The Transmate workstand, cheapie tool - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-03-2005, 06:57 PM   #1 (permalink)
JeepinDoug's Avatar
Member # 13028
I seen something like this along time ago and figured it was time to make one.
I had some extra steel laying around and bought two 3/4" coarse coupling nuts and a 2' section of all thread.
I bent 1-3/4" by .120" wall 180 degrees.
Chopped the ends so they line up.
Then I down sleeved the tube twice more.
The bend and sleeves don't matter.
I threaded the coupling nuts onto the 2' length of all thread and spaced them to match the horseshoe so I could weld the nut at the end of each side.
Just tacked them so I didn't overheat the threads.
I pulled the all thread out and chopped into two lengths.
I turned the all thread ends in a lathe but grinding simple points will work fine.
Then welded some t-handles.
My TH400 has these two side holes that are a great balance point for grabbing the trans, I'm not sure how many other trans have this feature.
Here's the horseshoe.
It fits over the trans like so........
And once I pull the trans out to change the tail shaft it'll go in the engine stand like so........
I don't have a whole lot of table space right now so this will come in handy for me and store away nicely.
I may lack much in way of integrety but I make up for it with pure denial.
[URL=http://www.pirate4x4.com/forum/showthread.php?t=377480][B][COLOR="Red"]Malvado Grande #1[/COLOR][/B][/URL]
JeepinDoug is offline   Reply With Quote
Old 11-03-2005, 08:40 PM   #2 (permalink)
Member # 18989
All the tranny stands I have used had an additional brace coming in from the top to keep the transmission from pivoting. Like this.....
A flash of lightning illuminated the object, wretch, hideous, filthy daemon. A new species would bless me as its creator.
frankenfab is offline   Reply With Quote
Old 11-03-2005, 09:22 PM   #3 (permalink)
JeepinDoug's Avatar
Member # 13028
The one I saw had the horseshoe so small around the case there was no room for it to pivot. I do plan on adding a stop for the back of it though. I'd like it to lean back a little, that's why the horseshoe is large on mine.
Old 11-03-2005, 10:21 PM   #4 (permalink)
jays68yak's Avatar
Member # 19015
Send a message via AIM to jays68yak Send a message via Yahoo to jays68yak
hmm thats pretty sweet.
1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s
1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and fox coilovers, 8.1 liter 496 bbc/4l80e/BWtcase. DD/towrig
jays68yak is offline   Reply With Quote
Old 11-03-2005, 11:33 PM   #5 (permalink)
Christian hater arg!
CrustyJeep's Avatar
Member # 29527
This is why I love PBB
Originally Posted by JK3078 View Post
To fucking ignorant
CrustyJeep is offline   Reply With Quote
Old 11-03-2005, 11:34 PM   #6 (permalink)
Member # 36678
$270 at NorthernTool:
http://www.northerntool.com/webapp/w...24&R=200008224
BurntOrange is offline   Reply With Quote
Old 11-04-2005, 04:58 AM   #7 (permalink)
PAToyota's Avatar
Member # 37600
Send a message via AIM to PAToyota Send a message via Skype™ to PAToyota
At $300 by the time you add shipping and all that is one ugly piece of work. Doug's is much more trick plus bonus points for chit just lying around!
GET INVOLVED - Join the Blue Ribbon Coalition
SIGN THE PETITION - SAVETHEHAMMERS - #85
'93 Chevrolet 6.5TD K2500 NV4500 Std. Cab Longbed 170K
'85 Toyota 22R RN60 4x4 Std. Cab Shortbed 178K (Currently retired for rebuild)
PAToyota is offline   Reply With Quote
Old 11-04-2005, 05:02 AM   #8 (permalink)
sid
Member # 21869
thats cool!! good job!!
sid is offline   Reply With Quote
Old 11-04-2005, 09:22 AM   #9 (permalink)
Moderator
geberhard's Avatar
Member # 5861
Doug Monster's garage, kick ass!
Gui
geberhard is offline   Reply With Quote
Old 11-04-2005, 04:52 PM   #10 (permalink)
JeepinDoug's Avatar
Member # 13028
Wow. The cheapest tool house still wants big dollars.
I should have listed this in dollars and cents.
2 coupler nuts and all thread $17 at Orchard HW store.
1 odd piece of tube, 2-3/8" by 1/4" wall, $4.00 at Metal Supermarket.
A 4' section of 1-3/4" by .12" wall, $9.00 at MSM.
I had the other scraps.
$30 total.
Use your own engine stand as a base instead of having multiples on the floor.
Thx guys, I love making these little odds and ends and good feedback is icing on the cake.
Old 11-05-2005, 10:51 AM   #11 (permalink)
Member # 16773
The one I use is similar, but the piece that fits into the bench/engine stand comes off the side of the tranny, not the top. Lets you lay it flat on it's back to deal with the valve-body.
To many damn projects!!!
Cahdealme is offline   Reply With Quote
