Member # 14848
I paid about $1800 after taxes and trading in my little 80cf c25 bottle for a 165cf(? not sure, but the biggest bottle airgas had). I have put roughly 1000lbs of .035 wire through it, and it is a very good machine. Lately I have had a few rough patches with it, but it appears it is mostly taken care of. I had to replace the gun about 6 months ago, and I would highly recomend a high quality brass ground clamp, alot of my mystery problems stemmed from the fact that the crimped lug had burned through the cheap sheet metal clamp they provide, and I was getting a poor ground, I chased the problem for a long time before I found it.
Later, Jason
2006 JCORF Buggy, 60's,Locked F&R,42" TSLs,EFI460,C6,Atlas5.0 Comp Case 1988 Bronco,in progress |
#4 (permalink) | |
Member # 70509
You might consider the 175 then use the rest of the money you would have saved on a Miller 375 ($1082) plasma cutter. For a couple hundred more than just the cost of a 251 you can have both, and unless you plan on doing a bunch of commercial stuff or plan on welding up aircraft carriers in your spare time, you're ahead of the game. As I'll never (that I can think of anyway) have the need to weld/cut anything thicker than 3/8" the 210 welder and the 375 plasma suit my needs and budget well.
"In the end...It's all Hack." |
Lots of info on here in the search this is a VERY nice welder
I have a 251, My reasoning was I wanted a VERY nice welder and i only wanted to buy ONE. This thing should last me the rest of my life. I highly doubt I will ever crank it up to it's high settings. It is a big machine, If you have the space i would consider getting it. The infinate adjustability is a nice feature over the 210 but not biggie. On plasma cutters pretty much the ones to get are either the hypertherm 600 OR the thermal dynamics 51. get whatever one you have acess to consumables easily and cheapest. they are pretty much the same machine.
93 YJ, SOA. 37's locked '08 6.7L 4 door 4x4 LB. Mineral gray. Lorenz bilstein leveling kit. SRT hood. AFE CAI. Mag-hytec's. SMARTY ME. 120HP injectors. II stage 2 turbo. |
#6 (permalink) | |
Member # 50730
The 251 is the best welder I have ever owned/used. |
fishingwithdynamite
Member # 30721
I wrote this article for Off-Road.Com about the MM251 a while ago. No pricing information, but you said you were also looking for some feedback. For the record, I love mine.
Member # 50949
i bought mine about 3 months ago and like it alot. I run .035 solid and it does all i ask it to. Best deal i found was through quimby welding supplies. Look on ebay, they usualy have a few for sale and their price cant be beat, i saved around $70 over the ebay price since they are local to me and they knocked off the shipping money.
#10 (permalink) | |
1930 model A buggy for sale |
#12 (permalink) |
well ive been using a miller 135 and its just not enough and i dont want to have to go through the process of getting a new one later if im going to need it. thanks for the responses. ive never welded w/ anything but the 135 we have. what is the most noticable difference with the bigger machines? is it easier to make a nice bead? less splatter? less "popping"? takes less time to weld the thicker stuff? stronger weld?
Sit down lawn mower |
#13 (permalink) |
Member # 14848
I too had a MM135 before I bought my MM251. The main reason I bought the 251, was because trade in on my 2 tear old MM135 was only like $200, and I have paid $900 for it w/ gas. I didn't want to be in a position where I needed a bigger machine in 4 years and be stuck with something worth basically nothing. The price difference between the 210 and 251 was only about $250 (not talking list price, this is what my airgas guys quoted me at the time), I couldn't see not buying the mm251. Between the 135 and the 251, there is absolutely no comparison. Longer duty cycle, smoother welds, surperior feed control, more wire capacity, faster welding if you know what you are doing. And the list goes on, you will not regret it.
Later, Jason
#14 (permalink) |
of all the tools I have in my garage my 251 is my favorite! Night and day difference in weld and quality.
#16 (permalink) |
savage
Member # 1730
I just tried one of these out today and was really impressed with it. I welded an apron panel (thin sheetmetal unibody structure) back into an 05 scion. I was amazed by how fine the adjustment was and how I was easily welding sheetmetal with a machine that will also weld 1/2 plate in one pass. Best welder I have ever used.
"they've lowered the speed limit to zero and banned reverse" |
#18 (permalink) |
Member # 72707
I went with the 210, like it alot, sometimes wish I could tweak the power like I can with the 251 at the shop.... But I dont regret saving the 600 dollars.
I paid 1200 for my 210 |
#19 (permalink) | |
Member # 19967
