HD Snap ring pliers - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-27-2006, 12:33 AM   #1 (permalink)
90Beater's Avatar
Member # 52074
HD Snap ring pliers
I need to remove the monster Snap Ring from my transfer case (BW 1356) so I can reseal it. I tried a Sears one but it's not near strong enough. It claims up to 2" Outside Snap ring but this 1 1/4" or so one it too strong. I was looking around and found a few HD sets that have a screw type arm that look like they will work but need to find a B&M place I can pick one up in the morning so I can get to it. I don't want to wait for internet shipping.
Anyone have any ideas where I can pick one up locally?
[URL="http://bronco.tophersworld.com/"]Bronco.tophersworld.com[/URL] 1990 Full Size Bronco Camo Paint SAS 8 Lug. D44 Front 14B Rear
90Beater is offline   Reply With Quote
Old 12-27-2006, 02:13 AM   #2 (permalink)
Member # 41764
Get better at using snap ring pliers, I used a Sears set to take apart 241's(3 seperate occasions) and the same set to pull the snap rings off of the plasma generators at work, all the snap rings are in the 1-2" range. It is kind of a skill to make them work right when the snap rings don't have tangs with holes.
Tow Rig: 2006 Dodge 2500 610CTD/G56/NP271/AAM9.25/AAM11.5
Trail Rig: 1997 K1500 LQ9/4l80e/NP241/D60/14FF and some stuff in between
No one is ever gone if they are always remembered.
JasonPayneMemorial
bggrnchvy is online now   Reply With Quote
Old 12-27-2006, 02:44 AM   #3 (permalink)
braxton357's Avatar
Member # 14685
Send a message via AIM to braxton357
Build your own. Snap ring pliers are stupidly simple.
In vino veritas
70 turbocharged 351w fastback mustang
73 linked 5.8efi Bronco
99 QCLB 4x4 twin'd cummins on meth.
braxton357 is offline   Reply With Quote
Old 12-27-2006, 03:11 AM   #4 (permalink)
Member # 18989
I have this transmission set from Snap-On. It's worked for everything I've come across. Your local Snap-On guy should have it on the truck.
http://buy1.snapon.com/catalog/item....re&dir=catalog
A flash of lightning illuminated the object, wretch, hideous, filthy daemon. A new species would bless me as its creator.
frankenfab is offline   Reply With Quote
Old 12-27-2006, 06:37 AM   #5 (permalink)
Mechanos's Avatar
Member # 6704
Originally Posted by bggrnchvy View Post
...It is kind of a skill to make them work right when the snap rings don't have tangs with holes.
What you are describing is really a lock ring, not a snap ring (although they are referred to by most people as a snap ring since they don't know any better). What you want is a pair of lock ring pliers. The two on the right in the snap-on pic above are lock ring pliers. They have flat tips on them to fit between the ends of the lock ring and force it open when you sqeeze the handles.
It's
IHeavy
aka TORC
KC0UIC
Nothing is foolproof to a sufficiently talented fool.
Mechanos is offline   Reply With Quote
Old 12-27-2006, 08:04 AM   #6 (permalink)
Member # 16024
Track down a Snap On truck... They have a multiplicity of different snap ring and lock ring pliers -- all with lifetime warranty.
They're also made of some high-zoot steel. They hold up very well. Hardly ever had to warranty one when I was on the truck.
Gonna cost you a little bit, but they're worth it when they actually do the job without screwing up parts (or your hands).
Check out UCORA.org
VOTE or SHUT UP!
glfredrick is offline   Reply With Quote
Old 12-27-2006, 08:23 AM   #7 (permalink)
Mechanos's Avatar
Member # 6704
Any decent tool store should have them as well. I bought a pair from the auto parts store that worked well on the smaller lock rings on my T19, but the pivot was so close to the nose that they wouldn't spread far enough to take the bigger lock rings off. I went to the tool store here in town that is notorius for being expen$ive to see what they had. Ended up with a pair of US made lock ring pliers that were about the same size as my original pair, but the pivot was twice as far from the tips so they opened up about twice as far.... only $12.
It's
IHeavy
aka TORC
KC0UIC
Old 12-27-2006, 09:38 AM   #8 (permalink)
I make websites!
Member # 12429
The ones from NAPA have worked fine for my needs and don't SNAP the bank account They may have some to loan you for free too... wouldn't hurt to call them.
