Tap and Die question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-22-2007, 07:30 AM   #1 (permalink)
Member # 26743
Two questions when looking for tap and die sets.
What does the "NC" and "NF" mean
And where can I find a single 7/8's LH tap and a 7/8's RH tap?
Trogdor is offline   Reply With Quote Quick reply to this message
Old 02-22-2007, 07:40 AM   #2 (permalink)
Member # 14848
NC= SAE standard, or coarse thread pitch
NF= SAE fine thread pitch
There are also some intermediate thread pitches found in larger sizes, but they are pretty uncommon outside manufacturing facilities.
Off the top of my head, places that should have left and right taps, Graingers, Mcmaster carr, Fastenal, Most industrial tool and die supplies, or industrial fastener supplies.
You may want to try searching google for more info. You can find most of the above info, as well as the actual TPI for the different thread pitches according to bolt size.
Later,
Jason
2006 JCORF Buggy, 60's,Locked F&R,42" TSLs,EFI460,C6,Atlas5.0 Comp Case
1988 Bronco,in progress
Wicked_S10 is offline   Reply With Quote Quick reply to this message
Old 02-22-2007, 08:08 AM   #3 (permalink)
Cranky Moderator
steveh's Avatar
Member # 2026
Send a message via AIM to steveh
e-taps.com
85 Toy Xtracab
"I DON'T want to understand !!"
"Wow this is unbelievable"
steveh is offline   Reply With Quote Quick reply to this message
Old 02-22-2007, 08:40 AM   #4 (permalink)
Member # 26743
Does this sound right for a 7/8 tap in a 1.25 DOM with a .25 wall? I'm trying to make a tie rod and drag link with 7/8 TRE's.
for 7/8"-18 thread hole size is .828
for 7/8"-9 thread hole size is .766
Also what does the last number mean on the sizes?
Old 02-22-2007, 08:57 AM   #5 (permalink)
blueguy's Avatar
Member # 15631
Send a message via MSN to blueguy
The last number in the tap sizes is the TPI's or threads per inch.
blueguy is offline   Reply With Quote Quick reply to this message
Old 02-22-2007, 09:14 AM   #6 (permalink)
Member # 26743
Thanks guys. one last question.
What do these types mean?
Taper
Plug
Bottoming?
I think I understand the Taper one to be self centering, am I correct in the assumption?
Old 02-22-2007, 09:18 AM   #7 (permalink)
Member # 26743
Actually nevermind....Google rawks lol
Old 02-22-2007, 02:22 PM   #8 (permalink)
krb
krb's Avatar
Member # 7692
7/8-18 UNS tap drill size is .815-.828
7/8-9 UNC tap drill size is .755-.778
'85 CJ7,SOA,36" IROCS,9" HP Currie/Detroit,44 spooled,Tera Low,Warn 9000I,Mopar F.I.,Premier Welder
krb is offline   Reply With Quote Quick reply to this message
Old 02-23-2007, 08:44 PM   #9 (permalink)
TNToy's Avatar
Member # 5776
Be aware that you've got one fine-thread tap, and one coarse-thread tap, listed there. (That's the -9 and -18 thing)...
The tie rod ends I assume you're going to be needing these taps for? They'll most likely both be fine-thread. Fine or coarse, either way you'd still have one useless tap.
Old 02-23-2007, 09:31 PM   #10 (permalink)
solarpower's Avatar
Member # 47722
and if your going to make tie-rod ends fit into a knuckle you might need to get a tapered reamer also..if your making the hi-steer brackets.just a fyi
Professional Driver. Closed course.
solarpower is offline   Reply With Quote Quick reply to this message
Old 02-25-2007, 01:58 PM   #11 (permalink)
nate379's Avatar
Member # 20099
Tie rod end would probably be 7/8" x 18. The Chevy 1/2 ton TREs I used on my Jeep were anyhow.
nate379 is offline   Reply With Quote Quick reply to this message
