Grinding Tungsten - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-23-2007, 10:16 AM   #1 (permalink)
Member # 6848
Grinding Tungsten
Hey guys, looking for information on grinding tungsten. How thin to make the point, etc. Anybody have a link? I have searched and searched...
Jack
71 1-ton EB
BITD 7200
IronBenderII is offline   Reply With Quote
Old 01-23-2007, 10:17 AM   #2 (permalink)
Member # 62080
Go to millers web site they have a lot of good tech for tig welding
xrated is offline   Reply With Quote
Old 01-23-2007, 10:26 AM   #3 (permalink)
Member # 14848
A tip on actually sharpening it well, put it in a battery drill and spin the tungsten while sharpening it. Always sharpen it axlially, nor radialy. I use a bench top belt sander on mine, and always sharpen it to a point. I believe that there is actualy a percentage of the diameter that you are supposed to sharpen to, but a sharp point works well for me. Also, if sharpening thorieated tungsten, try not to breathe the dust, or get it in your eyes. Thoriated tungsten is slightly radioactive.
2006 JCORF Buggy, 60's,Locked F&R,42" TSLs,EFI460,C6,Atlas5.0 Comp Case
1988 Bronco,in progress
Wicked_S10 is offline   Reply With Quote
Old 01-23-2007, 10:27 AM   #4 (permalink)
Member # 32841
Send a message via AIM to cybergeek23851
I've been doing 2 times the diameter. To sharpen it, I've been chucking the tungstens in a cordless drill and using that on the small bench grinder at the shop. I do it on the edge of the wheel, not the face. Also, be easy, don't force the Tungsten into the wheel, let the grinder do the work.
cybergeek23851 is offline   Reply With Quote
Old 01-23-2007, 10:33 AM   #5 (permalink)
Member # 26216
Send a message via Yahoo to Gummi Bear
My buddy that TIG's uses his bench mount belt sander to dress the tungsten tips, and then quenches them in a cup of water.
I consider myself a student of the game, it's just too bad I'm in special ed...
Gummi Bear is offline   Reply With Quote
Old 01-23-2007, 10:39 AM   #6 (permalink)
Member # 6848
Good info. So is 2x the diameter the correct amount?
71 1-ton EB
BITD 7200
Old 01-23-2007, 10:47 AM   #7 (permalink)
Member # 26216
He makes it about the shape of a pencil lead point. I'm not sure about any formula, just until it looks 'right'
Old 01-23-2007, 10:57 AM   #8 (permalink)
Member # 13655
I adjust the point depending on what I am going to weld.
Thin steel - sharper point to concentrate heat exactly where I need it. like a really sharp pencil point, 2 - 3 x the diameter of the tungsten
Thicker steel - still a sharp point, but more like a ball point pen look, rather than a drafting pencil look. maybe 1.5 - 2 x diameter of the tungsten
Aluminum. - even though I am going to "ball" the end I still sharpen the tungsten to about 2 x diameter first.
Once contaminated, make sure you break off far enough to remove the contaminant. I put the Tg into a vice and break it off, then rough sharpen it on a griding stone, and final sharpen on a belt sander. good tip above is chucking the Tg into a drill. And always axially not radially.
I always sharpen both ends of my steel Tg (red tips) so I can just reverse the Tg if it gets dull or contaminated. I only ever sharpen one side of the Al Tg (green). Easy way to keep them seperated even if the color is missing.
89 XJ, 8" lift, 38's, locked F&R
98 LR Discovery - street poser
99 F350 PSD 4x4 Jeep Tow Truck
2003 Mini Cooper S - street go-kart
2004 Subaru WRX STi - Vette eater
2005 Mini Cooper S - street go-kart on LSD
Pile of tube, 383 SBC, and some buggy plans
XtremeJ is offline   Reply With Quote
Old 01-23-2007, 12:02 PM   #9 (permalink)
Member # 6848
Thanks guys. I've read about balling the end for Aluminum, how do you do this?
71 1-ton EB
BITD 7200
Old 01-23-2007, 12:31 PM   #10 (permalink)
Member # 15404
The way I was taught was to start with a square point and arc it out over some brass. Heat her up good and the tip will start melting and round off. You don't want to get the tip to much bigger than the dia of the rod.
There are some times when you sharpen it first to get a smaller ball but we never did that.
