Piping for compressed air - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-17-2006, 05:49 PM   #26 (permalink)
Member # 1926
Originally Posted by caryt
My last shop I used copper..type L, cheep easy and I silver soldered everything with 15%!
cary
Silver solder would give you the strongest joint. Not sure if it is needed for 125 PSI though.
'69 FJ40 with very few stock parts.
2000 Cummins with some goodies to make it smoke.....
Trail Gear's Bad Ethics=Bad Business.
fj40charles is offline   Reply With Quote Quick reply to this message
Old 02-17-2006, 07:52 PM   #27 (permalink)
Member # 66862
Originally Posted by rusted
You can use a Franzinator.
And what are you gonna do this this dumb thing?
stingthieves is offline   Reply With Quote Quick reply to this message
Old 02-17-2006, 07:57 PM   #28 (permalink)
Member # 66862
and what do you plan to do with this waste of time?
Old 02-18-2006, 09:34 AM   #29 (permalink)
Member # 27775
I am a HVAC contractor so doing it that way is easy and faster for me to do! I run 175lbs in the lines.
Cary
caryt is offline   Reply With Quote Quick reply to this message
Old 02-18-2006, 10:35 PM   #30 (permalink)
section525's Avatar
Member # 14692
Send a message via AIM to section525 Send a message via Yahoo to section525
Originally Posted by ironpig70
when you do your drops turn thr "T" upside down and then put in a short straight piece and then an elbow, then your drop. what this does is keep water in your supply line and not in your tools. a cheap trick to do if you do it when building a system.
I just finished doing my garage just like this:
section525 is offline   Reply With Quote Quick reply to this message
Old 02-18-2006, 10:56 PM   #31 (permalink)
Member # 35687
http://img.photobucket.com/albums/v6...rSeparator.jpg
My Franzinator
HossCat is offline   Reply With Quote Quick reply to this message
Old 02-18-2006, 11:54 PM   #32 (permalink)
Rotten Sperm
Nordic1's Avatar
Member # 63386
So officially silver solder is the strongest right? That or just tig everything
Nordic1 is offline   Reply With Quote Quick reply to this message
Old 02-19-2006, 08:30 AM   #33 (permalink)
Banned
Member # 5670
so anyone have any comments on the products listed in the original post?
Pavemen is offline   Reply With Quote Quick reply to this message
Old 02-19-2006, 01:06 PM   #34 (permalink)
PAToyota's Avatar
Member # 37600
Send a message via AIM to PAToyota Send a message via Skype™ to PAToyota
Yep, the kits mentioned at the start are nice and probably go together slicker than snot. But I about fell out of my chair when I saw the prices.
94 GMC 6.5TD K1500 Yukon SLE / 93 Chevy 6.5TD K2500
85 Toyota 22R RN60 4x4
PAToyota is offline   Reply With Quote Quick reply to this message
Old 02-20-2006, 02:49 PM   #35 (permalink)
Member # 67518
Send a message via AIM to antipro
as a plumber in our garage we have copper for the main part and pex that connects that to the compreser. copper is 10x easyer then steel pipe and pex is 10x easyer then copper
-steve-
i do front digs in my car to get in and out of parking spaces
antipro is offline   Reply With Quote Quick reply to this message
Old 02-24-2006, 01:36 PM   #36 (permalink)
Hendo's Avatar
Member # 20295
Send a message via MSN to Hendo
useing silver solder is way over kill and costly compared to solder,with air you dont even need type L copper M is surficiant and believe me sweating pipe is way easier than threading
Hendo is offline   Reply With Quote Quick reply to this message
Old 02-24-2006, 06:10 PM   #37 (permalink)
Member # 27775
Ya I know but I bought it by the pound and have lots of it
Cary
Old 02-25-2006, 06:07 AM   #38 (permalink)
Member # 10115
I've done both copper and galv. pipe that comes pre-threaded (I had to get the HD guys to cut and thread a few off size pieces, but that was no problem really). Both worked just fine. Copper is way eaiser to work with and put together - not to mention cleaner as you don't need any thread sealant.I've got several moisture traps and drains and an air drop about every four feet with an extra one overhead. I'll be running one more through the wall to the pad next to the garage when I get around to it. The only leaks I've had with either system was an occasional bad quick disconnect.
To each his own, but I personally don't see the point in dropping a ton of money on some snazzy manufactuerd air piping system when a snazzy copper or galv. pipe system can be had for way less...
69CJ is offline   Reply With Quote Quick reply to this message
Old 03-19-2006, 07:09 PM   #39 (permalink)
jeeppoor's Avatar
Member # 54928
OK school me on why I should not use PVC or CPVC pipe. I know a few people that are using pvc pipe and have for over 10 years with no problem.
I never thought of copper. I just knew that I did not want to do it with steel pipe. With the threading and all.
Oh yea. This will be going in a garage / shop that is heated all year. It never gets below 45 degs.
Living the dream one day at a time.
