I thought I would put this out there in case anyone knows the answer. I have a standard manual 4 way control valve (Prince no 5009), spring return center. Currently in the center position A & B are blocked and P & T are connected.
I would like the center position to block A and connect B, P, and T. This looks similar to a "floating" valve, but the pressure and tank ports are connected instead of the work ports.
I can't find any drawings of the valve's internals, so I'm not sure how the spool works to direct flow. Does anyone know if I can purchase a spool or modify my valve to accomplish this change?
Attached is what I have and what I would like to have. Thanks for any help!