Life begins where the pavement ends!
rcurrier44 is offline   Reply With Quote
Old 01-23-2007, 12:35 PM   #11 (permalink)
Member # 15404
Question for you guys. Do you need a special grinding stone for sharpening steel type points? I know aluminum is real sensitive to impurities but don't recall if the grinding stone was special or not.
Just finalized my order for a parker plas/tig
Old 01-23-2007, 02:48 PM   #12 (permalink)
Member # 50997
This site has lots of info and free how to guides on grinding tungsten. Also you can fill out a form on the site and get FREE sample tungstens!! The guides are in PDF format.
http://www.diamondground.com/
Click on [request samples] for the form!
MigMiester is offline   Reply With Quote
Old 01-23-2007, 02:54 PM   #13 (permalink)
Member # 50997
If you have an inverter machine, you DON'T want to ball the end.
Old 01-23-2007, 03:15 PM   #14 (permalink)
Member # 24640
I'm just getting into TIG...This is a great thread,
Iv'e heard that you want to use a dedicated grinder (or grinding wheel) to keep from contaminating your tungsten...especially for alluminum. Sounds like you guys just use your bench grinder.
Is that one of those things that you only worry about if your welding up nuclear reactors or something along those lines?
Co-Driver 4447 Camco Rock Racing
Thanks to our partners: Bulldog Winch, Jackson Powertrain, Winchline.com, BFG, Raceline wheels
jmhinescj is online now   Reply With Quote
Old 01-23-2007, 03:27 PM   #15 (permalink)
Member # 50997
I have a dedicated grinder and polishing wheel. Contamination will shorten the life of the tungsten. You'll want a grinding wheel with at least a 400 grit to do it right. That fine a grit isn't much good for anything else anyway.
Old 01-23-2007, 05:11 PM   #16 (permalink)
JeepinDoug's Avatar
Member # 13028
I use a bench grinder, 1.5 x the diameter and always dull the point.
I may lack much in way of integrety but I make up for it with pure denial.
[URL=http://www.pirate4x4.com/forum/showthread.php?t=377480][B][COLOR="Red"]Malvado Grande #1[/COLOR][/B][/URL]
JeepinDoug is offline   Reply With Quote
Old 01-24-2007, 09:32 PM   #17 (permalink)
OUTLAW MOTORSPORTS
4doorchevy's Avatar
Member # 69112
they do do make a powder that u heat the tungsten up and dip it in and it makes the point on it for you. Work great when tig a lot just keep dipping it for a fresh point. Think it comes from MSC book
97 tj 6.0 nv4500 241c on tons in the works
4doorchevy is offline   Reply With Quote
Old 01-25-2007, 12:42 PM   #18 (permalink)
ugpro's Avatar
Member # 69216
Another $.02 worth
For all but aluminum/magnesium use a pointed tungsten, thoriated,ceriated etc, grind with the long axis of the tungsten at 90 degree to the grinder spindle, you want the grind marks to following the cone (point). As for the length of the cone, 2x the diameter is recommended. Some folks opt for diamond grinders, I've always used an aluminum oxide belt, I do reserve the belt for tungsten only. I gripe my tungsten in 1/2 dia drill extension, easier to hold and I don't burn my fingers. The cordless drill is an option but you have to break your tungsten from the std 7.0 length.
For aluminum/magnesium:
If you're using a transformer machine, use pure tungsten and ball the end.
If you're using an inverter machine, never use pure tungsten, use thoriated, ceriated etc and grind the point off to a .020-.030 flat.
The manuals for Miller machines can be down loaded from millerwelds.com, there'll be page in the manual showing tungsten prep.
Big pile of parts, old Toyota, now to get them together..
ugpro is offline   Reply With Quote
Old 01-25-2007, 01:34 PM   #19 (permalink)
Member # 80279
When I weld aluminum with a syncrowave 250, I use the Red 2% tungstens. Works just fine, the red is about all a guy needs.
Cork is offline   Reply With Quote
Old 01-26-2007, 02:32 PM   #20 (permalink)
Member # 36733
Basically same thing(s) I do but I gave up on sharpening both ends. Had enough instances of having a ball or funkiness at the reversed end only to dip the wick and end up grumping about snapping the tungsten off while in the torch to get it out...
As to using a drill or other such, freehand on a pedestal wheel is all I've ever done ginding with the grain (length).
D.
[I]Vegetarian is an old Native American word for bad hunter[/I]
DavidVanVorous is offline   Reply With Quote
