Member # 64230
Gear install tools
I'll be doing gears on my yota in the next couple months (never done them before) and I know that I need a press/puller, torque wrench (got that), 30mm socket, dial indicator and some type of stand. What other tools am I going to need and who would you recommend me purchasing them through? Thanks guys.
Member # 55920
You'll want some gear marking compound. The yellow GM gear marking compound works good although it is a bit expensive. See the parts guy at you local GM dealer. I tried prussian blue and it sucks, the GM stuff makes it much easier to read a pattern.
#3 (permalink) | |
Addicted to Gear Oil
Member # 56050
Search the for gear installs this is covered quite often. Here's a good write up for Toyota gears: http://www.4x4wire.com/toyota/tech/gear_setup/
Plus I'm sure there are a bunch on PBB, too. You'll also need an INCH LB torque wrench, (I got a snapon dial in/lb torque wrench from a pawn shop for about $60) but you can find them several other places also Randy's Ring and pinion sells them and so do these guys http://completeoffroad.com/wsm/c-21_...ial_tools.html I got most of my other tools from Harbor Freight: dial indicator, micrometer, calipers, bearing splitterm etc
1965 Scout 80 7.3PSD/ZF/203/205 D60F/14BFF Member: 4 Jackstand Wheeler's Association Quote:
David H. Petraeus for President 2016 |
