When I purchased my home it came with a 25x40 work shop that had a commerical wire basket making business. They told me is had 480 power. It says that in my paperwork when I got the house. I gutted my garage now I am thinking that is doesn't have 480. The wire from the pole comes into a big switch box. Then into a breaker panel. I opened the switch box and 3 wires come into it. 2 powers 1 neutral? Inside it says
The switch nameplate tells us its a motor rated switch that is rated for a 30HP motor with single phase 240V and a 50HP motor with 240V three phase power. It tells us nothing about your service as it sounds like it is a disconnect for the building. As it is rated for a 40HP motor with 250V DC the switch should have a non motor rating of 200A.
As far as what service you have look at your meter base or call your utility. What is connected between your service point and the disconnect in the building is unknown to us.
would be odd to have 3 phase at a residence but not impossible. inverters are not in the picture. put a volt meter on the legs and see what you have-easy.
Guy that owned it before me. His father owned my whole road and ran a multi million dollar wire basket business with lots of big equipment back in the day most likely 3 phase stuff. His son moved the buiness over to my shop that I own on and shrunk it down. Figuring he was useing the same old equipment and tied to 480 in the road that ran to his fathers place. Doesn't look like it though. I am going to call the power company to see if it is out in the road and how much to tie into it. I am moving my father's machine shop over here and he has power converter {over what ever you call it} to change the power on the bridgeport and lathe. So I was thinking of using those and put a plug of the other end and then just make up thick extension cords. Plug in the machine that I will be using at that time. Was planning on buying alot of different 3 phase equipment cuz its cheaper.
