Member # 14687
what kind of solvent for cleaning heads and tops of pistons?
got an engine torn apart to replace a head gasket and figured i would get things cleaned up while im in there. What do you guys use?
Thanks |
IH/Rover Moderator
Brake clean.
I like beer. On occasion, I will even drink beer to celebrate a major event such as the fall of communism or the fact that the refrigerator is still working." BUY MY BOAT http://www.pirate4x4.com/forum/misc-...e-history.html |
Member # 50092
Carb cleaner does a decent job at cleaning stuff up, but nothing really dissolves carbon, or at least nothing I have found yet. Use a blunt plastic scraper to help break it up. Make sure you dont get any pieces of carbon on the sides of the pistons because it will score the hell out of the bore. Add a little bit of MMO to the cylinder walls and allow it to seep down to the rings because the carb cleaner will dissolve any remaining oil on the walls.
Just my .02 Jim |
I have always used a wire wheel on carbon deposits with great sucess , followed by cleaning with a carb or brake cleaner
NorCal Tree Expert Co. (530)527-2844 Need tree trimming/removal , need defensible space ? Call us ,insured and licensed . Serving Tehama, Glenn, Shasta and Butte County |
Member # 18989
A can of GM top engine cleaner is the best I have ever used.
A flash of lightning illuminated the object, wretch, hideous, filthy daemon. A new species would bless me as its creator. |
if you are not removing the pistons I'd just leave the carbon alone. It's gunna come back either way, and you run a serious risk of fawkin up your walls if you're not uber carefull. When you run it again just run some sea foam through it to clean it up.
QUOTE=TheHawes;15027873 If it wasn't for pussy, I'd hunt them fucking things. |
#8 (permalink) | |||
IH/Rover Moderator
#9 (permalink) | |
#10 (permalink) | |
IH/Rover Moderator
Member # 24640
last time I replaced a head gasket I tried easy-off oven cleaner...with a little elbow grease it cut right thru the carbon deposits
Co-Driver 4447 Camco Rock Racing Thanks to our partners: Bulldog Winch, Jackson Powertrain, Winchline.com, BFG, Raceline wheels |
