Member # 21408
Harbor Freight "horizontal/vertical" pipe bender
There has been quite a bit of talk about using sch. 40 pipe and a HF pipe bender, but the other day I noticed that HF lists the good ol' 12-ton pipe bender and a 12-ton "horizontal/vertical" pipe bender. I don't remember seeing the latter listed previously on their site.
The pictures look basically the same, but the specs do mention 90 degree bends and a longer jack handle with the "horizontal/vertical" version, and it costs about $25 more. So what's the deal with this "horizontal/vertical" bender? |
Member # 24091
It's got springs on the ram so that it'll return the cylinder when it's postioned vertically is all. Looks at the pictures, you'll see the difference. Not worth the $25 imo. My base model one works just fine, in all positions.
Member # 16024
A post of this nature, after all the discussion previously on Pirate is subject to the ire of the board. But in short, for a non-competition rig, that mainly sees trail use -- the HF pipe bender and schedule 40 black pipe will work.
A good many people have done it, including this poster, with good results. It won't pass tech at a major rock crawling meet, but it will save your bacon on the trail. Have at it. Oh -- do a simple search for pipe bender and read all the rest of the discussions here at POR.
Check out UCORA.org VOTE or SHUT UP! |
Member # 16024
A couple of tricks that I have learned using mine...
1. Cut a piece of larger pipe/tube and use it to sleeve over the roller wheels so they don't dimple the pipe you are bending. This will allow you to make tighter bends very cleanly. 2. Use a magnetic angle finder and a large carpenter's square to figure out bend angles. Know that there is some "spring back" when you bend, so you will have to bend a tad more than you want to count for the spring back. Figure out the first leg, then duplicate that for mirror bends. 3. An engine stand makes an almost perfect attachment point for the bender. Just drill a couple of holes in the flat metal supports on the bender and hang it on there. You can then swivel the bender to almost any angle as you work a bend. It also lets you roll it around as you work, but doesn't affect the bending process because, unlike benders that you have to pull against, the HF bender bends against itself. 4. Bend slowly, and watch where the seam in the pipe goes. There are different opinions about where it should be, but I generally put it on the inside, where it has to bend the least so it doesn't stretch the weld so much. I've never popped one, but why take the chance. Otherwise, I've found that the bender is great -- and inexpensive -- for general use projects, and for the type of work for general trail rider rigs.
Member # 14903
I picked one a couple of weeks ago, it is the same as the 12 ton, just the return springs like someone mentioned. I like it. I lay it on it's back when i've got a whole stick of pipe in it so then when i release the pressure it retracts pretty quick. I'm getting ready to build a cage with for my rig, but i'm building a couple of other things first so i can get use to the bends and how it bends at different lengths.
Josh Cassell WV Air Force National Guard [URL="http://www.explorerforum.com/forums/showthread.php?t=167298"][SIZE="4"][COLOR="Blue"][B]SAS #2[/B][/COLOR][/SIZE][/URL] |
Member # 37244
Go with the regular model, no need for the spring return. I`ve used my HF bender for many projects and found the only drawback to be not getting a bend much past 90 deg. Glfredrick, thanks for the engine stand idea, that should make positioning much easier.
#9 (permalink) | |
Member # 16024
It sure does work good, though.
B.O.H.I.C.A.
Member # 55214
I bought the HF bender and its seems to be ok to me. I have been working on making some tube doors..........so far so good
"Why did I build my Jeep that way you ask?" "Because of the infinte knowledge you Pirate Gods told me too!
Member # 14903
Cool, post some pics up when you're finished, i'm working on the same thing, should be finished tomorrow!
#12 (permalink) | |
It's a Daimler thing: You wouldnt understand! [i]"I work on a fishing boat. I started as a Apprentice Baiter. Now I am a Journeyman baiter. One day I hope to make Master Baiter". (By DEnd)[/i] Last edited by coachgeo; 12-26-2005 at 08:55 PM. |
#13 (permalink) | |
Member # 16024
When I looked at more expensive benders, I noticed that the dies were longer, hence distributed the force over a larger section of tube while bending. I just wanted to duplicate that idea cheaply, so I came up with the sleeve idea. It works perfectly, except that you have to stick it in place before each bend. I can now shorten up the radius of the bends instead of having the rollers sit way to the outside of the rack (the recommended fix for "dimples" in the pipe). Here is a pic. You can see the sleeves if you look closely at the roller.
#14 (permalink) |
B.O.H.I.C.A.
Member # 55214
Here is my problem that I have hit tonight. I have 1.75 tube at something like .0239 or close to it. The HF bender is flattening and crinkling my tube.... it did great on the 1 inch. Seeing how there is no exact die to fit a 1/3/4 I tried the 2' the 1/1/2 and the 1/1/4 all did the same thing so I am really dissapointed now....... I will keep it to do small stuff but I dont know what eles to try any ideas......
#15 (permalink) |
B.O.H.I.C.A.
Member # 55214
What diameter tube should I be using........the metal shop guy said what he gave me what the same stuff everyone is using to make cages? I give up I am going to build a wooden cage...........
