I am looking to buy a new 220 welder. I am looking at Lincoln ST-175 Plus and the Millermatic 175 or the Hobart Handler 180.
I would like some REAL world reviews, not I HEARD that the Lincoln was awsome type responses please.
I am wanting to buy this welder in the next 2-3 weeks and need some input quickly guys. I dont want to step up to a bigger welder, I am really only interested in the ones listed above.
I've got the Lincoln SP-175 Plus. I love it. It's pretty much the welder that my 4x4 club uses when there's thicker metal or critical welds to be made.
The SP-175 Plus has the infinite heat control, which I think is really important. If the others do not, the choice, then, is simple.
I have the Millermatic 175 for about 3 years now. It is an absolutely outstanding welder. It has the infinite heat control as does the Lincoln 175.
I have run gasless and sold Mig .024-.040 through it and it has never given me any problems what-so-ever. I have welded 1/2" mild steel plate with .040 Innershield and yes, I cross-sectioned it to review penetration. It did fine.
All the welders you mentioned above are good ones.
If you search some, you will find what seems to be an insufferable amount of threads discussing this EXACT topic.
All three units are reall close to each other. My vote is Miller, but I suggest going with and getting from you local supplier. Mine has been an invaluable resouce of knowlege and help. Havent need anything but consumables for my MM175.
I recently bought a Hobart 175 from a local pawn shop and so far I am extremely happy with it. I know several guys that have the Miller machine and even some Lincolns. I don't think you can go wrong with any of them.
I have had my Lincoln SP-170 for almost 14 years now. I have put a lot of wire through it (200 12LB spools), and it hasn't ever given me problems. I have used many other MIG welders, and the SP-170 is still my favorite.
From what I was told, the Miller uses more expensive copper windings vs the cheaper aluminum windings of the Lincoln. This info came from two welding shops. They are priced basically identically and the manager of one of the shops is a friend of mine and gave me a rockin' deal on a Miller 175.
I was toying back and forth with getting a MM210 or even a 251.. but I can do 90% of what I'd ever do with the HH180, so I figured I'd spend the saved coin on other things like a plasma cutter, and other tools.
I like the Lincoln becase of the infinite heat control and the fact that Lincoln makes a Aluminum wire kit so that you can weld aluminum with the 175.
To do this with the Miller they insist on a Spool Gun. While that is good for production. If you are doing a few small things, espically on a bench it is nice to be able to do it cheeply.
Also it is a good welder.
BTW. I have a sp-175T, and a miller matic 200. The 200 is nice for big stuff but the Lincoln is pretty portable.
I recently bought the Liconln 175 without the infinite heat settings. The local welder told me that unless you are a very skilled/expert welder, that you would most likely not notice the difference. I have been very please with the results of this welder and would recommend it to anyone looking for a 220V welder. I dont' think you can go wrong with any of them!
Good luck and happy welding!
Just to throw one more option out there, our new Thermal Arc Fabricator 251 was delivered yesterday. We were able to get it for the same price as a MM210. We have not had the chance to do anything with it yet, but we will let y'all know how well it works. On a side note, the welding shop at the local community college is now using nothing but Thermal Arc machines.
I just bought a recon HH180 from ToolKing as well. Had to trade in my CO2 bottle for a C25 since the regulator was different from my hold Hobart 120.. haven't quite put down a bead with it yet, though.
FYI a home depot lincoln is NOT the same as one bought from a welding store. I highly suggest getting your welder from a welding shop. Not saying the HD one won't work, it's just in a different league..
I have a Millermatic 185 and love it. It has never, ever given me a single problem in the 8 years I have owned it.
