Dana 60 Case Spreader Design and Pictures - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-20-2006, 10:01 AM   #1 (permalink)
Off-Camber Crawlers
VTcivil's Avatar
Member # 30323
I made up my Dana 60 case spreader this weekend. Here is the design specs and some pictures in my Picasa Gallery.
http://picasaweb.google.com/vtcivil/Dana60CaseSpreader
Very useful tool for sure.
-Ryan
VTcivil is offline   Reply With Quote Quick reply to this message
Old 11-20-2006, 10:04 AM   #2 (permalink)
Member # 1889
Looks a whole lot like mine, except I welded crosstubes at the top and bottom of the angle instead of drilling through the other leg. I was worried that it'd twist the angle instead of spreading the case, so I wanted the force inline with the attachment points. Looks like I was unnecessarily paranoid about it.
Scott@Rockstomper is offline   Reply With Quote Quick reply to this message
Old 11-20-2006, 11:44 AM   #3 (permalink)
Off-Camber Crawlers
VTcivil's Avatar
Member # 30323
That's cool. I think I can visualize what you are saying. I was concerned about the size of the angle and the size of the threaded rod. I chose to go on the conservative side and there was no visible tweaking going on with the final design. I'm convinced a step or two down in angle ireon size and and 1/2" threaded rods would work, but might as well overbuild for a few bucks more.
Old 11-20-2006, 01:26 PM   #4 (permalink)
bronco75's Avatar
Member # 8512
Send a message via AIM to bronco75
I made mine out of old 1 " square pto shaft and 1/2 threaded rod I had laying around I get no twist but I could see it being a problem with angle.
keep up or get left behind
75 bronco trail buggy
60-9 frt
OutBack Auto 4WD and Fab
bronco75 is offline   Reply With Quote Quick reply to this message
Old 11-29-2006, 08:59 PM   #5 (permalink)
bremen242's Avatar
Member # 28687
I was thinking about using 1" square tube with 1/8" wall, and 1/2" fine threaded all-thread..
any thoughts on the 1" or would it be for pussies?
bremen242 is offline   Reply With Quote Quick reply to this message
Old 11-30-2006, 06:47 AM   #6 (permalink)
Off-Camber Crawlers
VTcivil's Avatar
Member # 30323
Well it sounds like bronco75 got it to work just fine. I would do it with what you have laying around if it will work... that's not pussy but cost effective
Old 11-30-2006, 07:31 AM   #7 (permalink)
Member # 12499
Do you see any issues with using the diff cover bolt holes instead of the holes for this use?
PTSchram is offline   Reply With Quote Quick reply to this message
Old 11-30-2006, 08:13 AM   #8 (permalink)
Off-Camber Crawlers
VTcivil's Avatar
Member # 30323
I have seen no ill effects. Prior to the 60, I used the diff cover holes on both my 44's with a spreader that I borrowed (same design) and it worked great.
Old 11-30-2006, 03:48 PM   #9 (permalink)
hellbilly_racing's Avatar
Member # 54147
Sorry for asking a stupid question, but what are these spreaders all about? I've never come across them before; factory or homemade!
Cheers
Perhaps if I made it out of billet and drilled holes in it to make it lighter you'd get it?
hellbilly_racing is offline   Reply With Quote Quick reply to this message
Old 11-30-2006, 03:59 PM   #10 (permalink)
bremen242's Avatar
Member # 28687
Cheers
when you preload bearings on a differential carrier, it makes it a really tight squeeze to fit it back into the case.
with a spreader, it spreads open the case about .015". You can then drop the carrier down into the case without beating it with a dead blow hammer.
btw, do the two cover holes (beside the bearing cap on either side) on the Dana 44 share the same spacing as a 60? I don't have my 61 over here to measure.. would suck to have to make two different spreaders.
good, have about 10ft of it...
Old 05-03-2016, 11:45 AM   #11 (permalink)
Off-Camber Crawlers
VTcivil's Avatar
Member # 30323
If anyone wants to buy this spreader from me, i can't use it anymore as my truss on my 60 now interferes with it.
-Ryan C.
Old 05-04-2016, 10:25 PM   #12 (permalink)
PARANOID56's Avatar
Member # 5114
Send a message via AIM to PARANOID56
how much do you want for it?
shipped to 92126
1971 FJ40 w/ rust
2003 Toyota Taco double cab
2013 Suzuki DRZ
TLCA member #12202
PARANOID56 is offline   Reply With Quote Quick reply to this message
Old 05-05-2016, 02:38 PM   #13 (permalink)
mrrisotto's Avatar
Member # 48117
I bought this one off eBay for $139 shipped. .015" spread was just about perfect for my 60.
mrrisotto is offline   Reply With Quote Quick reply to this message
Old 05-06-2016, 07:52 AM   #14 (permalink)
Off-Camber Crawlers
VTcivil's Avatar
Member # 30323
shipped to 92126
Make me an offer please. I can likely flat rate ship it via usps large box which is approx $18 for shipping, so add that on to your offer. PM's are best since it notifies me immediately.
-Ryan C.
