Iron Worker - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-30-2005, 10:58 PM   #1 (permalink)
I make websites!
Member # 12429
Iron Worker
Who has an Iron Worker and how do you like it?
I`m looking at them and they come in 25ton to 100+ ... What do you use yours most for and what's it rated at? Do you need more?
Lemme know!
My 4x4 Blog
Rockwell axles too!
Todd W is offline   Reply With Quote
Old 12-30-2005, 11:01 PM   #2 (permalink)
AprilzWarrior's Avatar
Member # 21033
Lemme know!
Im my dreams...
I want the JAWS IV 50Ton
http://www.vansantent.com/ironWorkers/jaws.htm
AprilzWarrior is offline   Reply With Quote
Old 12-31-2005, 11:59 AM   #3 (permalink)
nilla's Avatar
Member # 9017
I don't personally own one, but i've used
the one at my uncles shop. its a geka 55 ton.
He's had no complaints about it.
heres a pic of it
nilla is offline   Reply With Quote
Old 12-31-2005, 12:39 PM   #4 (permalink)
I make websites!
Member # 12429
heres a pic of it
What features did you use most?
What did you want to change?
My 4x4 Blog
Rockwell axles too!
Old 01-01-2006, 02:16 PM   #5 (permalink)
Member # 6848
Adam Ant just bought one...
Jack
71 1-ton EB
BITD 7200
IronBenderII is offline   Reply With Quote
Old 01-01-2006, 02:56 PM   #6 (permalink)
Member # 14406
we have a 50 ton at school and it just plain rocks i've been using it for 4 years no probs
with the one end you can you it as a punch press or brake and it has the shear in the middle and on the other end is the nibbler to fine tune you rough cuts (sure does make it alot easier cleanup with the sander after)
when i win the lotto i'll buy the same one other than that i have a lifetime usage agreement to use the one at school (teachers pet )
heres the link:
http://www.megamfg.com/p50.html
(tow/ weekend rig) 70k5 d60/14bolt 450hp 406sb 35's
(DD) 86 sami 1.6td
www.acmeadapters.com
www.sky-manufacturing.com
k5ryanNC is offline   Reply With Quote
Old 01-01-2006, 03:47 PM   #7 (permalink)
I make websites!
Member # 12429
Jack
Yeah - was hopnig he could chime in.
Maybe I`ll get some free time and go over to his place and chek it out
My 4x4 Blog
Rockwell axles too!
Old 01-03-2006, 07:49 AM   #8 (permalink)
Member # 191
I have a scotchman 90 ton unit at home. Mostly use it for the shear and
brake functions.
haven't honestly used it alot. yet. the punch function is really nice if you're
doing alot of the same sized holes in work. it takes about 10 minutes to
change punch bits. Mine came with a rod shear, and angle shear, the brake
attachment (mine is the 30" brake which is no longer available).
the slotted punches are really neat. there are also square punches too.
I really don't have an efficient place to arrange mine to use it often, so it
kind of sits alot.......
--Sherpa
[QUOTE][i]Originally posted by LAME [/i]
[B]
The guys designing cages for the D9 dozer on your Christmas list are going about this a bit differently way then a few rednecks, too much beer, and a JD2:D [/B][/QUOTE]
SHERPA is offline   Reply With Quote
Old 01-03-2006, 12:30 PM   #9 (permalink)
Got it !
Adam Ant's Avatar
Member # 2148
Send a message via ICQ to Adam Ant Send a message via AIM to Adam Ant
you should come buy and use it( then you will find out alot)
I did alot of research before this machine and the Porta Fab 45 is the Best bang for your buck. I looked into bigger machines but they dont change capacity untill you get into the 60 + tons to matter,
I do alot of suspension work ( alot) and it helps with all the holes I put into stuff
puching 1/4 3/8 and 1/2 inch material is a breeze speeds up production stuff fast,
I had a budget an I stayed right there.
I looked into every machine offered and could give you the diff benifits of each one
I have all the dies up to 1 1/2 and 3-1 toolshear and round cutoff and angle iron shear, 12 inch brake.
the 45 ton unit bends 3/8 plate with ease
once you have one you will wonder what you ever did without it
no more hole saw action LOL
Adam Ant,
Custom Fabrication, Bomb proof link susp and Hardcore parts, check us out on the web
AA-Fabrication
03 Dodge2500 4X4 CTD Laramie package with seat warmers
69 Jeep/ sand ride in progress. the go fast ride!
Adam Ant is offline   Reply With Quote
Old 01-03-2006, 12:36 PM   #10 (permalink)
Got it !
Adam Ant's Avatar
Member # 2148
AA-Fabrication
Old 01-03-2006, 12:41 PM   #11 (permalink)
Got it !
Adam Ant's Avatar
Member # 2148
I like holes
Adam Ant,
AA-Fabrication
