Removing broken bolt extractor? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-08-2006, 08:25 AM   #1 (permalink)
AbnRgr375's Avatar
Member # 37832
I run into this at work and at home all the time. I have used extractors from Snap-on to Harbor Freight and they all suck! But how the hell do you get the broken extractor out of the bolt that you are tring to extract. I have trashed many a good drill bit tring to drill a new hole around the broken extractor. Is there a superduper drill bit that can drill through tool steel? This can also apply to a broken drill bit. Arrrrrrrrrggggggg!!! Any helpful ideas are appreciated.
[CENTER][FONT="Franklin Gothic Medium"][SIZE="2"][B][COLOR="Red"]The Ultimate Measure Of A Man Is Not Where He Stands In Moments Of Comfort,
But Where He Stands At Times Of Challenge And Controversy.[/COLOR][/B][/SIZE][/FONT][/CENTER]
AbnRgr375 is offline   Reply With Quote Quick reply to this message
Old 04-08-2006, 09:10 AM   #2 (permalink)
bigtoy302's Avatar
Member # 36440
EDM machine, Thats how we burn out taps all the time at work.
bigtoy302 is offline   Reply With Quote Quick reply to this message
Old 04-08-2006, 10:40 AM   #3 (permalink)
Member # 48732
Send a message via AIM to 70cyclone Send a message via Yahoo to 70cyclone
works great...too bad most people have no access to one...
77 F150 new project 545/C6/205/rockwells/53s
79 Bronco (parting out)
85 Bronco 351W/C6/208(parting out)
01 F350 PSD 4x4
70 Mercury Cyclone Spoiler 429CJ/4sp
70 F250 crewcab shortbox
89 F350 4x4 460/ZF
93 Mark VIII 4.6 Cobra
66 Dart GT convertible
70cyclone is offline   Reply With Quote Quick reply to this message
Old 04-08-2006, 12:09 PM   #4 (permalink)
Member # 37519
Yeah, I think he was looking for a more availible sollution
[COLOR="Black"]..............[/COLOR]//)
[COLOR="Black"]............[/COLOR],/../
[COLOR="Black"]...........[/COLOR]/..../
[COLOR="Black"].....[/COLOR]//'...'/`
[COLOR="Black"]..[/COLOR]/'/.../..../......./\
[COLOR="Black"].[/COLOR]('(.......... ~/'...')
[COLOR="Black"]....[/COLOR]\.................'...../
[COLOR="Black"]......[/COLOR]''...\.......... _.
[COLOR="Black"].......[/COLOR]\..............(
[COLOR="Black"].........[/COLOR]\.............\
mudslinger99 is offline   Reply With Quote Quick reply to this message
Old 04-08-2006, 12:54 PM   #5 (permalink)
rockcrawln's Avatar
Member # 30586
I know a place in San Dimas but I can't find his phone #. Hes a great guy and might be able to do it while you wait. If you want I can give you his location and you can drop by and see what he says.
rockcrawln is offline   Reply With Quote Quick reply to this message
Old 04-08-2006, 01:27 PM   #6 (permalink)
Member # 5286
Send a message via Yahoo to Jason M
Never EVER use a screw extractor. just drill out the bolt and retapp the hole.
DEAR MADAM:
THANK YOU FOR YOUR RECENT ORDER FROM OUR SEX TOYS WEBSITE.
YOU'VE REQUESTED THE LARGE RED VIBRATOR AS FEATURED ON OUR WALL DISPLAY.
PLEASE SELECT ANOTHER ITEM.
THAT'S OUR FIRE EXTINGUISHER
Jason M is offline   Reply With Quote Quick reply to this message
Old 04-08-2006, 07:19 PM   #7 (permalink)
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
Since most of us don't have access to a EDM or even if we did, pulling the engine to get the bolt that broke off in the block aint exactly the best option
I've had good luck with a carbide dremel bit (1/8" bit round nose cost about $8 at walmart, lowes, etc) with a dremel tool or die grinder to cut harded steel i.e. a broken drill bit, tap, or "E-Z- out" That little carbide bit can zip through some pretty tough steel!
Give that a try and see if that works for you. I've rarely had good luck with an EZ-out extractor. They rarely work (unless the bolt just broke not frozen or rusted) and usually snap off at the worst time leaving you with a broken bolt with a chunk in hardened steel in the center.
Better to drill out, then chase/rethread the threads with a tap.
guidolyons is offline   Reply With Quote Quick reply to this message
Old 04-08-2006, 08:13 PM   #8 (permalink)
Member # 2790
I have heard of people using a masonary bit for that.. I personally have not tried it but will next time I break one..
Russ
hy_desert_4wheeler
46 Dodge WC15--67 M715--85 Jeep CJ10A--06 Dodge Ram2500Quad cab Cummins--94 Suburban--06 Ridgeline-
hy_desert_4wheeler is offline   Reply With Quote Quick reply to this message
Old 04-08-2006, 08:52 PM   #9 (permalink)
Member # 4878
Send a message via ICQ to Travis Waldher Send a message via MSN to Travis Waldher Send a message via Yahoo to Travis Waldher
It works on spring steel.... but an easy out?
That might be worth a try just as a bench experiment.
Travis Waldher is offline   Reply With Quote Quick reply to this message
Old 04-08-2006, 10:04 PM   #10 (permalink)
Member # 42567
Try a chisel or punch to break the extractor. They are difficult to drill out but are more brittle. Not fun but can be done.
