Ready Welder Q's - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-25-2005, 02:34 PM   #1 (permalink)
GRMhick's Avatar
Member # 87
Location: I live in hotels tear out the walls I have accountants pay for it all
Send a message via AIM to GRMhick
Ready Welder Q's
Im picking up my ready welder tomorrow, and I have a few questions about it.
First off, I read on the website, that I can use a DC stick welder as the power supply for the welder.
Does anyone know how that works? Will I literaly use the stick welder to change the amps for the ready welder?
What is the voltage coming out of the stick welder?
I only weld about 1-2 times a month, so I feel I can get away with the ready welder being my primary welder in the garage (im buying it so I can fix my junk on the trail). Am I going to have any problems with it? Only down side I see thus far is that the gun is huge compared to the hobart 180, or the lincoln 135 Im used to using.
GRMhick is offline   Reply With Quote
Old 11-25-2005, 04:25 PM   #2 (permalink)
Member # 21995
I think you hit the nail on the head as far as the biggest downside.. SIZE..
Other than that if you have a DC stick welder to hook it up to, you should be jammin. However, if you don't have a DC source to control the amperage, the ready welder is a bit of a PITA because the voltage and wire speed is int he same knob... as you increase voltage you increase wire speed. Not the end of the world, but a little annoying.
Also the wire is always hot. So if you touch something grounde, its going to go. (unless you spent the extra $100 to get the gun that doesn't do that)
mucknet is offline   Reply With Quote
Old 11-26-2005, 10:55 AM   #3 (permalink)
4x4 ADD
noclinkers's Avatar
Member # 23026
Mine has saved me more than once.
They are also able to use solid wire if you get a tank. That is a good option if you are working at home. Would not be my first choice though.
noclinkers is offline   Reply With Quote
