipped and hung, as one of the trays had a full corner and some bare spots from bubbles. Don't care about the paint as it will get beat up anyway. Although the casters aren't great, they seem to work just fine with the welder, tank and tools on board. I will be adding some standoffs for the tank as it is in contact with the welder.
For a simple cart that functions, it is hard to beat the price.
Clodhopper is offline   Reply With Quote
Old 10-03-2005, 12:08 PM   #7 (permalink)
Member # 347
When it is empty, is it stiff enough not to rack diagonally? How about when loaded?
A buddy bought the older HF gray model an it racked so badly that it was in the trash the next week.
Have they stiffened up the design?
Randii
randii is offline   Reply With Quote
Old 10-03-2005, 01:28 PM   #8 (permalink)
Dirt Engineer
Clodhopper's Avatar
Member # 23542
yep, it is pretty stiff. I have not seen the previous design, so I can't say how it was improved. This one has a solid back panel, limiting racking. I have no concerns with stability, even loaded. It rolls around very steady.
Old 10-03-2005, 01:29 PM   #9 (permalink)
Dirt Engineer
Clodhopper's Avatar
Member # 23542
Hey Frankenfab, I just noticed you have a liner in the pans on your cart. Did yours come with that or did you add it?
Old 10-03-2005, 02:03 PM   #10 (permalink)
Member # 18989
Originally Posted by randii
Is it stiff enough not to rack diagonally?
It is reasonably stiff. It could be a little sturdier (a person could easily add reinforcing), but I think it is acceptable.
I added it. It is rubber floor mat.
Old 10-04-2005, 12:50 PM   #11 (permalink)
Member # 660
tag for home
83cj7 amc 401 th 400
full hydro steering
dana 60 arb
14 bolt detroit
44x18x16.5 swampers
MEMBER East Coast Pebble Crawlers
smitrock is offline   Reply With Quote
Old 10-04-2005, 09:57 PM   #12 (permalink)
Bob1's Avatar
Member # 1486
Yea-I have that thing. After buying I highly suggest upgrading the casters on the front end. My Miller 175 almost took a huge dump because of my cheap cart. The front caster broke and the unit almost fell over, if I hadn't been turning the cart to make an adjustment on the front it would have hit the floor. Get rid of the stock casters and get some good ones to replace them with, if you can while your at it, widen the stance.
85 4Runner-08 Tundra 5.7 DC-77 FJ40
GCLC Vice President
Bob1 is offline   Reply With Quote
Old 10-05-2005, 09:24 AM   #13 (permalink)
dnebout's Avatar
Member # 36580
I got one for my birhtday. Cheap and decent. Can't be beat for the price.
dnebout is offline   Reply With Quote
Old 10-06-2005, 05:27 AM   #14 (permalink)
says "yall" alot
45acp's Avatar
Member # 13671
I have it and it works fine. As suggested, it really needs some better casters but overall it is sturdy. I wouldnt recommend your 350lb. mother-in-law jumping on it and riding it down the driveway while screaming "BONZAI!!!" but it is plenty strong for a welder.
Hey kid, are you going my way?
Hop in... we'll have ourselves a field day
45acp is offline   Reply With Quote
Old 10-06-2005, 07:45 AM   #15 (permalink)
Dirt Engineer
Clodhopper's Avatar
Member # 23542
another hobart welder on a HF cart..... just like mine. Man, we are a bunch of cheap bastards, aren't we?