Rory Bellows is offline   Reply With Quote Quick reply to this message
Old 04-08-2006, 10:55 PM   #11 (permalink)
quadrunner's Avatar
Member # 13924
Send a message via AIM to quadrunner Send a message via Yahoo to quadrunner
Here is a little trick we use at work.
Get a nut just a little larger than the bolt that you broke off and set it over the broken piece. Get your welder out and weld that nut to the end of the broken bolt. This works great in 2 fold. The nut gives you a place to wrench to and the heat from the welding helps loosen the rusted bolt. If you break the nut off (this happens all the time) just grab another nut and weld it on and try it again.
If you really wanted to drill HS steel bits you need a Carbide drill bit. They are spendy and very brittle. If you drop it on the cement it could break!
[FONT="Verdana"][SIZE="1"][B]'88 4-Runner[/B] 3.4L Supercharged V6 w/ SDS Stand Alone Computer, R-151 w/ Dual T-Case & 4.70 Gears in rear, SAS, 5.29, ARB Front & Rear, RS 9012 W/ in cab controller, U-Bolt eliminator Front, Shaved Front/Rear Axle, OBA w/ 6gal. tank, Hy-Steer crossover steering, Full Floater Rear, Hydro-Assist.[/SIZE][/FONT]
quadrunner is offline   Reply With Quote Quick reply to this message
Old 04-09-2006, 07:00 AM   #12 (permalink)
krb
krb's Avatar
Member # 7692
The drill bit would have to carbide.
If the surface is uneven(like where the extracter broke off) the bit would more than likely chip due to it being very brittle.
Another choice instead of EDM would be to place the part on a mill(part clamped in vise if allowed)and use a carbide endmill to remove broken extractor.
I do this at work to remove broken taps.Endmills hold better than drills.
I would also try using a punch and hammer.Sometimes the hardend material (extactor)will chip into peices.
'85 CJ7,SOA,36" IROCS,9" HP Currie/Detroit,44 spooled,Tera Low,Warn 9000I,Mopar F.I.,Premier Welder
krb is offline   Reply With Quote Quick reply to this message
Old 04-09-2006, 07:32 AM   #13 (permalink)
Member # 67355
heat up the broken ez out red hot then let it cool then you have plain old steel
groundloopdog is offline   Reply With Quote Quick reply to this message
Old 04-09-2006, 08:28 AM   #14 (permalink)
MattyL13's Avatar
Member # 32766
Send a message via AIM to MattyL13
not exactly....but what he is talking about is annealing the tool steel. it will make it softer and will allow you to drill through it easier. the reason you cant drill out the easy out is because both the drill bit and easy out are of an equal hardness. to cut or drill something, you must use a tool that is harder than the material youre trying to cut. if youre gonna try to anneal it, DO NOT dump water on it to make it cool. you msut allow it to slowly air cool.
on a side note, i never had too much trouble with easy outs. if you use them properly theyre great. you want to use the biggest one you possibly can. you always want to the drill the biggest hole you possibly can. you will also want to use some penetrating oil or rust breaker-offer. also you can feel when an easy out is about to break, and if you see its under alot of tension, back off a little bit.
HTH
If it aint broke fix it till it is
To the pessimist, the glass is half empty, to the optimist, half full, to the engineer, the glass is twice as big as it needs to be.
00 TJ. 318, NV4500HD, 231, 44 locked on 35's. Work in progress
MattyL13 is offline   Reply With Quote Quick reply to this message
Old 04-09-2006, 09:01 AM   #15 (permalink)
Member # 12499
Be CAREFUL with this method. I tried it with a broken tap and still have a chunk of HSS tap in my chest. It hit an artery and I bled real bad, real,real bad.
PTSchram is offline   Reply With Quote Quick reply to this message
Old 04-09-2006, 09:35 AM   #16 (permalink)
AbnRgr375's Avatar
Member # 37832
Thanks for all the ideas. I have tried the hammer and chisel method and I have used the weld the nut on the remaining bolt when it is possible. If I have one break at the house I will try the rosebud on the O/A. However when at work some of the suggestions would be impossible to use as I am a on the road forklift tech. and dont always have access or ability to use an EDM, mill or things along those lines. I would prefer not to use extractors and drill out and retap the hole but not always possible. I am gonna have to try the carbide tip on the dremel. Once again thanks for all the suggestions.
Old 04-09-2006, 04:43 PM   #17 (permalink)
Member # 8211
I've used the welded nut approach many times. Sometimes you can't get at it with a nut in the way, or can't hold it in place, or even a bit below surface level. In those cases I have actually managed to build up a bead on broken bolts as small as 5/16 till I get it above level, then grab it with a vicegrip to turn it out. Did this recently on a D60 knuckle steering limit bolt that was broke off about 1/16 below the surface while trying to back it out. Took about 3 tries before it came out clean. Last one before this one I broke an ez-out off and just welded both pieces together to remove it. This combination of “heat shock” (much more violent than torch heating) and giving you something to hold onto will get out most any bolt in my experience.
Russ
85 K30 truggy, 350 TBI, TH350, 203/205, D60/C14, 4.56 Locked, 42" TSLs, 4" lift, 112" wheel base, front leafs, rear double triangulated 4 link with coils.
BadDog is offline   Reply With Quote Quick reply to this message