#16 (permalink) |
Member # 912
You need to use PIPE not tube. 1-1/4" sched 40 pipe is around 1.66" OD & 1-1/2" is around 1.9" O.D.
Pipe is much cheaper than tube but do a search on the board to see the differences & make oyur own opinion. |
#17 (permalink) | |
orrrrr.. you take your dies down to the place where you can buy tube and you find one strong enough for a cage AND fits snugly inside one of your dies. I think there is ONE that fits exact. A search in this board will come up with it. Last time I saw the thead with this info it was NOT in this forum. Maybe in general 4x4? Someone might pop in and let us know.
It's a Daimler thing: You wouldnt understand! [i]"I work on a fishing boat. I started as a Apprentice Baiter. Now I am a Journeyman baiter. One day I hope to make Master Baiter". (By DEnd)[/i] Last edited by coachgeo; 12-27-2005 at 05:16 PM. |
#18 (permalink) | |
What have you found to be the best way too split the piece lengthwise?
It's a Daimler thing: You wouldnt understand! [i]"I work on a fishing boat. I started as a Apprentice Baiter. Now I am a Journeyman baiter. One day I hope to make Master Baiter". (By DEnd)[/i] Last edited by coachgeo; 12-27-2005 at 05:22 PM. |
#19 (permalink) | |
It's a Daimler thing: You wouldnt understand! [i]"I work on a fishing boat. I started as a Apprentice Baiter. Now I am a Journeyman baiter. One day I hope to make Master Baiter". (By DEnd)[/i] Last edited by coachgeo; 12-27-2005 at 05:57 PM. |
#20 (permalink) | |
you gota find that magic OD and ID tube that fits the pipe dies. Or modify your dies.
It's a Daimler thing: You wouldnt understand! [i]"I work on a fishing boat. I started as a Apprentice Baiter. Now I am a Journeyman baiter. One day I hope to make Master Baiter". (By DEnd)[/i] Last edited by coachgeo; 12-27-2005 at 05:58 PM. |
#21 (permalink) |
I did some searching and came up with below quotes
. just go to the metal yard and buy 1.90 x .134 wall tubing. It will work fine in the 1 1/2" pipe die . I thread the inside of the tubing with a pipe tap then fill it with water. . I have heard to use sand. . Difference (between tube bender and pipe bender) is primarily the size of the dies. I've found that you can take a piece of sheet metal about the length and width of the die and wrap it around the tube where you want your bend. Then make the bend slowly. The force of the bender will form the sheet metal into a little shim that takes the slack out of the die. It will also stay in the die and you can make multiple bends...This helps quite a bit. A tubing bender is still easier to use but this will make your bender useable . My dad bought on of these a while back, all it would do was kink stuff. The more we looked at it we noticed the dies didn't fit the pipe very well. So we heated them with a "rosebud" tip on the torch and beat them into shape. Cleaned them up with the grinder where they swelled a little from hitting them and now it works great. 1) Go Slow, if you try to pump them up fast they kink everytime 2) After the pipe tightens against the rollers 1 stroke of the ram is about 1 degree. 3) Be sure you aren't trying to bend too tight of a radius These are all from this thread http://www.pirate4x4.com/forum/showt...pe+bender+tube
It's a Daimler thing: You wouldnt understand! [i]"I work on a fishing boat. I started as a Apprentice Baiter. Now I am a Journeyman baiter. One day I hope to make Master Baiter". (By DEnd)[/i] Last edited by coachgeo; 12-27-2005 at 05:56 PM. |
#22 (permalink) |
Member # 37016
to make it work for tube you get a die smaller than the actual tube that your gonna be ebdning, than you grind out the die until the 1 3/4 tube fits tight in it. You should be able to get close to a 90* angle out of it. I did this on mine and built my whole interior roll cage and bedcage and engine cage with it.
#23 (permalink) | |
Member # 16024
I tried bending thin-walled tube once and had the same flattening problem. No problems bending pipe, however. It just smokes right around.
Check out UCORA.org VOTE or SHUT UP! Last edited by glfredrick; 12-27-2005 at 07:58 PM. |
#24 (permalink) |
Making your own dies.
here is something I wrote sometime back.
"What about having some hardass tube bent by a pro in a curve that is equivilant curve and cup to a die you want. Cut the thing lengthwise in half. Weld one half to the underside of the other half to increase the strength. Now you have something equivialant in shape to the part of a die that cups the tube as you bend. Now weld a plate on each side with some other gusseting. Another words, build a hollow die. Curved side is made up of the bent tube you cut lenghtwise to form the convex shape. Drill holes where neccissary and tada..... home made die. Will this work? or does my description totaly confuse you? __________________
It's a Daimler thing: You wouldnt understand! [i]"I work on a fishing boat. I started as a Apprentice Baiter. Now I am a Journeyman baiter. One day I hope to make Master Baiter". (By DEnd)[/i] |
#25 (permalink) |
Member # 14903
I see what you are saying and i guess that would work if you could get it all lined up and squared. But why not buy pipe instead of tubing??
