Is this angle finder any good? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-29-2006, 04:57 PM   #1 (permalink)
Member # 61487
I just ordered it to use with my tube bender (the home built one that bends up). I want it for its magnetic base, so i can stick it to the tube while i bend it.
Heavy Duty Protractor-Level— Two 25-lb. pull magnets hold this tool securely. Rotating dial has two 90° quadrants, graduated to 2 1/2° . Conversion chart shows degrees and rise per foot and per meter. Base has V-groove for working on rounded surfaces. Includes one level vial. Frame is cast aluminum. Size is 9" Lg. x 29/32" Wd. x 2" Ht.
mcmaster
part# 2145A11
BRAD D is offline   Reply With Quote
Old 10-30-2006, 05:04 PM   #2 (permalink)
Member # 9152
I would get a normal wheel-type protractor. You're looking at a pipefitter's tool. They don't bend pipe so they don't have to account for springback. You'd be fooling with that bubble way too much, and it would make bending harder than it needs to be.
Why kill them with kindness when you can use an axe?
78bronco460 is offline   Reply With Quote
Old 10-30-2006, 05:07 PM   #3 (permalink)
Member # 61487
I think the wheel spins.. just like a wheel-type
Old 10-30-2006, 09:23 PM   #4 (permalink)
Member # 9152
I don't think it does. Pipefitters set it to the angle then run their pipe to it when they have to maintain a slope in a run. I'm an electrician not a fitter, so maybe one will jump in here to confirm what I've seen em do.
This is similar to what I have used bending conduit for many years. They have one degree graduations and are easy to read. I might be too picky about the tools I use, but it's much easier to get accurate bends and duplicate parallel runs with this type of tool.
I'd rather use a tape measure a string and some trig than a fitter's level.
Old 10-31-2006, 04:55 AM   #5 (permalink)
Member # 12499
LOL! When helping folks build cages, if I dare utter the term calculator, I get run out of the shop! I'm sure the word trigonometry would get me shot!
Wrenchin' to riches!
If you want peace, prepare for war.
PTSchram is offline   Reply With Quote
Old 10-31-2006, 04:57 AM   #6 (permalink)
Lowtorious's Avatar
Member # 2387
Send a message via AIM to Lowtorious
This is the shit: Bosch digital protractor
http://www.toolbarn.com/images/bosch/dwm40l.big.jpg
~$100; Available from several places on line.
Lowtorious is offline   Reply With Quote
Old 10-31-2006, 07:43 PM   #7 (permalink)
Reprobate
jptbay's Avatar
Member # 35005
Send a message via MSN to jptbay
Smarttool electronic angle finder is a good option as well.
There are magnetic mounts available, and also a cool Mitler bros. plane of bend bracket (see picture). I have seen it at www.trick-tools.com They are a vender on this board.
The smarttool is available at sears as well. I saw it at www.sears.com for $75 with free shipping.
John.
jptbay is offline   Reply With Quote
Old 11-07-2006, 08:42 PM   #8 (permalink)
Member # 33167
After having used these at work for several yrs,i got myself one.
It is a Miracle Point.
http://www.erickmagnaholder.com/prot...er_finders.htm
87 Zuk Tin Top
rusty_scout is offline   Reply With Quote
Old 11-07-2006, 08:50 PM   #9 (permalink)
Member # 61487
Thanks for the tips.. the one I got was not what I thought it was
Old 11-07-2006, 10:25 PM   #10 (permalink)
I make websites!
Member # 12429
Here's one I found on amazon not to bad.
And the bosch one: here
Any idea why the bosch is bout 5x as much ?
My 4x4 Blog
Rockwell axles too!
Todd W is offline   Reply With Quote
Old 11-08-2006, 07:27 AM   #11 (permalink)
Trick-Tools.com's Avatar
Member # 32822
We have some pretty cool ones also.
http://vansantent.com/angle_finders_levels.htm
Christian Huffman
Trick Tools / Pirate 4x4 Sales
877-826-7268 Ext. 105
Christian@trick-tools.com
Trick-Tools.com
Shoot me a PM with your address for a Free Catalog!
Trick-Tools.com is offline   Reply With Quote
Old 11-08-2006, 08:03 AM   #12 (permalink)
4x Innovations
traxman25's Avatar
Member # 35227
Send a message via Yahoo to traxman25
Does the Bosch one find degrees from level if the angle finding arm is closed? I really just want a digital level basically. The Bosch one looks the best for the money because it can find angles too, followed by the smart tool from Trick Tools which is just a digital level. However if the Bosch only finds angles digitally and makes you rely on the bubble for making it level than it's worthless to me because I already have a nice small manual angle finder.
4x Innovations - Adam
Hardcore Toyota Rock Crawling Armor
1-608-348-4880
traxman25 is offline   Reply With Quote
Old 11-08-2006, 03:04 PM   #13 (permalink)
Member # 61487
Yeah i dont know if it does... but i like the looks of it.
Old 11-08-2006, 03:54 PM   #14 (permalink)
Member # 9152
If you're gonna spend the bucks, buy a SmartTools PRO 360.
http://www.smarttooltech.com/product.php?product=3
Old 11-08-2006, 04:17 PM   #15 (permalink)
Member # 10366
Leave it to a Fitter to invent a level that doesn't make things level. Damn Fitters!
Travis
IBEW Local 48 member
MOGXJ44 is offline   Reply With Quote
Old 11-08-2006, 05:47 PM   #16 (permalink)
www.12voltguy.com
SeaBass44's Avatar
Member # 40
these are the bomb
http://www.offroadfabnet.com/forums/...read.php?t=924
12voltguy
info@12voltguy.com--davezoffroadperformance.com
# 530.532.4529
TTC 2010 1989 BRONCO
-Awesome web development for your business. www.mudnworks.com mud@mudnworks.com
Pat's W I D E TOYOTA Front Axle
--07 KTM 450XC----with "stuff"
SeaBass44 is offline   Reply With Quote
Old 11-10-2006, 09:44 AM   #17 (permalink)
KYOTA's Avatar
Member # 19967
Does the Bosch one find degrees from level if the angle finding arm is closed? .
nope, but other than that it works great
KYOTA is offline   Reply With Quote
Old 11-10-2006, 10:09 AM   #18 (permalink)
4x Innovations
traxman25's Avatar
Member # 35227
Thanks KYOTA.
Shane, you'll be getting a call...
1-608-348-4880
Old 11-10-2006, 07:51 PM   #19 (permalink)
Member # 73930
I am also an electrician and I agree, A wheel type protractor is the way to go for accurate bend. And on another note I'd also look into buying a "No Dog" for bending offsets, or where there are many bends on the same plane.
82yoter is offline   Reply With Quote
Old 11-28-2006, 02:23 PM   #20 (permalink)
4x Innovations
traxman25's Avatar
Member # 35227
Just got my SmartTool digital level from Trick Tools. This thing is awesome! My desk is .4 deg tilted to the left. . Shane also recommended I get the almuminum bracket since mine will be used in the shop, and he knows how not nice I am to most of my tools... I also already have a POB bracket for the magnet base on the housing to "attach" to.
82yoter, what's a "No Dog"?
1-608-348-4880
Old 11-29-2006, 02:16 PM   #21 (permalink)
Member # 22501
I have one of those also but someone welded another angle to the bottom and a screww to fasten it to the pipe, since it came that way I will leave it alone. did have to make my own punch that I used oil hardening rod and made a point and hardened it. Works good.
Ed ke6bnl is offline   Reply With Quote
