Member # 39627
stick welding
I have a stick welder, and have been practicing for a while. but I am now looking for some tips, and tricks to make some better welds.
One question I have is there a way to clean the steel before I weld, Or do I even need to??? Thanks for the help.
35 MTR'S, ALLOY SHAFTS, ARB FRONT AND REAR,4.56 |
Member # 12247
Getting all the mill scale and/or rust and/or crud off the steel would give you a much better weld. I'd suggest to keep practicing in the form of "padding"... take a piece of 1/2" plate or thicker, about 6"x6" in size and run beads on it, keep running beeds till it's built right up. Once you have that down pat use the same approach except in a horizontal position, then verticle, then overhead. Stick isnt as easy as mig. Takes alot of practice but the resulting weld quality is worth the effort.
Keep the rubber side down ! |
Member # 18392
Having clean steel will make a huge difference in how it welds. Experiment with dirty / rusted steel, and then again after you clean it up with a wire brush and you will see the difference. A few minutes of time in cleaning prep is worth it.
#4 (permalink) | |
Addicted to Gear Oil
Member # 56050
Wire wheel on a 4 1/2 grinder works like a champ to clean up rusty steel before welding. Works good to clean off slag too.
Keep laying beads
1965 Scout 80 7.3PSD/ZF/203/205 D60F/14BFF Member: 4 Jackstand Wheeler's Association Quote:
David H. Petraeus for President 2016 |
Member # 39627
Yea I have been laying beads on a peice of scrape steel that has been given to me for a few monthes now. Just laying one bead after another. The person that gave me the welder showed me a little when I got it, but am now looking for some more tips. What Im getting from you guys was just keep practicing, which is what he told me to do. he used to weld ships togeather at a ship yard, so I trust what he says, but does live some distance away. .
The steel is in a L shape that a lot of large holes were drilled through, I was told to try to fill in the holes and to make the peice of steel one large solid peice of steel, one bead ontop of another. I still think he is crazy telling me to fill it all in and make one 2" think peice of steel. But maybe you can help with some more specific questions. I need some teqniques on filling holes. I can lay a bead well but when it comes the try and fill in holes Half the time I can fill it in, and the other half of the time I make the hole larger. I keep turning the welder to 90, What happens to my welds If I turn it up or down. what happens if you weld ontop of schlag, if you didnt chip it off at all or if some small peices didnt get taken off. And most importantly is there a eaiser way to get schlag off.
35 MTR'S, ALLOY SHAFTS, ARB FRONT AND REAR,4.56 Last edited by desertsport; 01-08-2006 at 06:36 PM. |
#6 (permalink) | |
B-RAD Fabrication TDO DYSFUNCTIONAL ROCKCRAWLERS |
#7 (permalink) | |
Member # 12247
Member # 39627
I let you know what welder and rods im using now. The girlfriend wants me to spend some time with her now. thanks for the help so far. talk to you omarrow.
