How are you folks dealing with low garage doors? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-25-2006, 04:17 PM   #1 (permalink)
Member # 71337
Obviously, my build will have some bugs to sort out. But getting it in and out of my typical garage door with the build complete is going to be a problem.
I know some have commercial doors on your shops, but others have to be in a regular garage. Are you guys putting on old rims with no tires on every time you bring the truck in?
Thanks
Roy
No one here is gunna caress your nut sack. We tell it how it is.:flipoff2:
Roy's Rustbucket is offline   Reply With Quote
Old 06-25-2006, 04:20 PM   #2 (permalink)
Member # 23939
I just air down my tires to about 3lbs, I have a set of small tires that i sometimes use as well.
96 S-10 D60/70
JNoble is offline   Reply With Quote
Old 06-25-2006, 09:29 PM   #3 (permalink)
Member # 20092
A set of 205/60-R16s on some 8 lug wheels. It's me low rider jeep in and out of the garage.
yes, it looks ridiculous.
'94 Toyota Land Cruiser FJZ80 - Vortec L33 5.3l, 4L60e, elocked, 3" OME lift, 315 KM2s, Warn 8074.
rock-rod is offline   Reply With Quote
Old 06-25-2006, 11:54 PM   #4 (permalink)
Peter_C's Avatar
Member # 34538
I will be there someday when my rig actually leaves the garage. I plan on using my winch to suck the front end down, then ratchet strap the rear down until it fits under the door.
Peter_C is offline   Reply With Quote
Old 06-26-2006, 12:38 AM   #5 (permalink)
90Beater's Avatar
Member # 52074
I have a 10 foot garage with a typical 6.5' door. I removed the top off my Bronco to fit the back end in and use my two 29" spares in front to slip under the door. I just completed my solid axle swap today and it worked for me. When I get bigger tires it might not work anymore.
[URL="http://bronco.tophersworld.com/"]Bronco.tophersworld.com[/URL] 1990 Full Size Bronco Camo Paint SAS 8 Lug. D44 Front 14B Rear
90Beater is offline   Reply With Quote
Old 06-26-2006, 06:38 AM   #6 (permalink)
Member # 25999
Send a message via AIM to CanuckJeeper Send a message via Yahoo to CanuckJeeper
Deflate to 2-3 PSI... ratchet strap the springs down, or use the front winch to bring down the front, etc.
JP
CanuckJeeper is offline   Reply With Quote
Old 06-26-2006, 08:32 AM   #7 (permalink)
Member # 71337
Thanks for the replies. I never thought of the ratchet-strap idea.
Roy
Old 06-26-2006, 08:50 AM   #8 (permalink)
tdavis's Avatar
Member # 908
I am getting my garage door re-hung later this summer.
It was installed with what is called "low profile" tracks. These tracks make the garage door hang below the opening. I have the space above the door in the roof, so I'm having it re-hung and rebuilt to be above the opening.
Of course, I'll have garage door opener problems; I have a cross beam that sits down and blocks where a normal garage door opener is placed. My solution is the opener goes above the beam; I've got a neighbor who did this.
I take my zuk out for walks.
tdavis is offline   Reply With Quote
Old 06-26-2006, 10:41 AM   #9 (permalink)
Member # 38771
The worst case I've seen was a friend's Willy's pickup on 1 tons. We had to roll it out on floor jacks with the rotors about an inch from the floor.
Joe
'88 GMC K5, lots of dents
'01 Chevy 2500HD D/A
"It's only sheetmetal!"
Joe_88k5 is offline   Reply With Quote
Old 06-26-2006, 10:45 AM   #10 (permalink)
Member # 5021
If it doesnt fit in the garage and its not a fullsize vehicle its too tall. Lower it 2" and enjoy the benefits of lower center of gravity.
Don't be "THAT GUY" on the trail.
www.voodoowax.com
The Rockslut is offline   Reply With Quote
Old 06-26-2006, 06:55 PM   #11 (permalink)
Member # 71337
The truck has no lift and 31's, but I'm building a custom body that is quite a bit taller than stock, and it has a roof rack.
Roy
Old 06-27-2006, 08:06 AM   #12 (permalink)
Banned
Member # 61591
we put 8' doors in my house when we first bought it. it was a full gut job. pier and beam, only original to the home now is the exterior brick. now i have a 2400 square foot shop in the back with 1500 square foot of office space above. the 8' doors made it so easy on the house i decided to use 8' on the shop with a high clearance door. works great for jeeps ad trucks cause i have a full 8' the money i saved from the doors (4- 16ft doors so i saved about 1200 bucks) topped off my equipment fund. basicaly see about getting the high clearance tracks and you will prolly be just fine. they will give you around another 5 or 6 inches overall.
clay
thejeepman4804 is offline   Reply With Quote
Old 06-27-2006, 08:17 AM   #13 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
damn buggys
I trimmed my header board, got me an extra 4 inches of height.
