making an air compressor quiet, maybe building a dryer also - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-17-2007, 07:56 PM   #1 (permalink)
Member # 21000
Send a message via AIM to CPOM
I'm moving to a house with a small garage, so I'll be moving my air compressor to the basement to save garage space. About 30 feet of hose to the garage and I'd be all set. Although, I would like to make it much quieter since it will be indoors.
I have a standup husky air compressor.
I was thinking about removing the pump and motor and mounting it in a wooden box on rubber "feet". I think I would have to also build a little fan for ventilation also.
Then I got thinking about air dryers. I could mount the setup inside an old refridgerator which would make it quiet and have copper pipe run through a bucket of water. Then the pipe would exit the fridge to the holding tank.
I was also thinking about a few spare a/c units I have and building a dryer. How do these self contained refrigerated dryers work? Is there some type of liquid filled heat exchanger that is refrigerated?
maybe someone could run with these ideas. I haven't worked on trucks in a while so I'm thinking about these new projects.
[COLOR="DarkSlateGray"]Chris
92 Isuzu Pup, 3800>r150f>dual toy cases
toy 8", isuzu 12bolt, not done yet[/COLOR]
CPOM is offline   Reply With Quote Quick reply to this message
Old 04-17-2007, 08:11 PM   #2 (permalink)
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
Chris,
I would leave the compressor intact, put it on a thick rubber mat and build a vented box around it.
Link for El Cheapo dryer, /forum/shop-tools/542949-el-cheapo-compressed-air-dryer.html
guidolyons is offline   Reply With Quote Quick reply to this message
Old 04-17-2007, 08:42 PM   #3 (permalink)
Member # 14848
I don't think you are going to make the thing quiet enough to be happy with it in your house. I would just stick it outside the shop and build a small shed for it...
Later,
Jason
2006 JCORF Buggy, 60's,Locked F&R,42" TSLs,EFI460,C6,Atlas5.0 Comp Case
1988 Bronco,in progress
Wicked_S10 is offline   Reply With Quote Quick reply to this message
Old 04-17-2007, 08:54 PM   #4 (permalink)
jstarnes's Avatar
Member # 12575
Location: It puts the lotion on its skin OR it gets the hose
years ago I worked at a place that had a wash pit that had enzymes that ate oil, it always needed aerated water so there was a screw compressor near it
they has a box lined with 4 inches of styrofoam which cut the noise in half
from like ear plug loud to boy thats annoying loud
Im special, just like everyone else.
jstarnes is offline   Reply With Quote Quick reply to this message
Old 04-18-2007, 08:43 PM   #5 (permalink)
Member # 19022
Send a message via AIM to p575
unless theres other people living in the house does it matter? you cant be in the garage and the house at the same time...
semper fidelis
official pit chef for Will Carter #52x.
yeah, i cook...
p575 is offline   Reply With Quote Quick reply to this message
Old 04-19-2007, 05:55 AM   #6 (permalink)
45acp's Avatar
Member # 13671
Sure you can. I have mine in a closet between the garage and the kitchen. When its running you can barely hear it in the garage or the house. With the TV on you dont even notice it. I lined the walls and backside of the door with scrap carpet.
Get some scrap carpet and built a large box for it. Carpet the inside of the box, and mount it on those anti-vibration pads. I bet with all this in the basement you wouldnt even notice its running.
45acp is offline   Reply With Quote Quick reply to this message