It's going to be a good day tater
Swamp Stompers 4x4 club.
jeeppoor is offline   Reply With Quote Quick reply to this message
Old 03-19-2006, 08:29 PM   #40 (permalink)
Rotten Sperm
Nordic1's Avatar
Member # 63386
Technically... PVC COULD work... People use PVC for all sorts of things (sprinklers, general plumbing.... potato guns )... Some of these things excede (sp?) 125 psi which is what our water preasure is here. Who could say that an additional 25 psi (to make 150 psi) isn't possible?
At the same time, I cringe at the thought of a PVC pipe exploding (or whatever you would want to call it) if I smacked into it with the truck, something heavy or other-wise.
Old 03-20-2006, 02:34 AM   #41 (permalink)
w83toy's Avatar
Member # 37383
The shop I'm in was plumbed with PVC pipe in the walls by the person who built it and guess what happened the first time it was hooked up. Leaks could be heard all over the place inside the walls hehe. We re-plumbed everything with copper and have zero leaks, pressure gauge still says 120 psi the next morning. Just recently expanded into another shop which had the remains of a PVC system, we put in all copper again. Goes really quick if you know what you're doing and will last a long long time.
w83toy is offline   Reply With Quote Quick reply to this message
Old 03-20-2006, 07:55 AM   #42 (permalink)
Member # 14584
Are those joints soldered yet? Mine are discoloring like crazy. I'm wondering if Im using too much heat or what. I bought some extra fittings to practice(learn ) with. I could see inside the fitting after I was done and the solder made it all the way through which is important right.
Im using lead free solder and one of those little bernzomatic type torches.
Yes my truck is environmentally friendly.
It lets most of the environment in the truck with you!
6869704x4 is offline   Reply With Quote Quick reply to this message
Old 03-20-2006, 07:57 AM   #43 (permalink)
PAToyota's Avatar
Member # 37600
PVC can work as far as the pressures go. The problem is when it stops working... PVC is brittle and you get shrapnel. Not just a matter of the pressure blowing the pipe - what about something accidently hitting it?
The chances of black pipe going at the pressures being used is limited and it will take a pretty good blow as well. Again, copper is unlikely to go from pressure and if hit it will only rupture and all the air escapes. Although PVC can take the pressure, if something smacks it and it breaks you have shrapnel going everywhere. I've seen the aftermath - plastic shards embedded in drywall and wood...
Now imagine standing next to it... Not something I want to take a chance on...
Old 03-20-2006, 10:43 AM   #44 (permalink)
section525's Avatar
Member # 14692
Nope. That was just mocked into place. I used the exact same stuff you're using. Sounds like you're doing it right.
Old 03-20-2006, 04:59 PM   #45 (permalink)
Member # 68414
piping
I never considered using copper or iron pipe. My dad piped his with pvc when i was a kid, did the same at his new house and so did I. Never had any problems. We just used the plain sch 40. The Sch 80 is stronger yet. I don't have any problems with leaks or breakage.
Tom
huntingaddict is offline   Reply With Quote Quick reply to this message
Old 03-20-2006, 05:17 PM   #46 (permalink)
Member # 29527
Wow. PVC is pretty hard to fawk up. I've never had a PVC joint leak, and I've done a fair bit, between landscape irigation work and air piping. The builder must have done something *really* whack
The original Fuckwad Penis.
CrustyJeep is offline   Reply With Quote Quick reply to this message
Old 03-20-2006, 06:00 PM   #47 (permalink)
Member # 16024
If you are going to use PVC use schedule 80 -- about double the rating of the more common schedule 40 stuff, which WILL blow up on you -- and at the worst possible moment.
Also know that some of the new ester oils in use by major compressor manufacturers eats PVC. Make sure your system is compatible. I get to change out all the air lines in the place where I work -- we just found out the hard way about the oil deal -- our compressor relief failed and we blew out a couple feet of PVC (schedule 80) and the insides were rotted away worse than rusty steel.
I like the idea of using the poly truck lines w/compression fittings for a home shop though. That might be the best bet from cost and ease of use.
Check out UCORA.org
VOTE or SHUT UP!
glfredrick is offline   Reply With Quote Quick reply to this message
Old 04-22-2006, 10:46 AM   #48 (permalink)
Member # 14584
Finished my copper air line a couple of weeks ago. I had to resolder one joint which is better than I expected since Ive never worked with this stuff before. I downloaded some info on working with copper from a link on garagejunkies. Anyone thinking about using copper I would say go for it.
My 175 PSI compressor and lines.
Some ugly soldering
Line going to cieling for reel hose
The fitting I had to resolder.
Old 04-22-2006, 11:37 AM   #49 (permalink)
Rotten Sperm
Nordic1's Avatar
Member # 63386
Nice... I'm doing copper in my garage now... I'll post pics of it when I am done
Old 04-22-2006, 09:16 PM   #50 (permalink)
CJ
Member # 71
Get rid of the galv and black iron fittings in the last picture and replace them with brass. Iron and copper are dissimilar metals and you will have electrolysis. The first pisture is ok, the rubber hose will act as a die-electric.
Some ugly soldering
Matt
81 CJ7