My 4x4 Blog
Rockwell axles too!
Todd W is offline   Reply With Quote
Old 12-27-2006, 11:03 AM   #9 (permalink)
90Beater's Avatar
Member # 52074
This is not a normal pressure snap ring. It took a lot more force than a normal snap ring to finally get it out. The cheap set just bent, the Sears set was an internal / external set that would just switch to int when you applied enough pressure to spread them open.
NAPA wanted $70 for a HD set. I went accross the street and Pep Boys had a HD set for $30. It worked. Now back to reseal the transfer case.
Old 12-27-2006, 04:39 PM   #10 (permalink)
Member # 17200
I bought a set of Knipex when I bent the ones I had from Sears. The Kinpex are much nicer and heavier duty, longer, and open wider.
Static-XJ is offline   Reply With Quote
Old 12-27-2006, 04:47 PM   #11 (permalink)
YJTypeR's Avatar
Member # 28268
Send a message via AIM to YJTypeR
Sears carries lock ring pliers too.......right next to the snap ring pliers.
YJTypeR is offline   Reply With Quote
Old 12-27-2006, 05:10 PM   #12 (permalink)
Loveday's Avatar
Member # 34298
I bought two cheapie lock ring pliars from HF. They did just fine removing the input shaft lock ring on an old Isuzu box. The lighter snap ring pliars I tried at first lost their tips.
Loveday is offline   Reply With Quote
Old 12-27-2006, 05:13 PM   #13 (permalink)
Mechanos's Avatar
Member # 6704
The ones that Sears has are the type with the pivot close to the tips and don't open very far. Pass on those and get a bigger pair.
It's
IHeavy
aka TORC
KC0UIC
Old 12-27-2006, 08:24 PM   #14 (permalink)
Member # 51692
Send a message via ICQ to rocknbronco Send a message via Yahoo to rocknbronco
I say go for the HF set I have yet to snap a set
Space for rent sold it all....
rocknbronco is offline   Reply With Quote
Old 12-27-2006, 10:55 PM   #15 (permalink)
90Beater's Avatar
Member # 52074
Ha-Ha that's what I started with. The multi set just fell apart. The larger single one just bent.
Not at my Sears. The $27 pro set was the best they had. I'm taking it back tomorrow. The Pep Boys set I bought is nearly as strong as the NAPA set but less than half the price. The pins on both are about 3 times larger than a standard set.
Anyhoo the transfer case is back together. Thanks for the advise guys.
Old 12-27-2006, 11:26 PM   #16 (permalink)
90Beater's Avatar
Member # 52074
Here is a pic for those interested.
Old 12-28-2006, 04:48 PM   #17 (permalink)
D60
D60's Avatar
Member # 6398
Had the same problem w my 1356. I went to Snappy and never looked back. The tips are not interchangeable but these pliers are fawking bomber with plenty of capacity for a bigger ring - no more pinched palms.
"Take 300 people and on average 290 of them just generally suck at life"
D60 is offline   Reply With Quote
Old 12-28-2006, 04:59 PM   #18 (permalink)
Mechanos's Avatar
Member # 6704
All of those pictured are snap ring pliers..... wrong tool for the job.
It's
IHeavy
aka TORC
KC0UIC
Old 12-28-2006, 08:49 PM   #19 (permalink)
houlster's Avatar
Member # 6292
I have a set of these:
http://www.toolfetch.com/Category/Ha...0ring%20pliers
They're very beefy, though I have managed to break one of the tips. The best part is the ratcheting lock. Makes it a lot easier on big snap rings as the lock holds the ring open/closed while you manipulate it.
--Dan
SC Amigo
houlster is offline   Reply With Quote
Old 12-28-2006, 08:57 PM   #20 (permalink)
Member # 10501
If anyone is looking for lockring pliers, why not buy it from Marlin Crawler? Got mine 2 yrs ago and has paid for itself many times.
http://www.marlincrawler.com/images/ring_pliers_500.jpg
jmsdad is offline   Reply With Quote
Old 12-28-2006, 09:56 PM   #21 (permalink)
Mechanos's Avatar
Member # 6704
Now those are lock ring pliers.... the right tool for the job. Those look just like the pair I bought at my local tool store for $12.
It's
IHeavy
aka TORC
KC0UIC
