new tube bender tool - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-10-2006, 01:02 PM   #1 (permalink)
Member # 13002
While looking throught the March 2006 issue of 4Wheel & Offroad they have a bunch of pictures from the Off Road Expo. One of the pictures is a tube bender that they've put some sort of rack and a gear box tomake it a somewhat non maunual bender. I went to there website, www.jmrmanufacturing.com but they have zero about it. Anybody seen this thing in person or have any details?
Jesse Angel is offline   Reply With Quote
Old 01-10-2006, 01:32 PM   #2 (permalink)
Member # 42292
i have used one. It is pretty sweet. easy to use and with the ratcheting gear mechanism, it is very easy to make identical bends... I would recomend it to anyone
jeepn4life is offline   Reply With Quote
Old 01-10-2006, 03:01 PM   #3 (permalink)
Member # 13002
I wonder about pricing. It looks alot cheaper than hydraulic ram setup and using an air ratchet whould be pretty fast and slick.
Old 01-10-2006, 08:23 PM   #4 (permalink)
Member # 42292
air ratchet probably not strong enough, and it is engraved right on there, NO IMPACTS. So a standard 12" ratchet is the way to go. Not as fast as hydro, but easy, cheaper, and accurate
Old 01-11-2006, 06:41 AM   #5 (permalink)
SHOOT TO THRILL!
300sniper's Avatar
Member # 26382
their notcher looks good. i have been thinking about making my own so i can make notches in a radius. it sounds like this could do that and it looks pretty stout. i have not seen the bender.
300sniper is offline   Reply With Quote
Old 01-11-2006, 07:26 AM   #6 (permalink)
Member # 25717
I was also interested in the ratcheting manual bender... until I found a vendor that sold them. The price wasn't on the JMR website, but if you search for their vendors you can find it. The price was $1295! No thank you, I'll stick to the one I've got. I think the vendor was VanSant Enterprises.
95 YJ, dual Dynatrac 60s, Detroit front, spool rear, 4.3 Chevy, SM465, Atlas II, 5.13s, 42 x 15 TSLs, MRT Beadlocks, etc.
ky1tonyj is offline   Reply With Quote
Old 01-11-2006, 07:41 AM   #7 (permalink)
Member # 42292
the notcher does work well and lets you notch in a bend some what
Old 01-11-2006, 09:43 AM   #8 (permalink)
Member # 13002
I was thinking that this might be an easy and cheaper way to bend than getting all the hydraulic parts, but sounds like I'll keep bending by hand!!
Old 01-12-2006, 01:02 AM   #9 (permalink)
92 Green YJ's Avatar
Member # 16505
Send a message via AIM to 92 Green YJ Send a message via Yahoo to 92 Green YJ
I actually spotted one of those over at ORW the other day, right before my subscription issue showed up with the pic. ORWs price tag on it is 295. bout the same as the JD2.
92 Jeep Wrangler.
RE 4" Lift, AR 767s with DIY Beadlocks, 35"x12.50" Xterrains, OBA, BTF Tube Fenders, BTF Comp Cut Corners, AA SYE, CV shaft, Warn M8000, Flow Kooler, MSD 6, 8.8 with ARB, , too much to list.
92 Green YJ is offline   Reply With Quote
Old 01-12-2006, 11:00 AM   #10 (permalink)
Member # 25717
Trick-tools.com lists the 1000M manual bender for $1295. That is the one with the gear, tooth, and ratchet assembly. Definitely not $295, although we may be talking about a different bender.
Old 01-12-2006, 01:58 PM   #11 (permalink)
Member # 16505
could be a iread the tag wrong, it was kinda fuzzy and i was irritated that this was the fourth store i had gone to that didn't have a centering pin i needed in stock
92 Jeep Wrangler.