Mark
welndmn is offline   Reply With Quote
Old 06-27-2006, 09:39 AM   #14 (permalink)
Member # 5482
Hydraulics
Just suck it down
Mike Green -- Billyji
[url]http://www.blacksheep4x4.com[/url]
Just another guy on the Pirate4x4 board !
billyji is offline   Reply With Quote
Old 06-27-2006, 03:06 PM   #15 (permalink)
Banned
4RnrRick's Avatar
Member # 3933
or just put some bare rims on it....
But seriously - its too tall if it doesn't fit into a standard garage door. heck my new rig (toyota on 36" has 4-6" of clearance with 25 psi in the tires)
4RnrRick is offline   Reply With Quote
Old 07-01-2006, 08:07 AM   #16 (permalink)
donkeystompit's Avatar
Member # 68569
Had to do the bare rim thing at my old house. Works great until a friend gets in it and does burnouts in the driveway. Does quite a number to the concrete.
donkeystompit is offline   Reply With Quote
Old 07-05-2006, 10:35 PM   #17 (permalink)
Member # 10199
I wonder if you could get up to speed how it would turn in the dirt!!!!!!!!! DOIT DOIT
[url]www.bprfabs.com[/url]
BPRCJ is offline   Reply With Quote
Old 07-06-2006, 04:12 PM   #18 (permalink)
GySgt - Retired
Devil Dog's Avatar
Member # 11922
Send a message via MSN to Devil Dog Send a message via Skype™ to Devil Dog
cargo straps... i just compress the suspension.. i only need about 2" tho.. but i can get about 5" out of it..
Front Toward Enemy
2009, 2011 & 2013 King of the Hammers
BUCK Wild Racing
Team 911
Degenerate
Team 505
Team 488
O.G. "Wreckin' Crew"
Devil Dog is offline   Reply With Quote
Old 07-06-2006, 04:31 PM   #19 (permalink)
rdnkjeeper's Avatar
Member # 9501
Send a message via Yahoo to rdnkjeeper
I tore it down and built a bigger one......
rdnkjeeper is offline   Reply With Quote
Old 07-07-2006, 01:51 PM   #20 (permalink)
Member # 1690
Send a message via AIM to lcruzrlvr
I had dealt with a 6' 6" door for over 4 years - finally, couldn't handle it any longer and raised the door to 8'. The garage is under the bedrooms - had to build a temporary wall about 4' inside the garage to hold up the house above then demolished everything outwards, dropped in a 20' I-beam (400 lbs) into place, rebuilt the garage frame and the brick facade. Magic - 8' opening.
Now, my wife wants to sell the house....
Beer, its not just for breakfast anymore.
lcruzrlvr is offline   Reply With Quote
Old 07-07-2006, 05:57 PM   #21 (permalink)
Kenny714's Avatar
Member # 34803
Redneck, but it works.......
Kenny714 is offline   Reply With Quote
Old 07-07-2006, 06:25 PM   #22 (permalink)
Member # 71337
Thanks for all the replies. I'm renting, so changing the doors isn't an option.
Roy
Old 07-10-2006, 06:19 PM   #23 (permalink)
piratebuggy's Avatar
Member # 53597
Got a new garage door last year-went with the recommended low clearance tracks. The top section of the door has it's own track -so there are two tracks for the door to ride in. Got about 4-5" extra clearance when open. Bought a CJ later that fall and it barely clears-talk about good timing on the door purchase.
78 Jeep CJ-5 304 ---setting off car alarms with extreme prejudice.......
out cali style!!!!!!
piratebuggy is offline   Reply With Quote
Old 07-10-2006, 07:10 PM   #24 (permalink)
TNToy's Avatar
Member # 5776
What dude above said. Rigs are too tall.
My Toy is on 38.5" SXs, and fits in a regualr door with inches to spare. It also stays rubber-side-down more often, now.
[size=1]ASE Certified Master Automotive Technician
Toyota Certified Expert Technician
Volvo Certified Expert Technician
Suzuki Certified Master Technician
IDPA Certified Master Cardboard Killer[/size]
TNToy is offline   Reply With Quote
Old 07-10-2006, 10:49 PM   #25 (permalink)
WHATAHEEP's Avatar
Member # 46170
Build it inside the garage. Drive it out. Either the door will get high enough or the truck will get low enough.
I came to pirate for the love and hospitality.
WHATAHEEP is offline   Reply With Quote
